x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-04-2004, 20:21 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Moon Age: 43
Member: 55717 Status: Offline Thanks Meter: 47 | A50 v11 no testpoint Hello to all; I´m wanted to know somebody knows some sorts things out of unlocking the A50 v11 without use of the testpoint! If it exists it can happen the procedure because I am with some apparels for I unlock! I wait for answer and clues to I respect! Thankful! |
06-04-2004, 20:41 | #4 (permalink) |
Freak Poster Join Date: Nov 2003 Location: The upper limit Age: 40
Member: 44552 Status: Offline Thanks Meter: 3 | Man... Did u ever unlocked a A60 or C60 with testpoint??????? A55 testpoint is better to see , easier to cut ( more space ). Doing the cut it takes less than 1 min. I unlocked a60+c60+a55=>200 pcs with testpoint and i NEVER made a wrong cut. It takes just a little study and a steady hand. Good Luck!!! NeXuSGTS |
06-04-2004, 20:47 | #7 (permalink) |
Member: 44552 Status: Offline Thanks Meter: 3 | oops man..... YOU SAID A50?????????? I AM VERY SORRY. I HAVE BEEN REPLYING WITH A55 V11 SOLUTION!!!!! I AM REALLY SORRY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! OK......for a50 you can do a little trick. The testpoint is the same as v3,v4 ( old time solution ). The trick is : 1. You must put the testpoint contact to the GND. 2. The GND can be from the phone 3. Take a pense and insert it downside the number "1" keypad , the other side must touch the display metal contact case. 4. Unlock it with freia. No need to open phone, just make this contact. Good Luck!!! NeXuSGTS P.S. : sorry again for my first faulty reply. |
06-04-2004, 20:51 | #8 (permalink) |
Member: 44552 Status: Offline Thanks Meter: 3 | Crew and Bugytech i apologised because i did understand wrong the siemens model. Then i gave good solution. Regards, NeXUSGTS P.S. : Bugytech , please msg me with your phone number , i wanna talk bussines with you. |
06-04-2004, 21:42 | #10 (permalink) |
Member: 55717 Status: Offline Thanks Meter: 47 | Hi guys, would know where it could find pictures regarding the process in case they exist, it would be only to consist! It is at once very fought by the answers, I will be testing the method today still and I will post here! 10x |
06-13-2004, 23:22 | #12 (permalink) | |
No Life Poster Join Date: Oct 1999 Age: 48
Member: 4201 Status: Offline Thanks Meter: 6 | Quote:
Http://www.ALFAMOBIL.ro/download/Test Point.rar best regards, Irinel | |
A50 v11+ Testpoint Solutions | ednacell | x1x to x45/x50 | 0 | 10-16-2004 03:06 |
testpoint SIEMENS A50 V11 | eerfaan | x1x to x45/x50 | 6 | 06-19-2004 13:38 |
Siemens A50 v11 ... impossible ?!?! | Brka | Siemens-Benq RingTones and WallPapers | 22 | 12-12-2003 18:28 |
how to unlock A50 v11? | Tina_sk9 | x1x to x45/x50 | 12 | 12-12-2003 11:22 |
A50 dead with no testpoint What are my options ? | jerrel | x1x to x45/x50 | 4 | 08-14-2003 16:50 |
