x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
10-19-2002, 20:53 | #2 (permalink) |
Member deceased !! Join Date: May 1999 Location: Wien/Austria Age: 65
Member: 5 Status: Offline Thanks Meter: 1,884 | here is how to modify your map file if you get the following error file is incorrect or havent i told you not to modify it this map has spaces at the end of each line of text we have to remove the spaces in some lines see below (if you highlite the whole text you will see what i mean) ******************** Section ******************** |remove this space ***************** ID: F7E75CD4 ****************** |remove this space ********** Old IMEI = XXXXXX-XX-XXXXXX ********** |remove this space ********** New IMEI = 350170-70-148101 ********** |remove this space ************************************************* |remove this space IMEI Block 00 [Siemens S45] |remove this space 0xFB 0xAC 0x52 0xAA 0xA8 0xED 0xF9 0x97 0xE0 0xFC IMEI Block 01 |remove this space 0x45 0xCC 0xFF 0xCF 0xEC 0xC2 0x5C 0x48 0x9F 0xD9 IMEI Block 02 |remove this space 0xD5 0x25 0x40 0x97 0x25 0x67 0x21 0x6D 0xA2 0x27 0x5E 0xAA 0x28 0xEF 0x92 0xC2 0x18 0x3B 0x01 0x61 0xA8 0x91 0x20 0x9A 0xC5 0xD3 0x79 0x33 0x53 0x39 0xDD 0x7F 0xED 0x21 0x50 0x6B 0x27 0x65 0x05 0x73 0xCC 0xAF 0xD9 0xC9 0x3E 0xEC 0xC3 0x9F 0x33 0x91 0xE3 0x8A 0xBF 0xEF 0xB4 0x63 0x71 0xD9 0x34 0xA3 0x55 0x10 0x99 0x67 0xEE 0x1C 0xFE 0x26 0x62 0x99 0xA1 0x94 0xE1 0xF2 0xD4 0x9F 0xDF 0xCF 0x09 0xBD 0xCA 0x6F 0xF7 0x28 0x37 0x79 0x39 0x30 0xD1 0xEC 0xC7 0xF1 0x1B 0xF8 0x43 0xB9 0x18 0x83 0xEC 0x90 0x82 0x2C 0x7B 0x5C 0x83 0x9F 0x6A 0x4B 0x79 0x2F 0x38 0x39 0x4E 0x52 0xB0 0x1A 0x87 0x79 0x80 0xCE 0x42 0x2D 0xC6 0xCE 0xAE 0xDB 0xCA 0xB4 0x9D 0x00 0x40 0x3F 0x58 0x9F 0xDF 0x9E 0x43 0x59 0x2B 0x5F 0xDC 0x25 0x85 0x29 0x43 0x87 0x2A 0x84 0xCD 0x9B 0x4E 0x97 0x09 0x22 0x44 0x8A 0xB4 0x8A 0x17 0xCD 0x18 0x2B 0xDC 0xE3 0x76 0x84 0xA4 0x84 0x34 0x4A 0x35 0xBF 0x30 0x3D 0x19 0xF8 0x4F 0x1E 0x2D 0xE3 0x92 0x90 0x95 0xD7 0xED 0x46 0xC2 0x35 0x64 0x12 0xE1 0xB7 0x45 0xB3 0x54 0x05 0xDD 0x41 0xE8 0x43 0xBA 0xEA 0xF4 0x3B 0x7F 0x4D 0x9C 0x98 0xC1 0x81 0xA0 0x47 0x06 0x68 0x44 0x14 0x87 0x0B 0x73 0xB1 0x2A 0x2B 0x7B 0x9E IMEI Block 03 |remove this space 0x85 0x31 0x00 0x5B 0x67 0x5D 0x55 0x73 0x7C 0x60 0xD7 0xC5 0x4F 0xA2 0x56 0x39 0xF8 0x0D 0xA3 0xDE 0x4F 0xA5 0xB2 0x06 0x89 0xC1 0xB3 0xF7 0xB0 0x31 0xB0 0x77 0xD3 0x1E 0x76 0x87 0x72 0xDA 0x29 0x3A 0x31 0x5D 0x1B 0x21 0x8A 0x1A 0x0C 0xFF 0xD6 0x99 0xA7 0x7A 0xF3 0xFB 0xDF 0x4B 0xC8 0xB2 0xAB 0xCA 0xE7 0xE9 0xA1 0x31 0x25 0xEE 0x21 0x97 0xF5 0xD9 0xA1 0x63 0x1B 0x8D 0x04 0xF7 0xA1 0x10 0xEA 0xD0 0x22 0x31 0xF3 0x85 0x9E 0x98 0x59 0x78 0x02 0x5F 0xA3 0x6F 0x2C 0xD5 0x3B 0x93 0x3A 0x9B 0xB3 0x14 0x45 0xC7 0xEC 0xBC 0xAF 0xCA 0xDE 0xC6 0x99 0xA6 0x68 0x71 0xF3 0xAD 0x60 0x7C 0x56 0x84 0xE8 0xA5 0x9E 0x54 0x94 0x8A 0xC9 0x2E 0x9D 0x60 0x04 0x9B 0x86 0x7D 0x63 0x9F 0x60 0xEE 0x56 0x65 0x3C 0x91 0xC2 0x53 0x42 0x5E 0x55 0x88 0x0D 0x8C 0xC6 0x64 0xD1 0x77 0x71 0xB6 0xC6 0x9E 0x97 0x13 0x94 0xA2 0x51 0x0F 0x6F 0xC9 0x6B 0xD6 0x88 0x61 0x5C 0xE6 0x47 0x2F 0xF2 0x8D 0xA7 0x9D 0x55 0xD5 0xCF 0x26 0xF0 0x32 0x59 0x53 0xAC 0x79 0xC6 0xF9 0xC0 0x0C 0x60 0xD2 0xB0 0xA6 0xED 0x8B 0x29 0xDB 0x25 0xC7 0x11 0x0B 0xB9 0x6C 0x60 0xC4 0xC6 0x4F 0xA0 0xC4 0xB3 0x17 0x7F 0x8B 0x14 0x15 0xED 0xA5 0x50 0x5E 0x2A 0xDD 0x04 0x60 0x22 0x9B 0x1B 0x56 0x9F 0x1F 0x53 0x49 ************************************************* |remove this space | you must have two blank lines at the end of the map | you must have two blank lines at the end of the map thanks to minder for his works wbr Winner 58 |
HELP ME PLS! i need the map for dead C45 | Oleg_W | Phone Unlocking Codes & Maps | 3 | 11-17-2002 14:22 |
please help with map c45 ba20 killed | aklishin | Phone Unlocking Codes & Maps | 1 | 11-12-2002 11:35 |
Please help for one C45 BA20 map .... | djanib | Phone Unlocking Codes & Maps | 2 | 10-18-2002 07:57 |
help me .... map c45 ba20 | CellM@n | Phone Unlocking Codes & Maps | 2 | 09-22-2002 17:53 |
Please help me with C45 and make me a map for this log C45 | comiter | x1x to x45/x50 | 0 | 05-24-2002 22:43 |
