a50 can't charge it is working but can't charge:D |
maybe you can give us a few more informations about your phone what happened to the phone ? dropped ? waterdamage ? ....... did you open it ? |
I opened it,no sign of water damage,i don't know what happened,customer said that maybe water damage,but I can't find any sign,now I try to clean it,I haven't service manual so I don't know what to do |
you donīt need a service manual for cleaning :D does the phone respond when you connect the charger ? |
no it doesn't respond,I didn't mean that I need manuals for cleaning,but for repair |
that was a joke ;) try to measure the voltage on the connector and on the battery contacts (pbc) |
what connector,explain |
I connect charger and battery,nothing happend,same voltage on battery connectors(4.2V),charger is ok,output voltage is 9.7V,what to do,do you have some shematics or you can help... |
Change FET-Switch V342 |
How can I find that switch,I don't have any shematics of main board(pcb) with element placement |
Try changing the battery |
try substituting switch v342 for a harder-to-wreack switch v3500... |
Try a alcoholbath! |
guy's I find that some "wire" is broken and I overbridge it,now I get charging but it is working maybe for 5s and then is of |
