Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 08-14-2007, 17:28   #1 (permalink)
dharmdev's Avatar
Member: 51125
Thanks Meter: 1,435
N91 Rm-158 Not Read Ask To Rpl Pls Help Me 911gt
N91 RM-158 NOT READ ASK TO RPL PLS HELP ME 911GT
Phone is in: Test mode
Model: RM-158 (Nemo-w (China) )
V w33_06w24v4/13-09-06/RM-158 (c) Nokia.
Production serial number
Product code
Module code
Basic production code
Flash code
Order number
Long production SN
MCU SW V w33_06w24v4/13-09-06/RM-158/(c) Nokia.
PCI
RFIC 150a160e
DSP nemo_w_05wk32v32
APE SW Core V 2.10.013/15-09-06/RM-158/(c)Nokia
APE Variant V 2.10.013_v10.01/15-09-06/RM-158/(c)Nokia
Retu 32
Tahvo 52
APE HW 1
APE ADSP SW 256
Camera 25
APE BT HCI Version 2 (rev. 0). LMP Version 2 (rev. 3504). Manufacturer 13.
IMEI: 12345610654321?
WARNING: VPP pin is not connected, disabling VPP.
Operator: FFFFFFFFFFFFFFFF
Profile bits: FFFFFFFFFFFFFFFF
Closed on GID1: 00101F
Counters 0/10, 0/3
Boot...
rap3gv2_2nd.fg
Failed to find RAP3 Flash loader( damaged flash chip/damaged RAP3 chip)
PLS HELP ME
Old 08-15-2007, 09:34   #2 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
click on a OK buton and post log.
try to disable vpp
Old 08-15-2007, 17:41   #3 (permalink)
dharmdev's Avatar
Member: 51125
Thanks Meter: 1,435
MTBOX: 0034234f27 - Nokia Flash/Repair v1_35
Box: CR V 1.002 256
Code: NK V 1.001 1047
SN: 0034234f27
Nokia Unlimited: 259 times started
SonyEricsson Trial: 10 left, each max 15min
============= Set Flash mode for info =============
VBat is 3.90V
Vpp pin has 0.12V, Not Connected
Pins:
Mbus 1, Box Tx 1, Box Rx 1, Bsi 0
Boot...
rap3gv2_2nd.fg
Phone Type: BB5
------------------- SYSTEM ID Response: 12 blocks -------------
SYSTEM_ASIC_ID( APE ):
17100708
ASIC_MODE_ID( APE ):
00
PUBLIC_ID( APE ):
F0159FE26496CCE459F175A320223CF8C0DA0821
ROOT_KEY_HASH( APE ):
49A97E826B93BA20B7ED0B082475C00500000000
ROM_ID( APE ):
1DFD66132C872FD4
SYSTEM_ASIC_ID( RAP ):
000000010000022600010006000C192101012200
EM_ASIC_ID( RAP ):
00000232
EM_ASIC_ID( RAP ):
00000352
PUBLIC_ID( RAP ):
0F4001101C1E4E51B82E609B40F2E71C40085C3A
ASIC_MODE_ID( RAP ):
00
ROOT_KEY_HASH( RAP ):
E9EFF4BFAA5393217CA6B17755FC3E14
ROM_ID( RAP ):
F28A211FCEA7B19D
--------------- Device ID Response: 2 blocks -------------
Storage Device:
Owner Asic: RAP
Type: NOR Flash
Index: 0
Flash: Samsung, 00EC 2250 0000 0121
Storage Device Contents:
Owner Asic: RAP
000000000000000000000000000000000000
============= Set FBus mode for info =============
VBat is 3.94V
Vpp pin has 0.10V, Not Connected
Pins:
Phone is in: Local mode
Old 08-16-2007, 08:02   #4 (permalink)
MPhoneClinic's Avatar
Member: 20639
Thanks Meter: 233
Box: CR V 1.002 256
SN: 0034234f27
VBat is 3.90V
Pins:
Boot...
rap3gv2_2nd.fg
Phone Type: BB5
17100708
00
PUBLIC_ID( APE ):
ROM_ID( APE ):
1DFD66132C872FD4
EM_ASIC_ID( RAP ):
00000232
EM_ASIC_ID( RAP ):
00000352
PUBLIC_ID( RAP ):
00
ROM_ID( RAP ):
F28A211FCEA7B19D
Storage Device:
Owner Asic: RAP
Type: NOR Flash
Index: 0
Owner Asic: RAP
VBat is 3.94V
Pins:
yes i have the same problem after ask/rpl.
then i flash the erase file 8MB and reflash the phone and write back up PM and and use SX4 and re-write RPL and now the phone is imei 12345678.....
please GT give us step by step how to revive this.
thanks
mphoneclinic
Old 08-16-2007, 08:45   #5 (permalink)
dharmdev's Avatar
Member: 51125
Thanks Meter: 1,435
Box: CR V 1.002 256
SN: 0034234f27
VBat is 3.90V
Pins:
Boot...
rap3gv2_2nd.fg
Phone Type: BB5
17100708
00
PUBLIC_ID( APE ):
ROM_ID( APE ):
1DFD66132C872FD4
EM_ASIC_ID( RAP ):
00000232
EM_ASIC_ID( RAP ):
00000352
PUBLIC_ID( RAP ):
00
ROM_ID( RAP ):
F28A211FCEA7B19D
Storage Device:
Owner Asic: RAP
Type: NOR Flash
Index: 0
Owner Asic: RAP
VBat is 3.94V
Pins:
can not read ask file and give this error like
Boot...
rap3gv2_2nd.fg
Phone Type: BB5
Old 08-16-2007, 10:33   #6 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
need to check option "DisableVPP" and uncheck "UseTX2Line"
if then you dont have a BOOT OK then you need to connect TX2Line wire and check "UseTX2Line"
Old 08-16-2007, 10:41   #7 (permalink)
dharmdev's Avatar
Member: 51125
Thanks Meter: 1,435
VBat is 3.90V
Vpp pin has 0.14V, Not Connected
Pins:
Boot...
