Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 12-18-2009, 05:13   #1 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,162
New GENSX4 option supported models ???
MT has recently released GENSX4 option to repair superdongle key.. can anybody put a list which BB5 models are successfully repaired by this new function.
This will be helpful to all forum members..
The main queo is that whether old BB5 like N73, 6300, 6720 3110c etc are supported to repair SD key..
The Following 2 Users Say Thank You to zeel_zeel For This Useful Post:
Old 12-18-2009, 06:21   #2 (permalink)
Member: 310458
Thanks Meter: 94
iam try 6680,N70,N72 not support
Old 12-18-2009, 09:20   #3 (permalink)
Member: 160709
Thanks Meter: 4
N96 & E71 tested ok.
Old 12-18-2009, 16:02   #4 (permalink)
Member: 134930
Thanks Meter: 26
5200 tested ok.. N70 failled
so.. ??? not all type supported huh?
Old 12-18-2009, 16:04   #5 (permalink)
adriano II's Avatar
Member: 155242
Thanks Meter: 136
n73 95 8G and 5220 E71 done
Old 12-18-2009, 16:27   #6 (permalink)
Member: 107987
Sonork: 1575070
Thanks Meter: 14
e65 & 6131
tested ok
Old 12-18-2009, 19:23   #7 (permalink)
ttlin5188's Avatar
Member: 23253
Thanks Meter: 28
6120 C, N85 test good
Old 12-18-2009, 19:29   #8 (permalink)
ttlin5188's Avatar
Member: 23253
Thanks Meter: 28
The NOKIA model number of China N 95& N96 can't repair
Old 12-18-2009, 20:34   #9 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
5220,7210c,n96 all ok no problem
Old 12-18-2009, 20:40   #10 (permalink)
Member: 137489
Thanks Meter: 68
7210c,n96,e71 testet and are ok..
Old 12-18-2009, 20:47   #11 (permalink)
Thanks Meter: 4,071
Arrow i repaired 3250 SUCCESSFULLY
here is log:
Phone is in: Local mode
Model: RM-38 (3250)
V 04.60/14-09-07/RM-38 (c) Nokia.
Production serial number CGG571209
Product code 0526297
Module code
Basic production code 0516114
Flash code
Order number
Long production SN
MCU SW V 04.60/14-09-07/RM-38/(c) Nokia.
HW 1801
PCI
RFIC Š 17191719
DSP Š pb05w32v37_rm38
APE SW Core V 04.60/20-09-07/RM-38/
APE Variant V EURO1/30-06-06/RM-38
Retu 32
Tahvo 52
APE HW 256
APE ADSP SW 256
Camera 1028
IMEI: 357xxxxxxxxxxxx
WARNING: VPP pin is not connected, disabling VPP.
Operator: FFFFFFFFFFFFFFFF
Profile bits: FFFFFFFFFFFFFFFF
Closed on GID1: 00101F
Counters 0/10, 0/3
357xxxxxxxxxxxx
Searching loader
rap3gv3_2nd.fg
RAP3 Phone, Requesting...
Requesting service authorization from server...
busy, waiting...
Requesting code authorization from server
busy, waiting...
Computing...
busy, waiting...
Sending RPL...
C:\Program Files\GriffinTeam\MT-Box\rpls\357xxxxxxxxxxxx_sx4_sim.rpl
NO NPC CERTIFICATE!!!!
SKIPPED Certificate sent
============= Set FBus mode for info =============
VBat is 3.98V
Vpp pin has 0.12V, Not Connected
Pins:
Mbus 1, Box Tx 1, Box Rx 1, Bsi 0
Phone is in: Unknown mode
Model: RM-38 (3250)
IMEI: 357xxxxxxxxxxxxxxx
Delay one second.
Simlock send - SUCCESSFULL!!!
SuperDongle send - SUCCESSFULL!!!
Operator: 2440700000000000
Operator Name: AT&T;U.S.A. (3650)
Profile bits: 0000000000000000
Sim Status: Not locked
Procedure completed in 28 seconds
Trying box authorize
PMM Authorize SUCCESSFULL
PMM Send File
Operation Completed
The Following User Says Thank You to king.of.gsm For This Useful Post:
Old 12-19-2009, 08:21   #12 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
n73 95 8G and 5220 E71 .E66.N 95 CAN Repaired MT ??????????
Old 12-19-2009, 12:06   #13 (permalink)
kapilgupta's Avatar
Member: 681945
Thanks Meter: 422
here is the full detail for this service.. http://forum.gtibox.com/showthread.php?t=10960
this will clear all doubts..
Old 12-19-2009, 12:29   #14 (permalink)
Member: 62125
Thanks Meter: 4
helps pl is my log 3600 57.20 feld to read Phone is in: Test mode
Model: RM-217 (6300)
V 57.20/23-10-08/RM-217 (c) Nokia.
Production serial number DQA252538
Product code 0546425
Module code 0203166
Basic production code 0537040
Flash code
Order number
Long production SN
MCU SW V 57.20/23-10-08/RM-217/(c) Nokia.
