10-16-2007, 14:21 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 597580 Status: Offline Thanks Meter: 0 | N95 test point failed Scanning files, please wait... Done Selected Highest installed version: 10.0.018 Model: RM-159 (Aalto (EU) ) V 06wk41v31/05-06-07/RM-159 (c) Nokia Production serial number SGI760931 Product code 0552597 Module code Basic production code 0537959 Flash code Order number Long production SN 0 MCU SW V 06wk41v31/05-06-07/RM-159/(c) Nokia HW 5900 PCI RFIC 17141714 DSP dsprap_pb06w41v34 APE SW Core 12.0.013 APE Variant 12.0.013F5.01 APE Test rm159_eno_2007wk16v0.150 Retu 15 Tahvo 22 APE HW 1 APE ADSP SW 256 APE BT HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. IMEI: 356996013797963 V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 356996013797963 Operator: 0000000000000000 Profile bits: 2140100000000000 Closed on GID1: 21401F Closed on Mcc Mnc: 21401F Counters 10/10, 0/3 its hapens when cooms to mutch time TEST POINT FAILED , its posible reset counter by restore pm or imei backup or i need rpl ????? thanks |
02-21-2008, 13:38 | #3 (permalink) |
No Life Poster Join Date: Apr 2002 Location: South Spain Age: 41
Member: 10905 Status: Offline Thanks Meter: 109 | V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 358998010793340 V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 358998010793340 V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 358998010793340 V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 358998010793340 V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 358998010793340 V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 358998010793340 TPs OK TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED Alternating to keyboard counter! TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED FAILED, ALL ATTEMPTS USED! Sending SIMLOCK record... Warning: Failed to write 134:0001, 8192bytes. Use SX4 button to authorize Restarting phone Finished Restarting phone No communication with phone. I have backup, but can't restore, any advice? Thanks |
02-21-2008, 14:55 | #4 (permalink) |
Banned Join Date: May 2006 Location: United Kingdom
Member: 270521 Status: Offline Sonork: 100.15962233 Thanks Meter: 369 | try to write the simlock data with fbus cable load the same imei named file from bb5backup folder in c:/programe file/griffinteam and slect eprom read write load file and then write it. it should work and if not use jaf copy that file any where and slect write pm and click service it will do post reply |
02-22-2008, 14:55 | #11 (permalink) |
Member: 10905 Status: Offline Thanks Meter: 109 | I tried to edit post because i solved quickly but server was busy. I tried to post that was cable problem, but server was busy. Now, it seems this is working now; is working good using fbus cable. Thanks to all for your help Wbr |
5500 tp ok test point fail | dharmdev | MT-BOX | 1 | 05-26-2008 16:12 |
N95 test point by uid box | ::.imeimate.:: | UID - Box | 8 | 10-31-2007 23:40 |
5500 tp ok test point fail | dharmdev | MT-BOX | 2 | 09-10-2007 16:42 |
5200 mt pro unlock problem. test point failed!!!!!!!!! | zenadia | Nokia Base Band 5 ( BB-5 ) | 3 | 07-12-2007 19:54 |
hello test point failed andf i lost many credi | mbourtelephone | MT-BOX | 5 | 06-11-2007 17:34 |
