Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching
Siemens-Benq Flash Patching All about Flash patching/patches and Flash Modifications we can get it from here
Old 08-04-2004, 18:26   #1 (permalink)
Member: 44512
APS - Auto profile swaping - NOT WORKING
So...try do this test.
suppose:
Profile Normal = PN
Profile 1 = P1
profile swap from PN to P1 on 9PM
set on P1\Setup\Ringer setting\Beep - when P1 activate - icon Beep will be on screen
set on PN\Setup\Ringer setting\On - when PN activate - no icon...
then
set time to 8:59:30PM.... on screen no beep icon (OK - PN activate)
wait 30 second
profile swap, P1 is activated because Profile logo was changing....but on screen is no Beep icon .... why,
because profile really not swapping
only if You enter on Profile List, after this profile P1 will be activated, icon BEEP apear.....ect...
if in HPB You choose ring from profile f.e,36,37 - CB, the same history, after change profile to P1, Hourly Beep is from PN\CB ring
Question, where is bug
- in my phone (multi patching system in this function not working)
or in APS patch
Please try do this test.
ths
ps
Old 08-04-2004, 19:21   #2 (permalink)
trustkill's Avatar
Member: 27745
I use the APS Patch, it swaps the profiles....
Old 08-09-2004, 10:21   #3 (permalink)
Member: 44512
I trying again..
I put new clean flash...
- write 2 patches (code bellow) no conflict
-I set APP-Function 8 i 9 to enabled...
-I set in Profile 1 Ring settings - OFF (icon nosound on screen)
Auto profile swap on 20
I check which profile is enabled (menu\profiles) - NORMAL clock setting 17:00
now I set clock to 19:59:30 and I observe screen....
after 20, on screen not was icon (NO SOUND)
I check profile (menu\profiles) - and PROFILE 1 is set,
when I back on main screen ICON is apear
I check for call melody, before and after 20 ...
melody are changed after I in into setup\profiles
I try for my own clean SLIK, for "russion" SLIK, WINSWUP, and fls-sl45iv56.bin
same effect
So, APS patch not wotking fine, It change profile not quite...
PLZ help to resolve this "puzzle"
Who know how I can contact with author A_Alex ???
PLZ try on Yours SL
PS
;*** APP. New Setup->Application Menu for Patch Setting ***
;Firmware : SL45v56
;Author : RizaPN
;Release : November 8, 2003
;This patch will add new menu ("Application") under Setup, change the
;"Menu mode" item (the original ones is moved under this menu).
;This menu is used to modify some patches setting, such as : Display Invert,
;Flip Horizontal, Flip Vertical, Blank Screen, Animated Logo, Digital Clock,
;and Hourly Beep.
;After applying this patch, please REAPPLY these patches: Just Another Funny
;Display, Selectable Operator Logo, Blank Screen, and Hourly Beep (I did
;upload their latest version).
0x1A1E12: A101A201 9D089D08
0x1A1EC2: EA4ADC00 3ADEC700
0x4E402A: C3 C7
0x4E6A25: 09D718 09F503
0x4E6A28: A9B4051839520892 977F3667A69D0CD7
0x4E6A30: 259D45318A281CA5 25185C106B3D3986
0x4E6A38: 8C8F2DF697093A18 22AC0BD725185C10
0x4E6A40: C610F3A618C5DBCD 1397C96DAC09B925
