C35 Fully DEAD !!!! Hi I never seen something like this. That phone was killed by flashing and i don't know how but i cannot revive it. The WSWUP or any other program what is able to perform a flashing it hangs up after sending BOOTS nothing hapens. The wswup sends this error message "Unknown Char 00 received" and that's all. The battery is charged. The loggers they are stoping after pushing the Power On button and Sending Boot. please Help if you can :) Thanx |
reclean connector, may help |
Something else ? :) That's not the solution what i need :) |
I had the same problem,but cleaned connector and helped,try to set transfer speed lower,maybe helps... |
To MOKECKE Hey did you solved your problem, if yes how? I had the same problem with a35, and I think it is hardware problem, we need to rehoot flash chip. What you say? |
What worked for me Hi! If you e-mail me, I'll send ya progs with instructions to do a total flash an recovery. [email protected] |
just buy another ph! your cpu is damaged... bye! |
try flash with CM350501repair.bin file. If itīs software problem, this will revive your phone for sure. Download it here at my site: http://www.drug-store.wtcsites.com/SiemensPageCM35.htm If you canīt download it, Iīll sent it to you by mail. If you need x35 repair&flasher or All 3/4 to flash, itīs also for download: http://www.drug-store.wtcsites.com/SiemensPageFls.htm |
:confused: Hi. I've the same problem like you live before. My M35i battery seems full. After 2 days phone alerts that battery is empty. But battery indicator isn't changing. I've read the all forum pages. There is a tool that solves this problem. "Siemens battery sensor tools" and some "firmware" updates. If you have this utilities could you please send them to me? |
I recently unlocked my M35 (v16) wih ZeeSiemens, but then I had the battery problem. I then updated my phone to v25 with Freia, but it doesn't power on after that. However, I'm still able to flash the phone or access it with a service program. Does anyone still have the repair.bin that Drug_Store refers to? Thanks in advance. |
Hi, i have Freia 10, i can send. Email me |
M35i firmware hello all am desperately in need of siemens m35i firmware dead after trying to unlock via freia. regards |
