SME45i and Flexmem Hello, I have some easy (or not?) questions about Flexmem in SME45i. 1. How can I backup (small) Flexmem (348 KB) => then increase Flexmem by patch to (393,51 KB) => and then restore (small) Flexmem content into (big) Flexmem? (I've tried to saving flash from 0x140000 0x080000 bytes and restored this after increaseing => then Flexmem has 348 KB again. Using DES I had problems with "SMS-splitting" => ".smi, .smo, .txt"-problem!) 2. How can I convert .txt (on PC) to .smi or .smo for mobile? 3. Is there a possibility, to read out stored SMS (in and out) to pc without (automatic) converting to .txt? Hope somebody can help!? BR genetic1 |
1. No way to make it by cutting&pasting fw, you have to backup flexmem folders using DES and to restore them in Enlarged FlexMem 2 and 3.There are some programs, called something like, smo2txt and txt2smo, that can do this work |
Example: Before backup there is a file test.smi in phone => after backup there is a file test.txt on pc => after restore there are two files in phone "test_002_001.smi" and "test_002_002.smi" and text was splitted. Maybe one reason could be, that sms after backup with DES would be automaticly convert to.txt-file and after restoring again to .smi/.smo-file? But after all, there must be a possibility! Quote:
Thanks. |
adressbook (and other) backup is able throught SiMoCo http://www.mysiemens.cz/ms/simoco/ or you may able to open your adressbook files with r/w book or siemens offline adresbook extractor. in DES synch don't forget to unhide hidden dirs! Antoine [KNet] |
Uncheck "convert file" option in DES! |
@misko903 & Lalo: Quote:
EXACTLY THIS was my problem - now all probs are fixed about this topic! So many thanks for support! :) WBR genetic1 |
