09-03-2007, 17:43 | #1 (permalink) |
Insane Poster Join Date: Aug 2005
Member: 173199 Status: Offline Thanks Meter: 8 | failed ADSP flashing (N gage) i have flashed the normal nem-4 (n gage) many many times... and the result is NOTHING JUST have STUCK from this F**K FLASHER BOX!!! please tell me where i'm wrong on this log. and i try to flash it with other ROOKIE flasher box (just once) and the result is OK and the phone NORMAL. so i flash it with mt AGAIN, result SAME... get stuck while writing mcu. and i have skip bluetooth flashing too. ============= Set FBus mode for info ============= VBat is 3.96V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 Scanning files, please wait... Done Boot... WD2 BT2 w2_2nd.fia w2_amd.fia ASIC ID: 0082 Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA UEM IMEI is: 351521005 ============= Set FBus mode for info ============= VBat is 3.96V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: NEM-4 ( N-Gage) V 4.03/26-11-2003/NEM-4 (c) NMP. IMEI: 351521005 Phone is in: Local mode Model: NEM-4 ( N-Gage) V 4.03/26-11-2003/NEM-4 (c) NMP. Production serial number SHA779145 Product code 0510299 Module code Basic production code 0507870 Flash code Order number Long production SN MCU SW V 4.03/26-11-2003/NEM-4/(c)NMP HW 0720 PCI UEM 8 UPP 130 RFIC 0300 DSP SS206-3.20 PPM V 4.03/26-11-2003/NEM-4/(c)NMP.98 BT MCM HCI: 0x01 (rev. 0x0000). LMP: 0x01 (rev. 0x0248). Manuf: 0x0001 IMEI: 351521005 WARNING: VPP pin is not connected, disabling VPP. VPP is DISABLED. Phone is in: Local mode IMEI: 351521005 Generated RPL file from resource 208 C:\Program Files\Nokia\Phoenix\Products\NEM-4_351521005.rpl Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.71 MB]... erasing region [00000000 to 0000FFFF] erasing region [00010000 to 006FFFFF] ADSP device: \\?\usb#vid_0451&pid_9000#5&34522811&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} OK Inspect erasing region [02000000 to 023FFFFF] erasing region [04000000 to 046B4FFF] in 181.02s Flash[17.91 MB]... Lower send speed for Bluetooth flashing Restoring to fast speed>>>>>>>>>>>>>>>>>>>>>>>>GET STUCK IN HERE %%%%%%%% ERROR SENDING FLASH: Failed at address 00012000 VPP is DISABLED. Phone is in: Phone is not responding, power on phone! Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.71 MB]... erasing region [00000000 to 0000FFFF] ADSP device: \\?\usb#vid_0451&pid_9000#5&34522811&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} erasing region [00010000 to 006FFFFF] OK Inspect erasing region [02000000 to 023FFFFF] erasing region [04000000 to 046B4FFF] in 198.05s Flash[17.91 MB]... Lower send speed for Bluetooth flashing BT Version: 22 Restoring to fast speed>>>>>>>>>>>>>>>>>>>>>>>>GET STUCK IN HERE %%%%%%%% ERROR SENDING FLASH: Failed at address 00004000 VPP is DISABLED. Phone is in: Phone is not responding, power on phone! Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.71 MB]... erasing region [00000000 to 0000FFFF] ADSP device: \\?\usb#vid_0451&pid_9000#5&34522811&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} erasing region [00010000 to 006FFFFF] OK Inspect Supported Proceed.... Empty check: Not Empty Erasing Elapsed 10s Elapsed 10s Elapsed 10s Erase OK sw_dl_init : status o.k. sw_dl_end : status o.k. sw_checksum : status o.k. ADSP Flashing DONE erasing region [02000000 to 023FFFFF] erasing region [04000000 to 046B4FFF] in 196.95s Flash[17.91 MB]... Lower send speed for Bluetooth flashing Restoring to fast speed>>>>>>>>>>>>>>>>>>>>>>>>GET STUCK IN HERE %%%%%%%% ERROR SENDING FLASH: Failed at address 00008000 ADSP device: \\?