How to make an usb cable to flsh c62 I have two usb cables for c55 and cx65, how can I modify them to use for flashing c62 phones? Please help me, I need that solution. :) |
1 Attachment(s) You need modify usb cabel for serial !Put (-) from source 12 V in pin 2 cable and (+) , pin 9 !Run FlashProgrammer_V2.78.exe in xp or in 98 !Work ! |
I have a serial cable for c62, but I want to know how to modify the c55 usb cable to gain more speed in flashing and saving the 9v battery. |
but usb cable flashing for only 3 min |
I need for this solution too |
i dont think its possible to convert it to work with c62 flasher.. it only works with serial ports.. go luck anyway!! |
there is the solution use C55 USB cable 2pin - gnd 3-5pins short (Tx) pin3 for x5x,x6x series, pin5 for C62 4-7pins short (Rx) pin4 for x5x,x6x series, pin7 for C62 9pin - +U (9 - 12)V |
you can flash you C62 only for 3 minutes |
