Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2000 Location: uk
Member: 2899 Status: Offline Thanks Meter: 6 | "another sl45 problem" I connected my sl45 to all siemens3/4,pressed init mobile its been dead for few days now, heres what i have done so far, opened a donngle emulator(unisiemens) i get this message"one line is missing" run the programe, read flash from a working sl45, but always stops at 99%, but when i plug and unplug the cable it says 100%, i save the flash as a bin, then i read eeprom from the same working sl45, i save it as a bin again, then flush the eeprom and flash which was obtained from a working phone to the dead one,then i read it with the logger and save it, then i make a map and upload it with the imei writer, once it wrote it to the phone but the phone still dead, i kept trying to write to the phone again but sometimes it says bad data, sometimes it says writing imei and nothing happens , i have given up now, is there anything else i could do what r those error messages? please help, i am useless with siemens. BR farry |
![]() | #4 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2001 Location: [internet]
Member: 6877 Status: Offline Thanks Meter: 0 | Warning!!! Quote:
If unisiemens says about 99% and then stops your backup is CORRUPTED,do not use it!!!Please do not touch your PC while unisiemens works.Because ANY delays or swap activity caused by your action will cause some bytes to be lost.You backup will be incomplete then.Also it is a good idea to boost task priority for unisiemens... | |
![]() | #5 (permalink) |
Member: 2899 Status: Offline Thanks Meter: 6 | thanx masterros and sergay the emmu is running but it says one line is missing.and once the unisimense read the programm 100% still no joy ,the phone is dead, but the problem is when i want to upload the map it just says writing imei for a long time but nothing happens!!and the id is different in most cases!! has anybody else has this problem? BR farry |
![]() | #6 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2001 Location: Germany
Member: 6087 Status: Offline Thanks Meter: 0 | try this: ignore the message "one line is missing" and press okay, unmark the options "Reset Keypro" & "opimize Data" and enable the emulator again. doubleklick unisiemens.exe and wait 20 secs. now it will work properly ;-) trust me regardz Proggy |
![]() | #7 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Mar 2002 Location: neverland Age: 45
Member: 10507 Status: Offline Thanks Meter: 0 | same problem.. solved i have same problem 3 months ago. Now, my SL45 is working properly. send me log file, phoneID and full imei regards, `lavdate [email protected] |
550i "Another application is running close it and then start the camera" | pakmobiles | SETool2 | 3 | 05-21-2011 08:27 |
6300 Contact Service "Another Success Story" | etool30 | Universalbox | 2 | 05-31-2010 14:45 |
solution for camera K770 "Another application is running.Close, then start the camera | khassene01 | Sony Ericsson Hardware Repair | 4 | 05-20-2010 02:32 |
Z310 when camera open "another application running close that" | ganpath846 | SETool2 | 3 | 08-09-2008 05:53 |
a200 "lcd problem" | Moosani | Samsung Hardware Repair | 0 | 04-06-2003 00:00 |