\usb#vid_0421&pid_0102#5&34522811&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} vid_0421&pid_0102 device not supported VPP is DISABLED. Phone is in: Phone is not responding, power on phone! %%%%%%%%%%%%%%%%% ABORTED FLASH %%%%%%%%%%%%%%%%%%%%%%%%%%%%% - Nokia Flash/Repair v1_36 Box: CR V 1.002 256 Code: NK V 1.001 1047 SN: Nokia Unlimited: times started SonyEricsson Trial: left, each max 15min VPP is DISABLED. Phone is in: Phone is not responding, power on phone! Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.71 MB]... erasing region [00000000 to 0000FFFF] ADSP device: \\?\usb#vid_0451&pid_9000#5&34522811&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} erasing region [00010000 to 006FFFFF] OK Inspect Supported Proceed.... Empty check: Not Empty Erasing Elapsed 10s Elapsed 10s Elapsed 10s Erase OK sw_dl_init : status o.k. sw_dl_end : status o.k. sw_checksum : status o.k. ADSP Flashing DONE erasing region [02000000 to 023FFFFF] erasing region [04000000 to 046B4FFF] in 196.99s Flash[17.91 MB]... Lower send speed for Bluetooth flashing BT Version: 22 Restoring to fast speed>>>>>>>>>>>>>>>>>>>>>>>>GET STUCK IN HERE %%%%%%%% ERROR SENDING FLASH: Failed at address 00004000 ADSP device: \\?\usb#vid_0421&pid_0102#5&34522811&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} vid_0421&pid_0102 device not supported VPP is DISABLED. Phone is in: Phone is not responding, power on phone! %%%%%%%%%%%%%%%%% ABORTED FLASH %%%%%%%%%%%%%%%%%%%%%%%%%%%%% - Nokia Flash/Repair v1_36 Box: CR V 1.002 256 Code: NK V 1.001 1047 SN: Nokia Unlimited: times started SonyEricsson Trial: left, each max 15min VPP is DISABLED. Phone is in: Phone is not responding, power on phone! Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.71 MB]... erasing region [00000000 to 0000FFFF] ADSP device: \\?\usb#vid_0451&pid_9000#5&34522811&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} erasing region [00010000 to 006FFFFF] OK Inspect Supported Proceed.... Empty check: Not Empty Erasing Elapsed 10s Elapsed 10s Elapsed 10s Erase OK sw_dl_init : status o.k. sw_dl_end : status o.k. sw_checksum : status o.k. ADSP Flashing DONE erasing region [02000000 to 023FFFFF] erasing region [04000000 to 046B4FFF] in 197.00s Flash[17.91 MB]... Lower send speed for Bluetooth flashing BT Version: 22 Restoring to fast speed %%%%%%%% ERROR SENDING FLASH: Failed at address 00000164 - Nokia Flash/Repair v1_36 Box: CR V 1.002 256 Code: NK V 1.001 1047 SN: Nokia Unlimited: times started SonyEricsson Trial: left, each max 15min VPP is DISABLED. Phone is in: Phone is not responding, power on phone! %%%%%%%%%%%%%%%%% ABORTED FLASH %%%%%%%%%%%%%%%%%%%%%%%%%%%%% VPP is DISABLED. Phone is in: Phone is not responding, power on phone! Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.71 MB]... erasing region [00000000 to 0000FFFF] ADSP device: \\?