Server error when unlocking urgent help please!!!!! Hi i recently bought mtpro lite had trouble workingn it finally got it working now this Using Account: uMTPlite10604 Connect... Resp: o/0110/hello there Login... OK, available count 40; busy, waiting... e/401/command execution error; Server error ================================================== ==== what is the reason for that i took it back to my supplier and he logged in from his pc and internet connectionn to show me how it is used could that be the prob logging in from another place barred my account? could someone please help urgent response needed phones waiting to be unlocked. Regards DjinnSystems |
u r trying to unlock unsupported ver. mate download and read user manual http://www.griffinteam.net/gt_net/at...anual_v3.0.pdf |
it says in manual nokia 6300 v4.70 is supported that is what i am using on these phones |
ys same to me haveing problem with 6300 v4.70 always gettign error, and in the manual gt team says this versionis wuported. br... |
HI problem still persisiting this the log i am getting sing Account: uMTPlite10604 Connect... Resp: o/0110/hello there Login... OK, available count 40; busy, waiting... e/401/command execution error; Server error i tried adding the revision =F to my mtpro lite griffin .ini and it worked but when i attached the test points it quickly goes testpoint failed tespint failed testpoint failed testpoint failed tespint failed testpoint failed it did it 10 times and now says used up all the times i was able to unlock and it happed on 2 phones now i have 2 phones wich are fu**** and cant be unlocked again because of some dodgy server 401 error nokia 6300 v4.70 followed everythging and giving server 401 error added revision=f and i get 2 shafted phones any iadeas fellas Regards DjinnSystems |
Read phone info and post log here. |
here we go softmobile thanks for response and sorry about bad landuage earlier abvit vexed thats all. Also if you have used up all 10 tries is there a way round it please let me know thanks Phone is in: Test mode Model: RM-217 (Piccolo 900 ) V 04.70/24-01-07/RM-217 (c) Nokia. Production serial number KFP825491 Product code 0546930 Module code 0203166 Basic production code 0537040 Flash code Order number Long production SN MCU SW V 04.70/24-01-07/RM-217/(c) Nokia. HW 3003 PCI RFIC 17211721 DSP pb06w14v33 PPM V 04.70/24-01-07/RM-217/(c) Nokia. /C Retu 32 Tahvo 53 Content Pack Content: tmo_uk/V 04.70/24-01-07/RM-217/(c) Nokia. // IMEI: 35643601******* WARNING: VPP pin is not connected, disabling VPP. |
have you not set it to auto-backup field 308 before unlocking? if not you will need to buy a rpl to repair the sim data. also you have not posted full log. br |
well its my first day with this thing dont know what rpl is when it failed 10 times it did ask me to repair rpl data or something and if i clicked yes it would permenantly something scared the living daylights out of me so i decided to go with no. Now when i read phone info thats the info i get also where do i check to save this 308 data |
this is what i get after pressing unlock W 04.70/24-01-07/RM-217/(c) Nokia. Auto backup SIMLOCK... ================================= bb5bckup\356436016618668.pm nBackup file already exists! SKIPPING backup ================================= =================================== V 04.70/24-01-07/RM-217 (c) Nokia. IMEI: 356436016618668 Operator: 8000000000000000 Profile bits: 2343000000000000 Closed on Mcc Mnc: 23430F =================================== Using Account: uMTPlite10604 Connect... Resp: o/0110/hello there Login... OK, available count 40; busy, waiting... e/401/command execution error; Server error |
Hi i am getting the same problem on an 7373 - W 03.90/06-10-06/RM-209/(c) Nokia. Auto backup SIMLOCK... ================================= bb5bckup\353240018605779.pm nBackup file already exists! SKIPPING backup ================================= =================================== V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 353240018605779 Operator: 8000000000000000 Profile bits: 2343300000000000 Closed on Mcc Mnc: 23433F Closed on Mcc Mnc: 23486F =================================== Using Account: uMTPlite1023 Connect... Resp: o/0110/hello there Login... OK, available count 40; busy, waiting... e/401/command execution error; Server error please advise. intouchce |
is the server down ? |
i have the same problem with 6151 v4.10 W 04.10/21-12-06/RM-200/(c) Noki Auto backup SIMLOCK... ================================= bb5bckup\356297010945493.pm nBackup file already exists! SKIPPING backup ================================= =================================== V 04.10/21-12-06/RM-200 (c) Nokia IMEI: 356297010945493 Operator: 8000000000000006 Profile bits: 2140300000000000 Closed on Mcc Mnc: 21403F =================================== Using Account: uMTPlite10748 Connect... Resp: o/0110/hello there Login... OK, available count 40; busy, waiting... e/401/command execution error; Server error |
delete in grifin.ini revision F |
sorry can you explain that ? |
