Siemens-Benq Flash Patching All about Flash patching/patches and Flash Modifications we can get it from here |
11-01-2003, 12:18 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: EEPROM damaged Age: 44
Member: 15315 Status: Offline Thanks Meter: 1 | S55 v20 Java Class Verification -> Disable ; Java Programme starten schneller (getestet mit zwei S55 v20) ; Firmware : S55 v20 ; Author : RizaPN, SiNgle, ported to S55 by ACiD [mrp] ; Homepage: www.gsm-dev.com 5B4826: 3D 0D |
11-02-2003, 09:52 | #2 (permalink) |
Junior Member Join Date: Sep 2003 Location: Greece Age: 37
Member: 38609 Status: Offline Thanks Meter: 0 | after patched my phone with this, java opening about 30% faster! also the the patch that removes dialog to copy all entries on addressbook when changing sim works fine. I know that you can but if you you want can you make me a patch that removes the confirmation when activate/deactivate gprs? and something else:a patch to change softkeys in send menu like before (v16 and older versions)."group" at the left softkey and to choose from the addressbook at the right softkey. I hope it's not very difficult for you. thanks in advance. |
S55 v20 Flash Programming Header | Acidmrp | GSM Programming & Reverse Engineering | 3 | 11-18-2003 15:28 |
s55 v20 sl55 v14 with romanian | Ciubaka | E-Gold Based Phones | 2 | 11-02-2003 22:18 |
S55 v20 don't ask "Copy all entries..." | Acidmrp | E-Gold Based Phones | 0 | 11-01-2003 18:50 |
i need firmware for S55 v20 with lg4 | panchev | E-Gold Based Phones | 4 | 10-14-2003 18:46 |
S55 v20 String References | Acidmrp | GSM Programming & Reverse Engineering | 0 | 10-13-2003 19:22 |