\usb#vid_0451&pid_9000#5&34522811&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} erasing region [00010000 to 006FFFFF] OK Inspect Supported Proceed.... Empty check: Not Empty Erasing Elapsed 10s Elapsed 10s Elapsed 10s Erase OK sw_dl_init : status o.k. sw_dl_end : status o.k. sw_checksum : status o.k. ADSP Flashing DONE erasing region [02000000 to 023FFFFF] erasing region [04000000 to 046B4FFF] in 209.24s Flash[17.91 MB]... Lower send speed for Bluetooth flashing BT Version: 22 Restoring to fast speed %%%%%%%% ERROR SENDING FLASH: Failed at address 00000164 VPP is DISABLED. Phone is in: Phone is not responding, power on phone! Processing File: nem440.3c1 Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. - Nokia Flash/Repair v1_36 Box: CR V 1.002 256 Code: NK V 1.001 1047 SN: Nokia Unlimited: times started SonyEricsson Trial: left, each max 15min VPP is DISABLED. Phone is in: Phone is not responding, power on phone! %%%%%%%%%%%%%%%%% ABORTED FLASH %%%%%%%%%%%%%%%%%%%%%%%%%%%%% VPP is DISABLED. Phone is in: Phone is not responding, power on phone! Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.71 MB]... erasing region [00000000 to 0000FFFF] erasing region [00010000 to 006FFFFF] erasing region [02000000 to 023FFFFF] erasing region [04000000 to 046B4FFF] in 197.25s Flash[17.91 MB]... Lower send speed for Bluetooth flashing BT Version: 22 Restoring to fast speed %%%%%%%% ERROR SENDING FLASH: Failed at address 00004000 ============= Set Flash mode for info ============= Pins: Mbus 0, Box Tx 0, Box Rx 0, Bsi 1 Boot... Failed to boot RAP3 ( cable problem/damaged RAP3 chip/damaged phone power circuit ============= Set FBus mode for info ============= Pins: Mbus 0, Box Tx 0, Box Rx 0, Bsi 0 - Nokia Flash/Repair v1_36 Box: CR V 1.002 256 Code: NK V 1.001 1047 SN: Nokia Unlimited: times started SonyEricsson Trial: left, each max 15min Boot... WD2 BT2 w2_2nd.fia w2_amd.fia ASIC ID: 0082 Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA UEM IMEI is: 351521005 ============= Set FBus mode for info ============= VBat is 3.94V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Phone is not responding, power on phone! Phone is in: Phone is not responding, power on phone! Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.71 MB]... request erase [00000000 to 0000FFFF] request erase [00010000 to 006FFFFF] request erase [02000000 to 023FFFFF] request erase [04000000 to 046B4FFF] Waiting response for 300 Sec... ADSP device: \\?\usb#vid_0451&pid_9000#5&34522811&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} OK Inspect Supported Proceed.... Empty check: Not Empty Erasing Elapsed 10s Elapsed 10s Elapsed 10s Erase OK sw_dl_init : status o.k. sw_dl_end : status o.k. sw_checksum : status o.k. ADSP Flashing DONE in 126.00s Flash[17.91 MB]... Lower send speed for Bluetooth flashing BT Version: 22 Restoring to fast speed %%%%%%%% ERROR SENDING FLASH: Failed at address 00002000 - Nokia Flash/Repair v1_36 Box: CR V 1.002 256 Code: NK V 1.001 1047 SN: Nokia Unlimited: times started SonyEricsson Trial: left, each max 15min Phone is in: Phone is not responding, power on phone! Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.71 MB]... request erase [00000000 to 0000FFFF] request erase [00010000 to 006FFFFF] request erase [02000000 to 023FFFFF] request erase [04000000 to 046B4FFF] Waiting response for 300 Sec...in 126.19s Flash[17.91 MB]... Lower send speed for Bluetooth flashing BT Version: 22 Restoring to fast speed %%%%%%%% ERROR SENDING FLASH: Failed at address 00000164 - Nokia Flash/Repair v1_36 Box: CR V 1.002 256 Code: NK V 1.001 1047 SN: Nokia Unlimited: times started SonyEricsson Trial: left, each max 15min ============= Set Flash mode for info ============= VBat is 3.94V Vpp pin has 0.12V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Boot... WD2 BT2 w2_2nd.fia