Sound Volume Of Sx1 Anyone Knows A Way To Make The Sx1 Louder; |
what sw version do you have? You can patch phone to increase volume... |
I HAVE DOWNLOAD THE FIRMWARE "LAST UPGRADE OF SX1" FROM THE SITE WWW.SIEMENS-MOBILE.COM.DOES THIS MAKE A DIFFERENCE; |
we know :D ..................... |
does a upgrade realy help? gets the sx1 louder after flashing? i dont know which sw i had before but now i`ve got sw 12 but i can`t try it because my phone is still locked :-( im from germany and i have the sx1 music edition with the sw of o2. |
download a SERVICE update (winswup update...) of v15 and flash it! |
v15 for greece is not available.is there other way to make it sound louder; |
yes. use patch (winhex patch) to increase sound... |
Apply this to OFFICIAL V12 upgrade with vklay (select file of flash, then *.exe), then flash your phone 0F26AF0: 696E3D2031303636 696E3D2031373930 0F26AF8: 380D6E6F5F626971 390D6E6F5F626971 0F26B70: 303938340D6E6F5F 383434300D6E6F5F 0F26BE8: 3D2031313034370D 3D2031383534360D 0F26C60: 61696E3D20313132 61696E3D20313838 0F26C68: 31370D6E6F5F6269 33310D6E6F5F6269 0F26CE0: 31313334350D6E6F 31393034360D6E6F 0F26D58: 6E3D203131333731 6E3D203139303930 0F26DD0: 6761696E3D203131 6761696E3D203139 0F26DD8: 3434310D6E6F5F62 3230370D6E6F5F62 0F26E50: 2031313439360D6E 2031393330300D6E 0F26EC8: 696E3D2031313530 696E3D2031393332 0F26ED0: 380D6E6F5F626971 300D6E6F5F626971 |
it will be easier for you to use winhex patch, because you will not need to make test point as for V_KLay... // WinHex script [ .whs ], by Stefano G. // On WinSwup_service "Primary Memory" // * Previous SVN:15 Audio settings --> excellent SVN:15 Audio settings // I suggest to apply, the first time, an original WinSwup update, // then the patches with only "Core-Img (Z1)" flagged. // It's more safety , more fast and absolutely transparent for the // system ( no HardReset ). Goto 0x0 {Find 0x506F737444434C38303030 Down IfFound Move 19 Write 0x3137393039 Else JumpTo -Errors EndIf Find 0x506F737444434C3131303235 Down IfFound Move 20 Write 0x3138343430 Else JumpTo -Errors EndIf Find 0x506F737444434C3132303030 Down Move 20 Write 0x3138353436 Else JumpTo -Errors EndIf Find 0x506F737444434C3136303030 Down Move 20 Write 0x3138383331 Else JumpTo -Errors EndIf Find 0x506F737444434C3232303530 Down Move 20 Write 0x3139303436 Else JumpTo -Errors EndIf Find 0x506F737444434C3234303030 Down Move 20 Write 0x3139303930 Else JumpTo -Errors EndIf Find 0x506F737444434C3332303030 Down Move 20 Write 0x3139323037 Else JumpTo -Errors EndIf Find 0x506F737444434C3434313030 Down Move 20 Write 0x3139333030 Else JumpTo -Errors EndIf Find 0x506F737444434C3438303030 Down Move 20 Write 0x3139333230 Else JumpTo -Errors EndIf}[2] MessageBox " Speriamo bene !!! !!! !!! " JumpTo -NoErrors Label -Errors MessageBox " ATTENZIONE : patch NON applicabile !!! !!! !!! " Exit Label -NoErrors MessageBox " La patch è stata applicata !!! !!! !!! " ***** p.s. copy/paste this text above in blank text editor and save it as .whs how to use winhex patching, read here - http://www.siemens-mobiles.org/forum...ic=520.new#new |
the patch with vklay is applicable WITHOUT testpoint, you can apply it to ENTIRE UPGRADE FILE DOWNLOADED BY SIEMENS SITE, one time applied, you can archive the update file MODDED, no need to re-apply the patch if you want to re-flash (same file..) sorry 4 my english :D |
In fw15 the sound is louder than fws 12,13,14. I installed the International version of fw15 and now my phone is nearly %30 louder. |
If you cannot find your region's firmware than you can use URL http://www.sx1.org/dl/firmware/fw15/...ru_15_0001.rar to use the English-German-Russian version. (Like international) |
