N96 dead after flashing with MT i flash phone with USB cable and phone white screen . pls help me how to solved problem . MT supported flash fbus now ? |
you must flash it like dead USB BR |
problem have be solved by JAFSetup_1.98.61 |
now your phone is white screen only, no NOKIA words even. full flash it again via usb. put the baterry to phone but do not switch it ON. After clicking flash you see 'Power ON phone, press pwer buttun one time and wait it will responding. I'm using MT-bx 1.53 http://forum.gtibox.com/showthread.php?t=4639 |
Processing File: RM-247_10.065_prd.core.fpsx Boot... \\?\nmwcd#vid_0421&pid_0106&if_oth#6&15da089&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381} FAILED TO BOOT PHONE!!! Make sure that phone is connected. BB5 PM back Phone is in: Phone is not responding! Processing File: RM-247_10.065_prd.core.fpsx Boot... \\?\nmwcd#vid_0421&pid_0106&if_oth#6&15da089&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381} FAILED TO BOOT PHONE!!! Make sure that phone is connected. BB5 PM back Phone is in: Phone is not responding! Processing File: RM-247_10.065_prd.core.fpsx Boot... CONNECT PHONE to USB and Power ON phone! Pooling for phone... \\?\nmwcd#vid_0421&pid_0106&if_oth#6&15da089&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381} FAILED TO BOOT PHONE!!! Make sure that phone is connected. BB5 PM back Phone is in: Phone is not responding! Processing File: RM-247_10.065_prd.core.fpsx Boot... CONNECT PHONE to USB and Power ON phone! Pooling for phone... \\?\nmwcd#vid_0421&pid_0106&if_oth#6&15da089&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381} FAILED TO BOOT PHONE!!! Make sure that phone is connected. |
I have same problem, phone is killed by MT and now doesn't want to flash it, I even tried with JAF and it can't flash it also, phone was before flashing working 100%!!! I tried and with v1.53 and v1.54 and same problem!! Here is log: Selected Highest installed version: 12.035 Using Tx2 Data line. Processing File: RM-247_12.035_prd.core.fpsx Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. VPP is DISABLED. Using Tx2 Data line. Processing File: RM-247_12.035_prd.core.fpsx Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. VPP is DISABLED. Processing File: RM-247_12.035_prd.core.fpsx Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. Using Tx2 Data line. Processing File: RM-247_12.035_prd.core.fpsx Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. Using Tx2 Data line. Processing File: RM-247_12.035_prd.core.fpsx Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. FAILED to find USB Device. Attach phone to usb port! Switched to USB BUS Using Tx2 Data line. Processing File: RM-247_12.035_prd.core.fpsx Boot... CONNECT PHONE to USB and Power ON phone! Pooling for phone... FAILED TO BOOT PHONE!!! Make sure that phone is connected. Switched to service cable FBUS Using Tx2 Data line. Processing File: RM-247_12.035_prd.core.fpsx Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. FAILED to find USB Device. Attach phone to usb port! Switched to USB BUS Using Tx2 Data line. Processing File: RM-247_12.035_prd.core.fpsx Boot... CONNECT PHONE to USB and Power ON phone! Pooling for phone... \\?\nmwcd#vid_0421&pid_0106&if_oth#6&29b7dfd9&6&00 #{4f919102-4adf-11d5-882d-00b0d02fe381} STn8815_2nd.fg STn8815_STNFMS_alg.fg %%%%%%%% ERROR BOOTING: VPP is DISABLED. Using Tx2 Data line. Processing File: RM-247_12.035_prd.core.fpsx Boot... \\?\nmwcd#vid_0421&pid_0106&if_oth#6&29b7dfd9&6&00 #{4f919102-4adf-11d5-882d-00b0d02fe381} FAILED TO BOOT PHONE!!! Make sure that phone is connected. VPP is DISABLED. Using Tx2 Data line. Processing File: RM-247_12.035_prd.core.fpsx Boot... CONNECT PHONE to USB and Power ON phone! Pooling for phone... \\?\nmwcd#vid_0421&pid_0106&if_oth#6&29b7dfd9&6&00 #{4f919102-4adf-11d5-882d-00b0d02fe381} STn8815_2nd.fg STn8815_STNFMS_alg.fg %%%%%%%% ERROR BOOTING: Using Tx2 Data line. Processing File: RM-247_12.035_prd.core.fpsx Boot... \\?\nmwcd#vid_0421&pid_0106&if_oth#6&29b7dfd9&6&00 #{4f919102-4adf-11d5-882d-00b0d02fe381} FAILED TO BOOT PHONE!!! Make sure that phone is connected. Using Tx2 Data line. Processing File: RM-247_12.035_prd.core.fpsx Boot... CONNECT PHONE to USB and Power ON phone! Pooling for phone... \\?\nmwcd#vid_0421&pid_0106&if_oth#6&29b7dfd9&6&00 #{4f919102-4adf-11d5-882d-00b0d02fe381} STn8815_2nd.fg STn8815_STNFMS_alg.fg %%%%%%%% ERROR BOOTING: |
GSMBlade & simply-cy You need to flash ONLY mcu & skip APE with same SW version via FBUS (tested with jaf...) and your phone will be OK ;) BR Mamin |
http://forum.gsmhosting.com/vbb/show...&postcount=109 BR |
