x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
09-15-2002, 04:01 | #17 (permalink) |
Insane Poster Join Date: May 2002 Location: Indonesia
Member: 12319 Status: Offline Thanks Meter: 0 | edmond: To make sure the Loader works, wait for 10 seconds AFTER the UniSiemens window has appeared. There will be an error message from the Loader if it can not patch UniSiemens correctly. The flashing box only indicates that it is ready to receive input from the user. This is a feature which comes from the UniSiemens, not the Loader. |
09-15-2002, 19:37 | #19 (permalink) |
Member: 12319 Status: Offline Thanks Meter: 0 | edmond: Make sure your cellphone is TURNED OFF before using UniSiemens. When "scanning..." with red light flashing, push the power button ONCE. You may need to press it again, but don't hold the button as you usually do to turn on the phone. |
10-08-2002, 20:46 | #24 (permalink) |
Junior Member Join Date: Sep 2002
Member: 15485 Status: Offline Thanks Meter: 0 | C45 You have luck !!! I have now my C45 repair by SAV .. now I can't read flash and eeprom .. no nothing c45 tool no unisiemens not ok winswup error connect bootstraploader ! Battery is emtpy Data cable ok .. ( only i can read general infos imei with cable and soft s35expl .. without read flash !) Help me |
10-09-2002, 11:41 | #26 (permalink) |
Insane Poster Join Date: Aug 2002
Member: 14395 Status: Offline Thanks Meter: 1 | I have also tried it and it does work. I used WinXP sp1 in compatibility mode. Read flash 100% ... no problems. did not have to remove battery. Read eeprom 100% ... but I had to remove the battery. Still, great work done. Now I have a backup of my phone, ... eeprom and flash. very cool! |
10-14-2002, 23:43 | #27 (permalink) |
Banned Join Date: Oct 2002 Location: Jl.Mawar merah 5 Blok D30 No.15 Bekasi Indonesia Age: 46
Member: 16434 Status: Offline Thanks Meter: 0 | Where I can download the full flash for cm 35 new verions suport indonesia language because i wan to try Unisiemens pls... give me ok! |
R26111VL_U_96A00ER not supported on the Boot-Loader V2 | s@lwos | Smart-Clip | 15 | 03-22-2010 18:23 |
I at the download firmware of the www.boot-loader.com speed very slow | ttlin5188 | Smart-Clip | 3 | 05-26-2008 15:52 |
HELP! LG7100 can not power on after running the photo loader. | southriver | LG | 0 | 12-27-2003 16:32 |
Question on UniSiemens loader code? | kxn | x1x to x45/x50 | 0 | 07-06-2003 06:33 |