0x4E6A48: 0CA74E105DA1A767 7E6A8E6D94880B7C
0x4E6A50: BC2224D78CB4FACC 0882AD8010323134
0x4E6A58: 18A928CD2D18C631 31099EDD89AC100F
0x4E6A60: BBD68C8FE4683DF8 A0E308E79B3D2591
0x4E6A68: 105E108409940352 54F608D7E56DC986
0x4E6A70: ACCC 1002
0x4E6B1A: 228586343DAD 08D7E56DC986
0x4E6B20: D5AD690918866737 102C09D7E56DC986
0x4E6B28: 101676095FDD5F67 10300709D7E56DC9
0x4E6B30: 6D3194E60EEB0D0D 8610303064D7E56D
0x4E6B38: BF67C32411E7 C98610305B10
0x4EA274: FFFFFFFF 09D7E56D
0x4EA278: FFFFFFFFFFFFFFFF C98610301409D7E5
0x4EA280: FFFFFFFFFFFFFFFF 6DC98610303C09D7
0x4EA288: FFFFFFFFFFFFFFFF E56DC98610306609
0x4EA290: FFFFFFFFFFFFFFFF D7E56DC986103021
0x27DE00: FFFFFFFFFFFFFFFF 0000000065000C00
0x27DE08: FFFFFFFFFFFFFFFF B00DE2029D08FF7F
0x27DE10: FFFFFFFFFFFFFFFF 0000000000000000
0x27DE18: FFFFFFFFFFFFFFFF 0000000000000000
0x27DE20: FFFFFFFFFFFFFFFF 063CEB02FC3BEB02
0x27DE28: FFFFFFFFFFFFFFFF 81000000DADEC700
0x27DE30: FFFFFFFFFFFFFFFF 0035370040363700
0x27DE38: FFFFFFFFFFFFFFFF 1100E6FCA101E6FD
0x27DE40: FFFFFFFFFFFFFFFF 1100EC00E6003700
0x27DE48: FFFFFFFFFFFFFFFF E6F11235E6F28436
0x27DE50: FFFFFFFFFFFFFFFF E6F447058841E064
0x27DE58: FFFFFFFFFFFFFFFF 8841E00488418841
0x27DE60: FFFFFFFFFFFFFFFF 884188C188C1E6F4
0x27DE68: FFFFFFFFFFFFFFFF EB028841E6F4223C
0x27DE70: FFFFFFFFFFFFFFFF 8841E6F4C7008842
0x27DE78: FFFFFFFFFFFFFFFF E6F408DF884246FC
0x27DE80: FFFFFFFFFFFFFFFF A1013D03E6FCA704
0x27DE88: FFFFFFFFFFFFFFFF 0D0546FCB3043D02
0x27DE90: FFFFFFFFFFFFFFFF E6FCC30808C106F1
0x27DE98: FFFFFFFFFFFFFFFF 240028D13DD90824
0x27DEA0: FFFFFFFFFFFFFFFF E6F4DC008842E6F4
0x27DEA8: FFFFFFFFFFFFFFFF EA4A8842FC00E00C
0x27DEB0: FFFFFFFFFFFFFFFF E08D88C028D13DFD
0x27DEB8: FFFFFFFFFFFFFFFF E6FD001EE6FE1F03
0x27DEC0: FFFFFFFFFFFFFFFF 88E088D0E6FD101E
0x27DEC8: FFFFFFFFFFFFFFFF 88E088D0E00DE00E
0x27DED0: FFFFFFFFFFFFFFFF DAE690EC06F01800
0x27DED8: FFFFFFFFFFFFFFFF DB00E00248E02D07
0x27DEE0: FFFFFFFFFFFFFFFF F02EBB0A60212D02
0x27DEE8: FFFFFFFFFFFFFFFF E0120D01E0228820
0x27DEF0: FFFFFFFFFFFFFFFF DAE748600802DB00
0x27DEF8: FFFFFFFFFFFFFFFF E01128214C12D740
0x27DF00: FFFFFFFFFFFFFFFF 0E00F2F2423ACB00
0x27DF08: FFFFFFFFFFFFFFFF 88C088D0DAE7AE61
0x27DF10: FFFFFFFFFFFFFFFF F024BBF25021D740
0x27DF18: FFFFFFFFFFFFFFFF 0E00F6F2423A98D0
0x27DF20: FFFFFFFFFFFFFFFF 98C0FAE7244AFFFF
;This patch is run with no problem under English Menu (only).
;If you are using another Language Pack, please modify these string ID in your language :
;... 1192 = 0x4A8: Invert Dsplay
;... 1193 = 0x4A9: Flip Horizntl
;... 1194 = 0x4AA: Flip Vertical
;... 1195 = 0x4AB: Blank Screen
;... 1196 = 0x4AC: Animated Logo
;... 1197 = 0x4AD: Digital Clock
;... 1198 = 0x4AE: Hourly Beep
;... 1199 = 0x4AF: Function 8
;... 1200 = 0x4B0: Function 9
;... 1201 = 0x4B1: Function 10
;... 1202 = 0x4B2: Function 11
;... 1203 = 0x4B3: Function 12
;... 2244 = 0x8C4: Function 13 (new string)
;... 2245 = 0x8C5: Function 14 (new string)
;... 2246 = 0x8C6: Function 15 (new string)
;... 2247 = 0x8C7: Function 16 (new string)
;using Skylord's Siemens_Language_Editor tools.
