please help me for this CF62.... please help me for this CF62.... i c'ant make flash file or write eeprome.........view log: Open file "E:\SIEMENS\SST\FLASH FILE\CF62\CF62_INTEL_FULLFLASH_V12\CF62_INTEL_FULL FLASH_V12.bin" for write in Flash. FullFlash file info: FlashID: 0089/8856 SIEMENS CF62 Sw12 lg4 RealLgPack: lg4 Start... Loading BootsModel(CF62)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 115200 BAUD: Ok. Warning: HASH data error! 7x7x 77 SwAB Soft FlashID: FDF0/B7EF (8FFA/FEEE) FlashID: B7EB/FDC8 Flash Size: 16Mb Region(1): Blocks 128, Size 64Kb EEPROM segments not found! FSN: 962DFCB4 -> PhoneID: B4FC2D96 Error IMEI in OTP! Warning: The software of the telephone does not correspond to FlashID! HASH: FBF7689FEFFAB6EDFBF7689FEFFAB6ED Error: EEP0067 not found! Error: EEP0076 not found! Error: EEP5005 not found! Error: EEP5007 not found! Error: EEP5008 not found! Error: EEP5009 not found! Error: EEP5012 not found! Error: EEP5077 not found! Error: EEP5093 not found! Error: EEP5121 not found! Error: EEP5122 not found! Error: EEP5123 not found! WriteFlash block at 0x000000 does not answer crc! i try withe all firmware but not solved......... Cf62_V07_lg4_fullflash cf62_v21.lg03_fullflash and i use jocker 0.3.5.6 please help me |
You tryed to fullflash using fullflash file for the Intel flash chip, but inside in your phone Soft flash ID is unkrown. So, rehot microcontroller and flash chip and try again (maybe you have bad contacts between the PCB pads and chipsets). See which flash you have inside (AMD or Intel) and after fullflash using fullflash file for this flash chipset. Use Joker and check only "ReCalc keys" in the Flash menu. dagos |
