Siemens-Benq Flash Patching All about Flash patching/patches and Flash Modifications we can get it from here |
08-13-2004, 04:46 | #1 (permalink) |
No Life Poster Join Date: May 2004
Member: 66040 Status: Offline Thanks Meter: 14 | to Mr. rc-filtzer:Real answering machine question "BTW, is there already a way to create real answering machine? You have done "auto accept call", there is "start something at beginning call" (VWC from you, auto answering from vBartek and me), and we can play vmo files. The "tiny" problem is how to measure the time when the .vmo file ("Hi! I'm not there. Please tell the news after beep tone!") has finished and that we then can start recording..." How can i play vmo file when an incoming call starts? I am very interested in ansr machine because it is useful for me It's ok for me to record the whole incoming conversation including the vmo file played. do you have the patch for this? Thank you sir. |
08-13-2004, 14:53 | #2 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 60520 Status: Offline Thanks Meter: 0 | Hello charlielao! Please don't call me Mr., that sounds so serious... To your question: you can start vmo files as described in "Technical disucssion" thread on page 4. In combination with VWC patch (slightly changed) you can play a vmo file at start of incoming (and outgoing, sorry) call. Tell me, do you know how to create patches or is it just interest in having such a patch? So, with that feature it's only "tell the caller that I'm busy" feature but no real answering machine. We need to record the caller's voice. The problem is, when you're playing vmo file you can't start recording while it is playing (leads to phone freezing - you can continue calling but no key reacts anymore). That's the reason for urge to measure the time and configure after how many seconds (when vmo file is played until the end) you can start recording. Unless no one has a method to count the seconds or to check whether a vmo is still playing, we can't create answering patch. All in all: only possibilities are (auto answer feature recommended) 1. play absent message for caller or 2. record incoming call but without notifying the caller - no good solution. |
08-14-2004, 01:11 | #3 (permalink) |
Member: 66040 Status: Offline Thanks Meter: 14 | I'm a just very stupid newbie sir with a lot of questions and interests But im trying to find out how to learn to make patches. Ive seen a lot of "how to" webpages but a lot of them are either in russian or german but not in english. when i translate them, i cant understand them also hehehe. |
08-14-2004, 01:51 | #4 (permalink) |
Member: 66040 Status: Offline Thanks Meter: 14 | Sir, for the possibility of #1 play "im not here" vmo file, can you please tell me how to slightly change the VWC patch? I dont understand the TECHNICAL DISCUSSION thread Maybe its because im a lower being hehehe. Thank you for your time. |
08-14-2004, 08:20 | #6 (permalink) |
Freak Poster Join Date: May 2003 Location: Russia, Ekaterinburg Age: 44
Member: 29316 Status: Offline Thanks Meter: 0 | i try to play vmo file and after it's played record it's work ok, but i not know how make a pause for five or six second to wait for autoanswer greetig is played, if we not wait for this? phone freezeng if we try to record and greetings is not end of play. or how i can turn off playng grettings after five seconds for start record |
08-15-2004, 07:23 | #9 (permalink) |
Member: 29316 Status: Offline Thanks Meter: 0 | i write the auto answer machine patch but have trouble program not running after i call play vmo file until i not exit from play file, enybody know how i can exit form playvmo? my patch works if we mannualy exit from play file |
08-15-2004, 15:11 | #10 (permalink) | |
Member: 60520 Status: Offline Thanks Meter: 0 | @DeadManS: Quote:
Exit from playVMO... if we could check the running time or the numbers displayed on screen (0:00, 0:01, 0:02...) then it would be possible. Tell me, how does your method work (starting dictRecord after exiting playVMO)? | |
08-16-2004, 04:47 | #11 (permalink) |
Member: 29316 Status: Offline Thanks Meter: 0 | i find the second counter in ram and check it's in func called from VWC patch, VWC running in the loop when call in progress. i try run PlayVMO from another entrypoint (my old AutoRecord patch) and run record from riza VWC patch and write what i get check this address counter EQU 01BACAh it's counter started after call is satrted |
To Mr gsminfo any answer for this | div_859 | SMTi | 7 | 03-09-2010 23:30 |
MR ZULEA please answer my question | usman_ali | Nokia Base Band 5 ( BB-5 ) | 4 | 04-11-2009 12:48 |
mr zulea please answer a question | mecca | SonyEricsson (USB-Smart) | 4 | 05-18-2006 21:37 |
to mr julvir ...plz answer | elsamady-gsm | SwS_SaG_BoX | 10 | 05-03-2006 12:39 |
ANM. Answering Machine - some question | Pbrzuch | x1x to x45/x50 | 0 | 08-23-2004 10:32 |