HW 1000
PCI
RFIC 17211721
DSP ICPR61_08w10
PPM V 57.20/23-10-08/RM-217/(c) Nokia. /C
BT MCM 06cc-P9.1
Retu 32
Tahvo 53
Content Pack Content: c_red_sl2/V 57.20/13-01-09/RM-217/(c) Nokia. /
IMEI: 35xxxxxxxxxxxxxxxxx
IMEI: 351955038452215
Failed to Read
IMEI: 35xxxxxxxxxxxxxxx15
Failed to Read
Phone SelfTest status:
Passed: EAR_DATA_LOOP
Passed: SIM_CLK_LOOP
Passed: SIM_IO_CTRL_LOOP
Passed: SLEEP_X_LOOP
Passed: UEM_CBUS_IF
NotExecuted: KEYBOARD_STUCK
NotExecuted: CAMERA_IF
NotExecuted: BACKUP_BATT
NotExecuted: LPRF_IF
NotExecuted: LPRF_AUDIO_LINES
NotExecuted: CURRENT_CONS
Passed: RADIO
Passed: BACKLIGHT
NotExecuted: SIM_LOCK
NotExecuted: SECURITY
NotExecuted: BT_WAKEUP
NotExecuted: HOOKINT
Passed: TAHVOINT
NotExecuted: SLEEPCLK_FREQ
NotExecuted: BTEMP
NotExecuted: BT_SLEEP_CLK
NotExecuted: EXT_DEVICE
NotExecuted: CDSP_RF_BB_IF
NotExecuted: CDSP_RF_SUPPLY
NotExecuted: CDSP_TX_IQ
NotExecuted: CDSP_TXC_DATA
NotExecuted: CDSP_RX_PLL_PHASE_LOCK
NotExecuted: CDSP_TX_PLL_PHASE_LOCK
NotExecuted: CDSP_RX_IQ_LOOP_BACK
NotExecuted: CDSP_GSM_TX_POWER
Summary: Passed(8), NotExucuted(22), OtherStatus(0)
Boot...
Using Tx2 Data line.
Trying boot BB5 phone...
rap3gv3_2nd.fg
RAP3Gv3_algo.fg
BOOT OK...
Send NPC Certificate
Send HWC Certificate
Send CCC Certificate
RAP3 Certificate sent SUCCESSFULLY
VBat is 4.02V
Vpp pin has 0.10V, Not Connected
Pins:
IMEI: 35195xxxxxxxx
VBat is 4.03V
Vpp pin has 0.09V, Not Connected
Pins:
Delay one second.
Simlock send - FAILED!
IMEI: 35xxxxxxxxxxxxxxxxxx
VBat is 4.02V
Pins:
Delay one second.
SuperDongle send - NO DATA IN RPL!!!
IMEI: 351xxxxxxxxxxxxxxxx
VBat is 4.00V
Pins:
IMEI: 3519xxxxxxxxxxxxx
Delay one second.
Passed: UEM_CBUS_IF
Passed: RADIO
Passed: BACKLIGHT
Passed: TAHVOINT
NotExecuted: BTEMP
============= Set Flash mode for info =============
Boot...
rap3gv3_2nd.fg
RAP3Gv3_algo.fg
BOOT OK...
Phone Type: BB5
------------------- SYSTEM ID Response: 7 blocks -------------
SYSTEM_ASIC_ID( RAP ):
000000010000022600010006010C192101001101
EM_ASIC_ID( RAP ):
00000232
EM_ASIC_ID( RAP ):
00000353
PUBLIC_ID( RAP ):
231001094D367E5619D8770B11811BD2C1C34BF9
ASIC_MODE_ID( RAP ):
00
ROOT_KEY_HASH( RAP ):
BAF3A9C3DBFA8454937DB77F2B8852B1
ROM_ID( RAP ):
191EC665DFAAF68F
--------------- Device ID Response: 3 blocks -------------
Storage Device:
Owner Asic: RAP
Type: NOR Flash
Index: 0
Flash: Amd, 0001 0041 0000 6A21
Storage Device Contents:
Owner Asic: RAP
000000000000000000000000000000000000
VBat is 4.03V
Pins:
Mbus 1, Box Tx 1, Box Rx 0, Bsi 0
NO SERIAL COMMUNICATION WITH PHONE
NOT SENDING SIMLOCK AND SUPERDONGLE
CHECK CABLE!
VBat is 4.00V
Pins:
Boot...
rap3gv3_2nd.fg
RAP3Gv3_algo.fg
BOOT OK...
Phone Type: BB5
EM_ASIC_ID( RAP ):
00000232
EM_ASIC_ID( RAP ):
00000353
PUBLIC_ID( RAP ):
00
ROM_ID( RAP ):
191EC665DFAAF68F
Storage Device:
Owner Asic: RAP
Type: NOR Flash
Index: 0
Owner Asic: RAP
VBat is 4.00V
Pins:
IMEI: 351xxxxxxxxxxx5
VBat is 4.00V
Pins:
Delay one second.
Old 12-19-2009, 12:52   #15 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
I HAVE TESTED ON 5200,5300,7210c,5220 AND N95 ALL WERE SUCESSFULL
WBR
sahil2000ind
[MXKEY - INFO] F.A.Q of new update and Supported Models Umair Rashid MXKEY Nokia Flasher and Unlocker (by Alim Hape) 29 12-28-2010 16:15
20/01/10 New MicroBox Full Supported Models List check it samigsm78 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 0 09-10-2009 12:39
creat a new list of supported models HAMMZA_MOBILES Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 1 12-17-2008 14:45
>>> F1: New "Broken Arrow" DCT4 IMEI/ESN Changer SUPPORTED MODELS <<< RNC_EBM Federal One 9 03-07-2007 18:47
new U.S. phone model support rps13sh Blazer 9 12-02-2004 01:32
Page generated in 0.23707 seconds with 9 queries
