n70 flashing problem with mt... n70 with white screen...wants solution... log is here Phone is in: Phone is not responding, power on phone! ============= Set Flash mode for info ============= VBat is 3.98V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Boot... Using Tx2 Data line. rap3gv2_2nd.fg RAP3Gv3_algo.fg BOOT OK... Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006000C192101002200 EM_ASIC_ID( RAP ): 00000232 EM_ASIC_ID( RAP ): 00000352 PUBLIC_ID( RAP ): 0D500008E1C45551AA545484E2B6B2F7E61C5DD7 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): E9EFF4BFAA5393217CA6B17755FC3E14 ROM_ID( RAP ): F28A211FCEA7B19D --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Samsung, 00EC 2250 0000 0121 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ============= Set FBus mode for info ============= VBat is 4.00V Vpp pin has 0.97V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 VPP is DISABLED. Using Tx2 Data line. Processing File: RM84_50647301.C0 Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. |
1 Attachment(s) n70 white screen solution is here best of luck & Best Regards GSMCrazy1 |
cable problem mate see box rx is 0 and also bsi 0 too which cable r u using 5 pin or 7 pin |
unthick "using tx2line" in "automatic action while flashing" except you have modify your cable using tx2 line. and try press status query again. if APE still not detected, means hardware problem. regards |
uncheck use TX2 line and click on a 6th buton if you dont get BOOT OK then you need to mod cable and connect TX2 line |
how can i check tx2 line & modify cable |
easy- click on check box and connect 8th pin of 10pin(rj-48) connector on a mt-box to TX2 on the phone |
thankx in advance |
this is the pictures who you can take and from support siite |
thankx ................ |
