x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
01-24-2002, 14:10 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Never Land
Member: 7277 Status: Offline Sonork: 100.42158 Thanks Meter: 68 | DEAD M35i v20...NEED FLASH FILE URGENT.... please help me asap............ thanks in advance.......... --------------------------- <br />kick butt first;<br />take names later <img src="frown.gif" border="0"> <img src="frown.gif" border="0"> <img src="frown.gif" border="0"> |
01-24-2002, 17:42 | #2 (permalink) |
Insane Poster Join Date: Jan 2002 Location: earth Age: 42
Member: 8906 Status: Offline Thanks Meter: 0 | To repair Siemens CM35 killed because flashing error, you need these software:<br />- Siemens Workshop v122 (all3x.com)<br />- SWUP.exe + 18xx.xbi or c3i_18xx.exe and repair_flash.bin<br />- ZeeSiemensG3.exe<br />- IMEIWriter.exe and Siemens IMEI MAP Maker.exe Then follow these steps:<br />01. Flash death Siemens CM35 with SWUP flasher 18xx.exe<br />02. Start Siemens Workshop 122, by run all3x.com<br />03. Open "repair_flash.bin" file, select only "EEPROM" and click on<br /> "Write Flash".<br /> If your phone not respond, choose "1.09 EG", remove battery, put it<br /> back and try again.<br />04. If Workshop says after flashing "Abnormal Termination" ignore this <img src="wink.gif" border="0"> <br />05. After flashing click on "CEE_Repair". (It will reset your IMEI) <br />06. Phone work <img src="wink.gif" border="0"> <br />07. Press *#06# on phone, you'll se IMEI 099999001234561<br />08. To turn back your IMEI to original, start "IMEIWriter.exe"<br />09. Turn Off your phone and connect it to data cable.<br />10. Go to "Logger" tab and select "Read phone" then press ON your phone.<br />11. Save all information by pressing "Save log" then exit.<br />12. Now start "Siemens IMEI MAP Maker.exe" then sellect "IMEI Change" tab<br />13. Press "Open log" and select the log file you have been saved before.<br />14. In "New IMEI" box, put your original IMEI number. (you can see it in<br /> the back of your phone)<br />15. Then press "Save MAP" and press "Write IMEI"<br />16. Your IMEI now back to original. to see it press *#06#<br />17. If you need, change language pack with SWUP flasher, ver. 18 or<br /> higher (the final flasher is ver. 21).<br />18. Now put on your sim card and turn on the phone. <br />19. If you cannot access your provider network, you need to unlock the<br /> the net-lock using "ZeeSiemensG3.exe"<br />20. Phone Work Like New! <img src="smile.gif" border="0"> Enjoy... |
Need flash file urgent pls | khokonhajigonj | Infinity-Box | 1 | 09-16-2008 10:24 |
Need flash file urgent | ameho0102 | Chinese Models & Cloned Phones | 1 | 09-11-2008 11:24 |
need flash file urgent PDA V13 | spnokia2008 | Infinity-Box | 1 | 09-04-2008 01:23 |
v525 dead need flash files urgent | vinay_sharma | Motorola P2k | 0 | 06-23-2007 14:51 |
need flash file urgent!!! | c0c0 | BF, BG, TH, BHx Series | 6 | 08-12-2004 15:55 |