Using Tx2 Data line.
rap3gv2_2nd.fg
RAP3Gv3_algo.fg
helen3_2nd.fg
Failed to boot send APE 2ND (bad APE)
Phone Type: BB5
17100708
00
PUBLIC_ID( APE ):
ROM_ID( APE ):
1DFD66132C872FD4
EM_ASIC_ID( RAP ):
00000232
EM_ASIC_ID( RAP ):
00000352
PUBLIC_ID( RAP ):
00
ROM_ID( RAP ):
F28A211FCEA7B19D
--------------- Device ID Response: 3 blocks -------------
Storage Device:
Owner Asic: RAP
Type: NOR Flash
Index: 0
Owner Asic: RAP
VBat is 3.96V
Vpp pin has 0.09V, Not Connected
Pins:
Old 08-16-2007, 11:04   #8 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
you dont check in check box DISABLEVPP man!!!!!!!!1
Old 08-16-2007, 13:17   #9 (permalink)
dharmdev's Avatar
Member: 51125
Thanks Meter: 1,435
Product code
Module code
Flash code
Order number
Long production SN
PCI
RFIC 150a160e
Retu 32
Tahvo 52
VBat is 3.90V
Pins:
Boot...
rap3gv2_2nd.fg
RAP3Gv3_algo.fg
helen3_2nd.fg
Phone Type: BB5
17100708
00
PUBLIC_ID( APE ):
ROM_ID( APE ):
1DFD66132C872FD4
EM_ASIC_ID( RAP ):
00000232
EM_ASIC_ID( RAP ):
00000352
PUBLIC_ID( RAP ):
00
ROM_ID( RAP ):
F28A211FCEA7B19D
Storage Device:
Owner Asic: RAP
Type: NOR Flash
Index: 0
Owner Asic: RAP
VBat is 3.96V
Pins:
Old 08-16-2007, 13:38   #10 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
need TX2line
Old 08-17-2007, 00:28   #11 (permalink)
Member: 20639
Thanks Meter: 233
thanks
mphoneclinic
Sorry 911GT how about this please help!!
thanks
Old 08-17-2007, 07:05   #12 (permalink)
Member: 6109
Sonork: 100.37432
Thanks Meter: 3,782
@911GT,
I try with TX2 line cable same as support site schematic but no success.Flashing work 100% with same cable using TX2 line but ask reading same error always.
Same problem with N72 Rm-180.Normal N91 RM-43 don't have any problem reading ask.
Thanks & Regards.
Ashok Garg
Old 08-17-2007, 09:51   #13 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
post full log 1st click on a OK buton then click on a read ASK and post log please
Old 08-17-2007, 09:53   #14 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
sorry may be our bug , will be solved today sorry again
Old 08-17-2007, 10:01   #15 (permalink)
Member: 6109
Sonork: 100.37432
Thanks Meter: 3,782
@911GT,
Here is the log-
MTBOX: 0005f38e6a - Nokia Flash/Repair v1_35
Box: CR V 1.001 256
SN: 000xxxxxxx
Nokia Unlimited: 565 times started
SonyEricsson Trial: 9 left, each max 15min
Pins:
Boot...
rap3gv2_2nd.fg
RAP3Gv3_algo.fg
helen3_2nd.fg
h3_sam_nand_xsr.fg
BOOT OK...
Phone Type: BB5
17100708
00
PUBLIC_ID( APE ):
39E4A4CEF884F1559D09ECB1BCC09FBF439F99E5
ROM_ID( APE ):
1DFD66132C872FD4
EM_ASIC_ID( RAP ):
00000232
EM_ASIC_ID( RAP ):
00000352
PUBLIC_ID( RAP ):
0E40011195744E5137805CB6C81F1A6DD23B0A0D
00
ROM_ID( RAP ):
F28A211FCEA7B19D
Storage Device:
Owner Asic: RAP
Type: NOR Flash
Index: 0
Owner Asic: RAP
Pins:
IMEI: 358847001360983
Boot...
rap3gv2_2nd.fg
Ask creation failed.
BR.
Ashok Garg
cancel my request for i900 ask to rpl and give me my money back sameenshah123 UST Pro II 3 07-24-2009 18:55
which fault to no read information moto w375 pls help me? shimul_777 Infinity-Box 1 05-11-2009 06:11
bb5 PC cant read N70 to unlock pls help oo_phoenix_oo Nokia Base Band 5 ( BB-5 ) 1 07-04-2008 00:07
6086 Unlock Problem Pls Help Me 911gt dharmdev MT-BOX 6 09-22-2007 09:47
6086 Unlock Problem Pls Help Me 911gt dharmdev MT-BOX 7 09-17-2007 07:46
Page generated in 0.24191 seconds with 10 queries