w2_amd.fia ASIC ID: 0082 Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA UEM IMEI is: 351521005 ============= Set FBus mode for info ============= VBat is 3.94V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Custom Erase Areas: 00000000 - 007FFFFF (8.000000 MB) Operation will continue aproximately 90 seconds, please wait... WD2 BT2 w2_2nd.fia w2_amd.fia Erasing: 00000000:007FFFFF Erase completed successfully in 98 seconds Custom Erase Areas: 02000000 - 027FFFFF (8.000000 MB) Operation will continue aproximately 90 seconds, please wait... WD2 BT2 w2_2nd.fia w2_amd.fia Erasing: 02000000:027FFFFF Erase completed successfully in 98 seconds Custom Erase Areas: 04000000 - 047FFFFF (8.000000 MB) Operation will continue aproximately 90 seconds, please wait... WD2 BT2 w2_2nd.fia w2_amd.fia Erasing: 04000000:047FFFFF Erase completed successfully in 107 seconds Phone is in: Phone is not responding, power on phone! %%%%%%%%%%%%%%%%% ABORTED FLASH %%%%%%%%%%%%%%%%%%%%%%%%%%%%% Phone is in: Phone is not responding, power on phone! Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Erase[17.71 MB]... request erase [00000000 to 0000FFFF] request erase [00010000 to 006FFFFF] request erase [02000000 to 023FFFFF] request erase [04000000 to 046B4FFF] Waiting response for 300 Sec... ADSP device: \\?\usb#vid_0451&pid_9000#5&34522811&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} ADSP device: \\?\usb#vid_0451&pid_9000#5&34522811&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} OK Inspect OK Inspect in 126.00s Flash[17.91 MB]... Lower send speed for Bluetooth flashing BT Version: 22 Restoring to fast speed %%%%%%%% ERROR SENDING FLASH: Failed at address 0000A000 - Nokia Flash/Repair v1_36 Box: CR V 1.002 256 Code: NK V 1.001 1047 SN: Nokia Unlimited: times started SonyEricsson Trial: left, each max 15min Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.71 MB]... request erase [00000000 to 0000FFFF] request erase [00010000 to 006FFFFF] request erase [02000000 to 023FFFFF] request erase [04000000 to 046B4FFF] Waiting response for 300 Sec... ADSP device: \\?\usb#vid_0451&pid_9000#5&3469dab1&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} OK Inspect %%%%%%%% ERROR ERASING: Failed at address FF000000 ============= Set Flash mode for info ============= Pins: Mbus 0, Box Tx 0, Box Rx 0, Bsi 1 Boot... Failed to boot RAP3 ( cable problem/damaged RAP3 chip/damaged phone power circuit ============= Set FBus mode for info ============= Pins: Mbus 0, Box Tx 0, Box Rx 0, Bsi 0 - Nokia Flash/Repair v1_36 Box: CR V 1.002 256 Code: NK V 1.001 1047 SN: Nokia Unlimited: times started SonyEricsson Trial: left, each max 15min Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Erase[17.71 MB]... request erase [00000000 to 0000FFFF] request erase [00010000 to 006FFFFF] request erase [02000000 to 023FFFFF] request erase [04000000 to 046B4FFF] Waiting response for 300 Sec... ADSP device: \\?