Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 10-22-2007, 11:42   #16 (permalink)
harim_1981's Avatar
Member: 243961
Sonork: 100.1591654
Thanks Meter: 104
Djsoft ....
while taking the backup of your certificates what is the simlock status...
in that time also whether it is in same 10/10 means after writting that backup u will get same only...
then u need RPL....
Old 10-22-2007, 12:04   #17 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
Bro You Now Writing Rpl !
Originally Posted by DjSwift View Post
well my result was its still 10/10
I get the impression there is a bug in the MT software ?
forgive me if im wrong. But I have a friend with a similar situation as me.
But he wrote the pm with JAF which did reset the counters.
Trouble is, my JAF is under construction (its broken)
DJ
AFTER WRITE RPL CHEK THIS CONTURES AND NO MORE PROBLEMS NOW UNLOCK THIS PHONE !
BR.
Old 10-22-2007, 12:42   #18 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
mate, only one solution for your problem ASK2RPL
Old 10-22-2007, 20:34   #19 (permalink)
Member: 5243
Thanks Meter: 80
DJ
Yes mine was the "similar situation" mentioned above, but it was a 6234, everytime MT wrote it back automaticly when unlock fails or if i wrote pm backup using the write pm, it was still 10/10, wrote the exact same backup using jaf, and first time it worked, counters reset!
Old 10-22-2007, 21:39   #20 (permalink)
DjSwift's Avatar
Member: 5360
Sonork: 1577169
Thanks Meter: 24
Too late for that, phone is broken i think.
When i switch on i see nokia logo
and then lights go, and nokia logo dissapears
DJ
Old 10-23-2007, 00:41   #21 (permalink)
yeldar's Avatar
Member: 12578
Thanks Meter: 60
@DJ,
Send phone up to me mate, maybe I can fix it for you......
Regards
Daz
Old 10-23-2007, 09:37   #22 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
DJ
dont worry all is ok need to be erased and flashed and all will be ok
Old 10-23-2007, 11:53   #23 (permalink)
Member: 227318
Rpl? - What for, if you have backup? I had the same case. Try to write pm-134 (but without making authorisation-actually you dont need to authorise to do this) whith another-older version of MT. Try it few times with few versions- FINALLY IT HELPED ME. Than, when the counter was 0/10 I downgraded fhone. But when I was making unlock again it started to "failed attempts", then I quickly remove testpoints, before it reached 10/10 and tnen... surprise phone unlocked. It looked like: touching TP for too long couse counter full. I dont know why, maybe it is a bug.
Old 10-23-2007, 12:06   #24 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
mate read up postings!!! he write "after restore backup i have a 10/10!!!!
Old 10-24-2007, 23:33   #25 (permalink)
DjSwift's Avatar
Member: 5360
Sonork: 1577169
Thanks Meter: 24
Doesnt flash
its going back to vodafone. And they will replace under warranty
Old 10-25-2007, 07:07   #26 (permalink)
UNIQUEM's Avatar
Member: 496203
Sonork: 100.1583640
Thanks Meter: 232
dear only one way just rpl any other tool can't help you
Old 10-25-2007, 07:12   #27 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
Try this tricks, write pm backup...after write disconnect the cable then try to read
hope it helps..
regards
N95 unlocked but still locked GSM SNIPER BB5KING 4 01-20-2009 22:40
N95 when unlocking but testpoint failed.. but ok i have the pm what next ? DjSwift MT-BOX 1 04-08-2008 21:46
N95 - 10/10 but 0/3 ! i_seeque J.A.F. V-SPEC 3 12-20-2007 21:09
What next if i change uem and its two flash ics? N761 Nokia Digital Core Technology 4 ( DCT-4 ) 6 07-21-2007 20:13
Page generated in 0.19703 seconds with 9 queries
