x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
07-12-2003, 04:25 | #1 (permalink) |
Crazy Poster Join Date: Jul 2003 Location: Recife - PE - Brazil
Member: 33208 Status: Offline Thanks Meter: 0 | A50 IMEI Locked ????? COMM_LoadBoots : selected phone family is 7 TTY_OpenCOMPort : opening COM1 COMM_IsBootRunning : bootcode does not seem to be running COMM_LoadBoots : Waiting to power on the phone ... COMM_LoadBoots : phone is powered on COMM_LoadBoots : internal loader version is 00.02 COMM_LoadBoots : original IMEI is 12345600123456 COMM_LoadBoots : flash IMEI is 35044610014024 (locked) COMM_LoadBoots : found SIEMENS A50 lg1 v7 (1) COMM_LoadBoots : flash ids are 008988C4 [00000000] - C489 COMM_LoadBoots : phone ids are EFF196AB [EFF196AB] O.K. Why the flash IMEI is locked? How can I unlock it? |
07-14-2003, 02:26 | #2 (permalink) |
Member: 33208 Status: Offline Thanks Meter: 0 | The phone is OK now. I rebuild the bootcore with c55.exe software and flash it with an old version of firmware. The original IMEI is OK now, but the flash IMEI is still locked. Any idea to unlock it? COMM_LoadBoots : selected phone family is 7 TTY_OpenCOMPort : opening COM1 COMM_IsBootRunning : bootcode does not seem to be running COMM_LoadBoots : Waiting to power on the phone ... COMM_LoadBoots : phone is powered on COMM_LoadBoots : internal loader version is 00.02 COMM_LoadBoots : original IMEI is 35044610014024 (B) COMM_LoadBoots : flash IMEI is 35044610014024 (locked) (/B) COMM_LoadBoots : found SIEMENS A50 lg5 v4 (1) COMM_LoadBoots : flash ids are 008988C4 [00000000] - C489 COMM_LoadBoots : phone ids are EFF196AB [EFF196AB] O.K. |
07-15-2003, 05:27 | #4 (permalink) |
Member: 33208 Status: Offline Thanks Meter: 0 | Yes. The phone is working ok. You just neet to put the same IMEI in EEPROM like the IMEI of Flash. More instructions: The free A50 Siemens ****er erases the bootcore from the phone, that's why it is impossible to repair phone with SWUP. (The A50 architecture uses the CPU in external boot mode.) To solve the situation follow these steps: -start the attached 55.exe program -go to flashing, select r/w full flash chip, click on OPEN and load the attached bootcore.bin file -flash the phone (use testpoint); after 20000 bytes program will report an error. -Your phone is now alive, but without language. To fix this, run any SWUP (preferably not lower version than the original SW) and flash the phone. Skip pre-check to avoid error message; for this operation no testpoint is needed. But i donīt remember where i download the c55.exe file (A50 & C55 Wizard, version 3). Try in www.gsmstrasbourg.fr.st The flasher files you can find in http://eh.student.utwente.nl/~landy/ (user=mobile, pass=elibom) |
a50 phone locked please turn off ! | ACE_UK | x1x to x45/x50 | 2 | 06-26-2004 11:50 |
A50 v3 locked to O2.. I can't unlock it. | DrMobile | x1x to x45/x50 | 18 | 03-29-2003 22:33 |
A50 phone lock | zoki | x1x to x45/x50 | 3 | 03-13-2003 08:20 |
unlock a50 network lock phone disable | Moosani | Phone Unlocking Codes & Maps | 3 | 03-07-2003 00:20 |
A50 user lock | pakman99 | x1x to x45/x50 | 1 | 03-02-2003 13:28 |
