Please help me unlock 6500s erro V 07.12/28-05-08/RM-240 (c) Nokia IMEI: 356400022384608 Operator: 8000000000000000 Profile bits: 5050300014981890 Closed on Mcc Mnc: 50503F Backup simlock Backup SIMLOCK: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\356400022384608.pm 356400022384608 Booting Phone... Searching loader rap3gv3_2nd.fg !!!Operation Has Failed!!! |
you need 1st becup jaf with. then u downgred 4.81 with jf after unlock mt box new exe MTB_NK1_57_2 i hope you will do unlock.TNX post result? |
check your cable first! it must be a cable fault! use right cable and right resistor value and all will go smooth! 1'st read phone info 2'nd [SL2 Unlock] button BR |
1.UPDATE YOUR MT-BOX WITH MT UPDATE TOOLV-3.8 2.CHECK YOUR CABLE 3.YOU MUST HAVE TO USE PERFECT 10PIN CABLE DIRECT TO MT-BOX(WITHOUT VPP ADOPTE) THEN U CAN TRY BR, P@lash_c6 |
HI BRO Phone is in: Local mode Model: RM-240 (RM-240) V 04.81/22-11-07/RM-240 (c) Nokia Production serial number KOG320838 Product code 0555552 Module code 0203327 Basic production code 0543753 Flash code Order number Long production SN 0 MCU SW V 04.81/22-11-07/RM-240/(c) Nokia HW 2000 PCI RFIC 17141715 DSP ICPR71_07w43 LCD SHARP PPM V 04.81/22-11-07/RM-240/(c) Nokia /C Retu 15 Tahvo 22 Content Pack Content: c_uk/V 04.81/22-11-07/RM-240/(c) Nokia / IMEI: 353076027538571 WARNING: VPP pin is not connected, disabling VPP. 353076027538571 V 04.81/22-11-07/RM-240 (c) Nokia IMEI: 353076027538571 Operator: 8000000000000002 Profile bits: 2342000000000000 Closed on Mcc Mnc: 23420F Closed on Mcc Mnc: 23594F Backup simlock Backup SIMLOCK: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\353076027538571_n.pm 353076027538571 Booting Phone... Searching loader Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit !!!Operation Failed!!! 353076027538571 V 04.81/22-11-07/RM-240 (c) Nokia IMEI: 353076027538571 Operator: 8000000000000002 Profile bits: 2342000000000000 Closed on Mcc Mnc: 23420F Closed on Mcc Mnc: 23594F Backup simlock Backup SIMLOCK: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\353076027538571_n.pm 353076027538571 Booting Phone... Searching loader Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit !!!Operation Failed!!! WHATS THE PROBLEM CABEL IS OK 100% I MADE 4 TODAY ITS PHONE OR SOFT PROBLEM |
