Problem unlocking E65 V 1.0615.25/10-01-07/RM-208 (c) Nokia. IMEI: 353262010102811 Operator: 0100000000000000 Profile bits: 2680600000000000 Closed on GID1: 26806F Closed on Mcc Mnc: 26806F =================================== Using Account: funnybb583 Connect... Resp: o/0110/hello there Login... OK, available count 2560; busy, waiting... e/401/command execution error; Server error All is ok... version is fine... canīt understand server error |
may be you try to unlock it with revision=* dont need to have a any revision in griffin.ini |
tryed with revision=f cause i donīt want to loose logs.... but also tryed with no revision at all and still the same |
just unlock an E65 5 hours ago with revision=F. its free and ok. |
same flash as me??? can u please check? |
yes this version if free try to reflash phone on a same version and try again |
problem solved... many tks.. |
E65 unlocking problem strange problem i am facing this problem when i am ataching tp to E65 does not show any thing and i am sure attaching the tp ok...............please suggest me |
be sure, you don't touch good or touch wrong TPs . where is the log mate? we are not a magician |
