NON Siemens Brand (ODM Phones) Do you know that C62 is not a Siemens Manufactured !? here in this section we Throw all non Siemens-Benq related Threads like C62, CFX65, SF65, CL75, CL50, S40, U15, C30,Xelibri. |
02-19-2005, 20:04 | #18 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: GEORGIA,Tbilisi
Member: 75765 Status: Offline Thanks Meter: 722 | Quote:
But it seems kind of overloaded.......try again BR | |
02-20-2005, 23:15 | #21 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | Thanks for links. Is that software supposed to start flashing automaticly when the power button is pressed shortly? There no reaction when i do it... I'm using THIS USB-cable, emulated as COM1. That should work, shouldn't it? Are there any way i can test communication? (any other software?) |
02-24-2005, 09:24 | #22 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Hungary Age: 48
Member: 36035 Status: Offline Thanks Meter: 8 | I have this problem with my ST60 as in the this erros message: Timeout Fail8: BS_PMC_PLAIN. Another solution is same with STTol Az STTol pedig power on the phone......OK Sending Boot.......Failed Toshiba_50VPF5782 chipset What can I do to flash my blocking phone? |
03-02-2005, 06:47 | #25 (permalink) | |
Junior Member Join Date: Dec 2004 Age: 47
Member: 97073 Status: Offline Thanks Meter: 0 | Can you do it? Quote:
Have u done flashiing with this cable? | |
03-03-2005, 16:52 | #26 (permalink) | |
Freak Poster Join Date: Jun 2004 Age: 48
Member: 70518 Status: Offline Thanks Meter: 21 | Quote:
Hollow my friend st-55 when i on the phone only be inspride whate I do thanks give replay siga | |
03-04-2005, 17:26 | #28 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | @privateGSM ... - Milano Backup Tool 4.1x .... do Clean User Data - Milano Switch Tool 4.1x ... do "ST55 -> Switch to neutral" - Milano Download Tool 4.1x ... do Full FLashing, MainFW+Map+LangPack all problems solved b.r. ALexandar |
03-04-2005, 17:33 | #29 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | @BB-GSM ... you should offer latest Milano Tools to board members ... and btw. if u are such a pro. who didnt you wrote how to edit .INI files in Milano tools, to make it working on USB or COM ports, and also how to remove other ports, and leave just COM1 or COMx ? here's attached .INI tool for Milano Downloader 4.1x with only one COM ... com1 ... and baud rate 230400 ... if u need special settings .... write a message here with requests ... (com port, USB or COM cable, customer name etc.) and i'll make INI file for you b.r. ALexandar. |
03-04-2005, 18:08 | #30 (permalink) | |
Freak Poster Join Date: Aug 1999 Location: Timisoara - RO
Member: 38747 Status: Offline Thanks Meter: 2 | Quote:
thanks and regards, ntt | |
UPDATE: 23 MAY 2005. Siemens ST55/ST60 flasher added | Infinity-Box | Infinity-Box | 10 | 04-28-2006 05:38 |
Quanta Calc - Panasonic A10x, X300, GD55, G5x, G70, Nec 101, 342i, Siemens ST55/60/50 | zulea | Panasonic (USB-Smart) | 0 | 04-03-2006 16:46 |
Quanta Calc - Panasonic A10x, X300, GD55, G5x, G70, Nec 101, 342i, Siemens ST55/60/50 | zulea | Others (USB-Smart) | 0 | 04-03-2006 16:44 |
Quanta Calc - Panasonic A10x, X300, GD55, G5x, G70, Nec 101, 342i, Siemens ST55/60/50 | zulea | Panasonic (USB-Smart) | 0 | 04-03-2006 16:43 |