;locale=Polish_Poland.1250
AND
;*** APS+ABF Automatic Profile Swapping and Auto Backlight Function ***
;This patch add two functions to Application Menu
;Firmware : SL45v56
;Author : A_Alex
;Release : November 26, 2003
;This patch will add two new function in ("Application") under Setup
;Automatic Profile Swapping - this function automaticaly switching
;between Normal Evinronment profile and Profile 1 in define time.
;Default time for Normal Evinronment from 07:00 - 20:00 and
;time for Profile 1 from 20:00 to 07:00.
;Auto Backlight Function works with backlight similarly.
;Time then backlight is turned ON 17:00 to 08:00
;You must have RizaPN APP Patch for use this.
;After apllying this patch follow Main Menu->Setup->Application->
;Function 8 will be Auto Backlight.
;Function 9 will be Auto Profiles.
4E6A6A: 08D7E56DC986100218A92824 0C7CBBB754A36A2518345F22
4E6B1A: 08D7E56DC986102C 087CBBB768FFB067
3B36C6: 46FCFFFF DAE000C7 ; calls E0:C700 ; E0C700
40C700: FFFFFFFFFFFFFFFF 88C088D088908840
40C708: FFFFFFFFFFFFFFFF D7400E00F2F9423A
40C710: FFFFFFFFFFFFFFFF D7400D00F2FDDE25
40C718: FFFFFFFFFFFFFFFF 9AF90180BB0A9AF9
40C720: FFFFFFFFFFFFFFFF 0170BB1A98409890
40C728: FFFFFFFFFFFFFFFF 98D098C046FCFFFF
40C730: FFFFFFFFFFFFFFFF DB00E6FC030346FD
40C738: FFFFFFFFFFFFFFFF 14009D0446FD0800
40C740: FFFFFFFFFFFFFFFF 8D0150CCD7400D00
40C748: FFFFFFFFFFFFFFFF 42FC88242D04D740
40C750: FFFFFFFFFFFFFFFF 0D00F6FC8824CB00
40C758: FFFFFFFFFFFFFFFF E6003600CC00F3F8
40C760: FFFFFFFFFFFFFFFF F90A46FD02008D06
40C768: FFFFFFFFFFFFFFFF 66F404003D02DADE
40C770: FFFFFFFFFFFFFFFF 2617CB0046FD0100
40C778: FFFFFFFFFFFFFFFF 8DF766F404002D02
40C780: FFFFFFFFFFFFFFFF DADE3817CB00FFFF
;If You DON'T want use Auto Swap Profiles function UNCOMMENT next line
;40C71Ń: FFFF ŃŃ00
;If You DON'T want use Auto Backlight function UNCOMMENT next line
;40C722: FFFF CC00
;For Advanced users:
;If you want change time you must change one byte at address:
;40C738 - Time to activate Profile 1. Default value #14h (20:00)
;40C73E - Time to activate Normal Profile. Default value #07h (7-00)
;40C764 - Time to turn Illumination ON. Default value #11h (17-00)
;40C776 - Time to turn Illumination OFF. Default value #08h (8-00)
;Please remember time to activate Profile 1 MUST BE GREATER than
;activation time Normal profile, îtherwise this would be work incorrectly
;Similarly time to turn illumination ON must be greater then time to turn OFF
;Thanks to RizaPN for your GREAT work.
kg195 auto off auto keypad buton working, keypad not working .by guljee guljee786 LG Hardware Repair 4 01-23-2011 18:41
auto pinout not detect not working janki_amreli SpiderMan 0 01-19-2009 19:09
Symbian Guru Auto Profiles v2.00 S60v3 SymbianOS9.1 Unsigned ARABIC By Masters_PDA kululunl Nokia Multimedia 2 07-14-2008 03:55
Auto pin finder not working : Ver 2.20 zeel_zeel SpiderMan 12 04-18-2008 12:46
C200 saying headset profile, hence speAKEr not working PLS HELP silveraxe Motorola ODM 1 09-10-2005 12:54
Page generated in 0.21660 seconds with 9 queries
