Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 10-02-2006, 06:13   #1 (permalink)
ChIcO*GsM's Avatar
Member: 152205
Pay attention MT can't choose flashes right
while i was flashing my 9500 with ver.4.51
i choosed from the Pcode tab Arabic
and the MT choosed the flashfiles itself as useual
but when i press flash it says
ERROR: Unable to open file
C:\Program Files\Nokia\Phoenix\\Products\RA-2\RA2_XXX
Terminating flash procedure
Old 10-02-2006, 06:25   #2 (permalink)
MicrostarGSM®'s Avatar
Member: 18855
Thanks Meter: 1,939
make sure that you are install to correct folder
if you have recently using the ufs suite installer the flash file will instal to others folder and not on the correct folder which Crogram files/nokia/phoenix/products
make sure the file is on this filder
also make sure install the major and minor DP if avalibale
if your flash files is in correct folder mena the files i not avaliable for the region
Old 10-02-2006, 07:09   #3 (permalink)
ChIcO*GsM's Avatar
Member: 152205
sorry dear
the flashfiles already installed 2 the correct folder
and when i choose them manual the phone flashes well
major and minor DP installed well 2
but when i let the program choose them it make this error
have u any explaination?
thanx 4 replay
br/ChIcO
Old 10-02-2006, 13:03   #4 (permalink)
Member: 18855
Thanks Meter: 1,939
sorry dear
thanx 4 replay
br/ChIcO
normaly in this case the file is not avalibale on your pc if you select by manually what is the files you are selectiing can you provide the file name here and let me try
coz i am trying here no problem
Old 10-05-2006, 05:30   #5 (permalink)
ChIcO*GsM's Avatar
Member: 152205
so it could be a problem of the flash dp
so if u plz test the dp major and minor for the version 4.51 and tell me the results
it would be better if u made a screenshoot
coz i tested it myself and didn't work well thatz y i made the post
waiting ur replay
Old 10-05-2006, 07:22   #6 (permalink)
Member: 18855
Thanks Meter: 1,939
waiting ur replay
ok for your information the dp some ini files is shown thet the files if avalibale but the flash file is not avaliable
if you get that message and check on your folder if the file not avalibale mean the dp not comes wiht that package
HOW CAN I CHOOSE THE RIGHT FLASH FILE FOR My X1-trio shola5 SMTi 1 08-23-2007 14:14
pay attention here if you flash your DB2020 mutualmobile Cruiser Suite 16 02-04-2007 08:54
Dejan Box 1.04: Choosing the right PC specs>? ed2k_7 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-20-2001 03:25
Page generated in 0.17174 seconds with 9 queries
