NON Siemens Brand (ODM Phones) Do you know that C62 is not a Siemens Manufactured !? here in this section we Throw all non Siemens-Benq related Threads like C62, CFX65, SF65, CL75, CL50, S40, U15, C30,Xelibri. |
10-14-2004, 14:07 | #17 (permalink) |
Freak Poster Join Date: May 2002 Location: CZECH Age: 45
Member: 11619 Status: Offline Thanks Meter: 1 | Problem witch flash recovery C62. write my FlashProgrammer 2.83 * Version 2.83 (Build 169) * Copyright (C) 2000-2003 Microcell Ltd Initializing... Uploading flash algorithm... Waiting phone restart... Uploading flash algorithm... Flashing failed. Unable to find flash settings (12304). |
10-14-2004, 15:57 | #19 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Recovery Flash is OK for me Recovery Flash completes in Just 3 seconds But Prob in Flashing Error Code 6 I still can't resolve it |
10-15-2004, 07:44 | #20 (permalink) |
Member: 11619 Status: Offline Thanks Meter: 1 | I have dead C62. At Recovery flash me FlashProgrammer 2.83 writes: * Version 2.83 (Build 169) * Copyright (C) 2000-2003 Microcell Ltd Initializing... Uploading flash algorithm... Waiting phone restart... Uploading flash algorithm... Flashing failed. Unable to find flash settings (12304). Please, what is that error the 12304 |
10-15-2004, 12:16 | #21 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: GSMHOSTING Age: 42
Member: 57652 Status: Offline Thanks Meter: 1,893 | Quote:
it's voltage problem you make sure that cable work xith 12v not 9v | |
10-15-2004, 13:07 | #22 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Cable is OK 2 days Before I Flash the Very Same Phone with the Original cable with 9V Supply Now all the Things are same Cable is also same Phone is also Same Power Supply is 12V , battery is Full Charged .... But still boot error Code 6 Phone is Dead I am in Deep Deep Trouble I don't have any Clue , what can i do ... |
10-15-2004, 17:46 | #23 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Baltchik,Bulgaria Age: 50
Member: 47236 Status: Offline Thanks Meter: 58 | there are two ways to revive your c62 first is to flash with higher version v26 or to downgrade to v16 and then again to v20 and phone will be ok but you need to crack your flasher, if you have not cracked yet |
10-16-2004, 07:53 | #25 (permalink) |
Member: 47236 Status: Offline Thanks Meter: 58 | check your email this is flash cracker your flasher must be on disk c: becouse cracker searched it directly to drive c: you can understand that you are cracked correctly flasher when you press menu "phone" on the flasher and there must be three fields on the first row 1"flash" 2"flash file" 3 "recovery flash" best regards |
10-16-2004, 14:37 | #27 (permalink) |
Freak Poster Join Date: May 2002 Location: Portugal Age: 42
Member: 12207 Status: Offline Thanks Meter: 2 | Free info... Create a new file if it doesn't exist in the folder you installed Flash Programmer, with the name FlashProgrammer.ini and add the following [Configuration] EnableExitCodeFeature=1 EnableDetectInvalidPackages=1 EnableFlashFileFeature=1 EnableSmartFlashing=1 EnableResetPhoneLock=1 Don't know what means some of those, but they are all internally found on software... Best Regards XARiUS |
10-18-2004, 08:30 | #28 (permalink) |
Member: 11619 Status: Offline Thanks Meter: 1 | * Version 2.83 (Build 169) * Copyright (C) 2000-2003 Microcell Ltd Initializing... Uploading flash algorithm... Waiting phone restart... Uploading flash algorithm... Flashing failed. Unable to find flash settings (12304). Please, what is that error the 12304 |
LG u8180 Dead after Full Flashing. Plz Help!! | citifone | LG | 12 | 11-06-2008 12:44 |
t610 dead after flash,pls help me urgent !!!! | ticoichip | Cruiser Suite | 1 | 06-23-2006 02:41 |
V400 Kept Reseting after Power ON . Plz help me Urgent | Aamir_Zia | Motorola P2k | 1 | 08-16-2004 20:20 |
5210 dead after flash PLZ help me | SeEbOy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-14-2002 16:41 |