\usb#vid_0451&pid_9000#5&3469dab1&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} OK Inspect Supported Proceed.... Empty check: Not Empty Erasing Elapsed 10s Elapsed 10s Elapsed 10s Erase OK sw_dl_init : status o.k. sw_dl_end : status o.k. sw_checksum : status o.k. ADSP Flashing DONE in 125.81s Flash[17.91 MB]... Lower send speed for Bluetooth flashing Restoring to fast speed>>>>>>>>>>>>>>>>>>>>>>>>GET STUCK IN HERE i decide to flash it with other box this is the log: 1st Boot Ok, WD2 STARSHIP, UPP: 0082 Fl0: 0x00000000-0x007FFFFF,0001257E,Amd 29BDS643GT Fl1: 0x02000000-0x027FFFFF,0001257E,Amd 29BDS643GT Fl2: 0x04000000-0x047FFFFF,0001257E,Amd 29BDS643GT Algorithm: s2_amd_b.fia, Ver: 4.57.0 Algorithm Ok, MSID: 84F8DF0135DB78FE162267356F Decoded MSID: 3E4EBAF7-000D29B5-A8000000 Encoded FAID: E5D36978-10DBB459-01DA7E49 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x006FFFFF Erased, Time: 01:16 Area3: 0x02000000-0x023FFFFF Erased, Time: 00:45 Area4: 0x04000000-0x046B4FFF Erased, Time: 01:21 BT MCM (26) Image Found: 22, 0x0002DD94 BT MCM Flashing Done, Time: 00:13 BT MCM Registering Done MCU Flashing Completed, Time: 03:47 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x04730000-0x047FFFFF Erased, Time: 00:11 Area3: 0x00700000-0x0075AFFE Erased, Time: 00:04 PPM Flashing Completed, Time: 00:14 Flashing Completed, Rebooting Mobile Set Full Factory Defaults Ok, Time: 00:57 User Area Format Ok, Time: 00:44 User Area Format Ok, Time: 00:45 User Area Format Ok, Time: 00:45 Init Normal Mode Ok, Time: 00:47 once just once!!!! and the phone NORMAL (just rokiiee BOX) Phone is in: Local mode Model: NEM-4 ( N-Gage) V 4.03/26-11-2003/NEM-4 (c) NMP. Production serial number SGB926536 Product code 0507871 Module code Basic production code 0507870 Flash code Order number Long production SN MCU SW V 4.03/26-11-2003/NEM-4/(c)NMP HW 0720 PCI UEM 8 UPP 130 RFIC 0300 DSP SS206-3.20 PPM V 4.03/26-11-2003/NEM-4/(c)NMP.98 BT MCM IMEI: 351521005 Phone is in: Local mode IMEI: 351521005 Generated RPL file from resource 208 C:\Program Files\Nokia\Phoenix\Products\NEM-4_351521005.rpl Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.71 MB]... request erase [00000000 to 0000FFFF] request erase [00010000 to 006FFFFF] request erase [02000000 to 023FFFFF] request erase [04000000 to 046B4FFF] Waiting response for 300 Sec... ADSP device: \\?\usb#vid_0451&pid_9000#5&34522811&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} OK Inspect Supported Proceed.... Empty check: Not Empty Erasing Elapsed 10s Elapsed 10s Elapsed 10s Erase OK sw_dl_init : status o.k. sw_dl_end : status o.k. sw_checksum : status o.k. ADSP Flashing DONE in 118.42s Flash[17.91 MB]... Lower send speed for Bluetooth flashing BT Version: 22 Restoring to fast speed>>>>>>>>>>>>>>>>>>>>>>>>GET STUCK IN HERE so.... GT, what is the problem here? |
09-04-2007, 06:25 | #4 (permalink) |
Member: 173199 Status: Offline Thanks Meter: 8 | yes it's work, i flash it with 1.29.5 and work normally. so.... this is kind of BUGS on 1.30 and above why GT not fixed it??? busy with their money i guess. not adsp failed but ngage flashing problem (get stuck on write mcu) this the log that i have flash it normally with 1.29.5: Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.71 MB]... erasing region [00000000 to 0000FFFF] ADSP device: \\?\usb#vid_0451&pid_9000#5&34522811&0&2#{958c1e51-94e6-4cb5-93ae-f7073d972797} erasing region [00010000 to 006FFFFF] OK Inspect Supported Proceed.... Empty check: Not Empty Erasing Elapsed 10s Elapsed 10s Elapsed 10s Erase OK sw_dl_init : status o.k. sw_dl_end : status o.k. sw_checksum : status o.k. ADSP Flashing DONE erasing region [02000000 to 023FFFFF] erasing region [04000000 to 046B4FFF] in 177.67s Flash[17.91 MB]... Lower send speed for Bluetooth flashing BT Version: 22 Restoring to fast speed in 94.78s * * Processed file in 289.47 seconds Processing File: nem440.398 