NON Siemens Brand (ODM Phones) Do you know that C62 is not a Siemens Manufactured !? here in this section we Throw all non Siemens-Benq related Threads like C62, CFX65, SF65, CL75, CL50, S40, U15, C30,Xelibri. |
05-24-2007, 17:12 | #1 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Ukraine. Lviv Age: 43
Member: 19633 Status: Offline Thanks Meter: 13 | EF81 blank LCD, PCB HD problem have two EF81 wyth LCD problem - first, LCD work some times then go to gray. after some time agane work ok. Second - all time two LCD are grey. I try use LCD modul and PCD from good phone and now I knou thet problem is in phone HD. LCD and flat cabels, conektors are ok. thys two phones is totaly new, not used, no woterdamege, no drops. I try rehot PCB but not helps. Did somebody hav similar problem? Hove to fix it? Thenks/ |
06-04-2007, 13:37 | #3 (permalink) |
Junior Member Join Date: Sep 2006 Location: Good old Germany
Member: 354600 Status: Offline Thanks Meter: 3 | Hello ! There are many from this phones in the market ! I have 150 pieces of them ! All of them have blank display but works! Sometimes i change a resistor and the display works ! The resistor is near the Battery Conector and is black! On some Pieces this resistor is broken ! Sorry for my bad english ! WBR |
06-06-2007, 02:14 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: yes
Member: 420658 Status: Offline Thanks Meter: 211 | Please. Those of EF81 without IMEI are not frozen. Can someone check if u can write into memory? Simple Test. "Firmwareupdate" : Change SVN 58 into 59 or so... You need QXDM. Memory Viewer (F4) 0x01BC3620 (adress varies, here from SVN 58 (IP16)) Code: O'zapft is!000;EF81;58;KE_1433_17.0.16;P; O'zapft is!000;EF81;59;KE_1433_17.0.16;P; Example video attached. Thanx for trying. Last edited by adfree; 06-06-2007 at 13:07. Reason: mistype |
06-06-2007, 09:09 | #5 (permalink) |
Junior Member Join Date: Jun 2007
Member: 522886 Status: Offline Thanks Meter: 1 | Hi! I also bought one of them as back-up Try looking at the display from different angles, they DO display what they should but without backlights Maybe you can tell us by referring to the pics in <http://www.ef81.com/Bilder.1472.0.ht..._lzgallery_pi1[showUid]=153> which resistor and how you changed it! This would be great and really of help! Thankx a lot! |
07-13-2007, 11:11 | #8 (permalink) |
Member: 522886 Status: Offline Thanks Meter: 1 | I found out that sometimes a diode is even missing (in my case: V900 aka RB501V40 by ROHM Electronics). These may be hard to find if you're not a phone manufacturer Anyone having an idea where to get them in Germany? |
Nokia 1200 Blank LCD problem | alamgir80 | HWK | 6 | 09-30-2008 16:21 |
d600 upper lcd pcb kepad problem | raja1 | Samsung Hardware Repair | 0 | 06-06-2008 11:43 |
D600 keypad problem by LCD pcb??? | MaRiN | Samsung Hardware Repair | 6 | 06-06-2008 07:29 |
Blank Nokia PCB boards | Number 3 | Wanted Products | 0 | 06-07-2004 15:30 |
8210 blank LCD with good LCD and new | uwenk98 | Nokia Hardware & Hardware Repair | 5 | 03-19-2004 23:01 |
