Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 06-01-2007, 10:05   #1 (permalink)
Member: 4123
Thanks Meter: 27
N95 dead after flashing with usb,I have griffin cable...
I flash my phone with phoenix via usb cable,and is dead only Nokia logo.I have griffin cable but I have this error:
Scanning files, please wait...
Done
Selected Highest installed version: 10.0.018
Using Tx2 Data line.
Processing File: RM-159_10.0.018_PR.C0R
Boot...
RAPIDOv102_2nd.fg
RAPIDOv11_algo.fg
omap2420_m1_2nd.fg
RAPIDOv102_2nd.fg
RAPIDOv11_algo.fg
omap2420_m1_2nd.fg
%%%%%%%% ERROR BOOTING:
What it's wrong?
Old 06-01-2007, 13:08   #2 (permalink)
Member: 13746
Thanks Meter: 2
hi
modify your FBUS cable & use to flash phone.
Old 07-02-2007, 17:37   #3 (permalink)
smootny's Avatar
Member: 77136
Thanks Meter: 12
how modify ? change rj45 on rj 48 and add pins ?
or add some pins ?
Old 07-02-2007, 19:19   #4 (permalink)
Member: 2800
Thanks Meter: 44
This thing for N95 is anoying a lot people,i've 2 cables 1 with tx2 line and without,no one is working for N95,but i connect the cables to twister and the enters in test mode,but mt-box dont do nothing.
Both cables are modified.
Old 07-02-2007, 23:35   #5 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
for flashing n95 you need to have a TX2. find shematic in forum and modify your cable then you have a BOOT OK
Old 07-03-2007, 10:58   #6 (permalink)
Member: 2800
Thanks Meter: 44
I have the schematic and i've checked my cable and everithing looks ok,i dont find any error in connections.
Old 07-03-2007, 13:02   #7 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
then your rj-48 on a box is brocken may be.
click on 6th buton and send the log
Old 07-03-2007, 13:15   #8 (permalink)
HAROON's's Avatar
Member: 100592
Sonork: 1578498
Thanks Meter: 245
yes log is better ot help you out
best of luck
Best Regards
GSMCrazy1
Old 07-03-2007, 13:29   #9 (permalink)
Member: 2800
Thanks Meter: 44
This is what i get:
Pins:
Mbus 1, Box Tx 1, Box Rx 0, Bsi 0
Boot...
Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit
============= Set FBus mode for info =============
Pins:
What can the problem be.When i connect cable to twister i've done factory defaults without any problem.I'm only having problem for flasing this phone,all other N series or E series without any problem,of course for other cables i use adaptor,this one i connect directly.
Old 07-03-2007, 13:37   #10 (permalink)
Member: 2800
Thanks Meter: 44
Sorry this is log when i use cable without tx line+adaptor
============= Set Flash mode for info =============
Pins:
Boot...
RAPIDOv102_2nd.fg
RAPIDOv11_algo.fg
omap2420_m1_2nd.fg
Failed to boot send APE 2ND (bad APE)
Phone Type: BB5
------------------- SYSTEM ID Response: 11 blocks -------------
SYSTEM_ASIC_ID( APE ):
24200705
ASIC_MODE_ID( APE ):
00
PUBLIC_ID( APE ):
A7F04A5753EA280915EA6178D6467F23F94B11A1
ROOT_KEY_HASH( APE ):
BA8710A7E1CD5A2909B9A875DB27AA2400000000
SYSTEM_ASIC_ID( RAP ):
000000010000022600010006400C192101011103
EM_ASIC_ID( RAP ):
00000295
EM_ASIC_ID( RAP ):
00000B21
PUBLIC_ID( RAP ):
0D900001CE4400580F39C32B9A2DC9F3F4C0A8B6
ASIC_MODE_ID( RAP ):
00
ROOT_KEY_HASH( RAP ):
CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM_ID( RAP ):
F2C6EBADC86E6189
--------------- Device ID Response: 3 blocks -------------
Storage Device:
Owner Asic: RAP
Type: NOR Flash
Index: 0
Flash: Amd, 0001 0035 0000 6921
Storage Device Contents:
Owner Asic: RAP
000000000000000000000000000000000000
Pins:
Old 07-03-2007, 13:55   #11 (permalink)
Member: 483440
Thanks Meter: 170
i had the same problem but with N93
this is what i did:
1-flash only MCU
2-reconnect box
3-flash only PPM
phone revive again
just try this solution you have no think 2 lose !
Old 07-04-2007, 05:19   #12 (permalink)
stefanusrudy's Avatar
Member: 128035
Thanks Meter: 315
Pins:
Boot...
RAPIDOv102_2nd.fg
RAPIDOv11_algo.fg
omap2420_m1_2nd.fg
Phone Type: BB5
24200705
00
PUBLIC_ID( APE ):
EM_ASIC_ID( RAP ):
00000295
EM_ASIC_ID( RAP ):
00000B21
PUBLIC_ID( RAP ):
00
ROM_ID( RAP ):
F2C6EBADC86E6189
Storage Device:
Owner Asic: RAP
Type: NOR Flash
Index: 0
Owner Asic: RAP
Pins:
should be like this:
Vpp pin has 2.27V, Connected
Pins:
Mbus 1, Box Tx 1, Box Rx 1, Bsi 0
Boot...
RAPIDOv102_2nd.fg
RAPIDOv11_algo.fg
omap2420_m1_2nd.fg
teflon_sam_nand_xsr151_m1.fg
BOOT OK...
Phone Type: BB5
24200705
00
PUBLIC_ID( APE ):
34C1B69C976CD3825560DD60F0A29ECF3E563ED4
EM_ASIC_ID( RAP ):
00000295
EM_ASIC_ID( RAP ):
00000B21
PUBLIC_ID( RAP ):
1EA00012CB480058094A552DB2E96DFB8B484D49
00
ROM_ID( RAP ):
F2C6EBADC86E6189
Storage Device:
Owner Asic: RAP
Type: NOR Flash
Index: 0
Owner Asic: RAP
Pins:
Phone is in: Local mode
Model: RM-159 (N95)
V 06wk41v18.4/13-03-07/RM-159 (c) Nokia
IMEI: 354835011550887
http://forum.gsmhosting.com/vbb/show...3&postcount=12
so, there're 2 options:
- make/modify cable become rj48/10 pins cable.
- modify mt-box 10 to 8 adapter, use 7th pin in rj45 (between vbat & bsi) to make tx2 line, connect to rx2 in phone.
regards
Old 07-16-2007, 23:17   #13 (permalink)
Member: 276432
Thanks Meter: 65
i want to know hot modfy the cable 10 pin to work with 8 pin please i want more details
Old 07-17-2007, 13:49   #14 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
need to open adapter and solder wire to grey wire.
this cable is TX2 line. on a cable for phone need put one more pin for a tx2 line and solder wire,then connect 2 wires
Old 07-17-2007, 14:26   #15 (permalink)
Member: 276432
Thanks Meter: 65
can you explain to me with drawing a picture hot to mdify my adapter please
n95 8giga dead after flash with usb melgsm MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 11-15-2009 09:42
N95 dead after flashing with Phoenix zoki Nokia Base Band 5 ( BB-5 ) 10 05-10-2007 21:09
J300i dead after flashing with usb smart som one can help??? .::Moby World::. SonyEricsson (USB-Smart) 8 12-20-2005 20:14
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.23165 seconds with 9 queries