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia w2_amd.fia 84F8DF0135DB78FE162267356FDA Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[1.23 MB]... erasing region [00000000 to 0000FFFF] erasing region [04730000 to 047FFFFF] erasing region [00700000 to 0075AFFE] in 13.41s Flash[1.23 MB]...in 6.17s * * Processed file in 35.25 seconds * * * Phone flashing done in 5:26 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 4.03/26-11-2003/NEM-4 (c) NMP. IMEI: 351521005 Factory Default Settings...OK Phone is in: Local mode Model: NEM-4 ( N-Gage) V 4.03/26-11-2003/NEM-4 (c) NMP. Production serial number SGB926536 Product code 0513929 Module code Basic production code 0507870 Flash code Order number Long production SN MCU SW V 4.03/26-11-2003/NEM-4/(c)NMP HW 0720 PCI UEM 8 UPP 130 RFIC 0300 DSP SS206-3.20 PPM V 4.03/26-11-2003/NEM-4/(c)NMP.98 BT MCM IMEI: 351521005 so thx mr Botya666 |
06-08-2008, 15:11 | #5 (permalink) |
Freak Poster Join Date: Feb 2008 Location: EL ghazi
Member: 697114 Status: Offline Thanks Meter: 15 | The solution is to remove (Erase) mcu +ppm and fash ok MTBOX: 00 - Nokia Flash/Repair v1_46 Box: CR V 1.002 256 Code: NK V 1.001 1048 SN: 00 Nokia Unlimited: 422 times started SonyEricsson Trial: 7 left, each max 15min Invalid erase end for User Arae 1 Invalid erase end for User Arae 1 Custom Erase Areas: Operation will continue aproximately 20 seconds, please wait... WD2 BT2 w2_2nd.fia w2_amd.fia Erase completed successfully in 15 seconds Custom Erase Areas: Operation will continue aproximately 20 seconds, please wait... WD2 BT2 w2_2nd.fia w2_amd.fia Erase completed successfully in 15 seconds VPP is DISABLED. Processing File: nem440.3c1 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia s2_amd_b.fia 84B310C8647C3E00BAAFC1084F51 Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.71 MB]... erasing region [00000000 to 0000FFFF] erasing region [00010000 to 006FFFFF] erasing region [02000000 to 023FFFFF] erasing region [04000000 to 046B4FFF] in 198.97s Flash[17.91 MB]... Lower send speed for Bluetooth flashing BT Version: 22 Restoring to fast speed in 98.17s * * Processed file in 315.41 seconds Processing File: nem440.379 Boot... ASIC ID: 0082 WD2 BT2 w2_2nd.fia w2_amd.fia 84B310C8647C3E00BAAFC1084F51 Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 257E 0002 0040, 10 02000000: Amd, 0001 257E 0002 0040, 10 04000000: Amd, 0001 257E 0002 0040, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA Erase[1.27 MB]... erasing region [00000000 to 0000FFFF] erasing region [04730000 to 047FFFFF] erasing region [00700000 to 00763FFE] in 13.94s Flash[1.27 MB]...in 6.33s * * Processed file in 37.19 seconds * * * Phone flashing done in 5:54 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 4.03/26-11-2003/NEM-4 (c) NMP. IMEI: 351521002644839 Factory Default Settings...OK Pooling mode for profile update... NEM-4\8418099.pp Sending Profile to Phone...OK Phone is in: Local mode Imei: 351521002644839 SIM Unlock Successfull |
Nokia 9500 ADSP Flash Failed ( NOKIA BLINKING ) | torpedo_seluler | Nokia Hardware & Hardware Repair | 1 | 06-18-2008 07:51 |
3300 adsp flashing fail | rajiv007 | Griffin | 2 | 01-15-2006 06:57 |
3300 adsp flashing fail with griffin | rajiv007 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 01-09-2006 20:23 |
Adsp Flashing??? | lemor | Federal One | 1 | 02-04-2004 14:23 |
help ADSP FLASHING? | lemor | Griffin | 0 | 01-21-2004 20:39 |
