Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 05-19-2009, 14:14   #16 (permalink)
mkwatis's Avatar
Member: 22893
Sonork: 100.1607086
Thanks Meter: 131
@dagos
I HAVE T830, AFTER HARD RESET DISPLAYS "PHONE LOCK" "Please enter phone codes" how to do it help please,even pm me
Old 09-06-2009, 21:00   #17 (permalink)
Member: 1113556
please unlock me Loox T810...
Old 09-26-2009, 19:00   #18 (permalink)
Member: 1127471
Thanks Meter: 6
Very nice ty
Old 11-07-2009, 10:31   #19 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 906
Seems That This fone has not yet any solution to unlock,,bcoz i searched every forum but could not succeeded,,Any way trying to find the solutions then let u know all,,
Old 01-24-2010, 12:50   #20 (permalink)
Member: 155186
Sonork: 100.1590978
Thanks Meter: 39
still no solution for this Phone?
Old 02-23-2010, 16:54   #21 (permalink)
Member: 1033679
Sonork: 100.1606747
Thanks Meter: 23
t830
hi guys
put me in line also
fujitsu-siemens_pocketloox_t830 ...........
hard reset it and now user code ......
no solution in any forum........
need some guines mindes over here also ....
The Following User Says Thank You to mrafghanistan For This Useful Post:
Old 08-03-2010, 22:08   #22 (permalink)
Member: 1359768
Sonork: asd
hey guys! I found the solution! In your pocket pc, in programs you will find : phone lock options. You will disabled phone lock.
Old 09-04-2010, 16:24   #23 (permalink)
anowar_virus's Avatar
Member: 1024090
Thanks Meter: 1,175
Soft reset (warm start)
After certain applications or the installation of new programs, it may be necessary
to restart the Pocket PC with a soft reset.
Unsaved data will be lost. Shut down all programs before you restart the Pocket-PC.
  1. Slide off the battery cover from the Pocket PC.
  2. Press the stylus tip once into the soft reset opening (1).
  3. The warm boot is carried out.
Cold starting and restoring factory default settings
Hard reset
If your Pocket PC stops working and switching off and on with the End button and the soft reset is
unsuccessful, you can perform a cold start with your Pocket PC or restore the factory default settings.
Unsaved data will be lost. Only carry out a cold start and reset
when the battery is fully charged.
  1. Slide the battery cover from the Pocket PC.
  2. At the same time press and hold the End button (1) and press the tip of the stylus pen into the soft reset opening (2).
  3. Release the End button as soon as a list of possible options is displayed on the screen.
  4. Select Skip if you would like to perform a normal cold start.
  5. To restore the Pocket PC to the factory defaults select Factory Defaults.
The selected option is performed.
It may take a few minutes for the factory defaults to be restored. At the end an acoustic signal sounds. Please follow the further instructions on the display.
The data memory is deleted when the Pocket PC is restored to its factory
defaults. This means: you will lose all data (documents, additionally installed programs, personal settings) that you haven’t saved elsewhere. Always back up your data on a regular basis (memory card, FSC Backup).
If you have set a password using FSC SecureLock then this password will be retained.
The Following User Says Thank You to anowar_virus For This Useful Post:
Old 07-22-2013, 16:24   #24 (permalink)
Member: 1983982
what the heck is the telephone code of the T830
I know, it's quite oldschool but I still use the FujitsuSiemens Pocket loox T 830 and it worked fine all the years.
Today, I took out the sim-card, inserted another SIM - no problem. But after putting back in the original one and entering the PIN, the phone suddenly demands a telephone code.
In this thread, some people had the same problem and DRAGO seemed to be able to help with a PM. Is anyone around who knows what to do or where to find this frigging code?
Thanx already now
Markus
how to Fujitsu Siemens T830 unlock turkcellgsm HTC & Smartphones ( WM Without Touch) 2 01-22-2010 20:02
Fujitsu Siemens Pocket LOOX T830 Unlock code need DemnZ Phone Unlocking Codes & Maps 0 09-08-2009 16:59
Fujitsu Siemens pocket loox T830 moji_baba Siemens Hardware Repair Area 3 06-24-2008 09:07
Fujitsu Siemens T830 unlock ? Patrick JAFWM 0 05-02-2007 00:15
fujitsu siemens boot passwd ? *MaTeOoSh* Off Topic Zone 3 01-13-2004 08:45
Page generated in 0.21222 seconds with 9 queries
