Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 07-08-2004, 11:12   #1 (permalink)
Member: 72159
Thumbs down C45 -> Unblocking -> Dead -> ???
hi everybody,
I have a C45 and tried to unlock it some days ago with some #*?%§"!-software...
Now I have a phone that does not start anymore, instead it sounds a low pitched beep if you press the ON-button and that's all.
I tried to flash the phone, first using an original siemens cable and after recognizing my error with a modified siemens cable (external +5V power supply to pin 1 & 4) and tried again - without success.
Attempts to charge the phone are accopanied by an even lower beep.
Any hints you can give me are most welcome.
Thanks, grazer
Old 07-08-2004, 11:18   #2 (permalink)
steva's Avatar
Member: 4772
Thanks Meter: 556
use freia10 software to full flash your phone and after that use option unlock with using orginal imei.Use standard siemens cable or solution by bruce.
regards
Old 07-08-2004, 14:30   #3 (permalink)
Member: 72159
All the software I tried, is not able to make a connection to the phone.
If you press the red button shortly, nothing happens, if you press it for 1 sec. you will hear that low beep and nothing more.
Any hints regarding the cable? Is the supply voltage of +5 needed?
Thanks, grazer
Old 07-08-2004, 16:30   #4 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
are u sure ur battery is charged ?
WBR
Syed
Old 07-08-2004, 17:12   #5 (permalink)
DeltaGSM's Avatar
Member: 65947
Thanks Meter: 135
read eeprom from other phone with FREIA, then upload to dead phone.
regards
DeltaGSM
Old 07-08-2004, 23:20   #6 (permalink)
Member: 72159
Do you need a 100% charged battery to flash the phone or does it also work with say 85% capacity?
Can you also tell me if the behaviour of the phone is normal for an error in the flash memory (1 beep and nothing more if you trie to switch it on)?
Bye, grazer
Need help ==> Unblock Sony T303 FrenchLolita Phone Unlocking Codes & Maps 9 07-29-2009 10:48
Need help ==> Unblock Sony T303 FrenchLolita Sony Ericsson 1 07-15-2009 06:06
6280 v3.81 --> dead --> v6.10. Finally worked! langnese Nokia Base Band 5 ( BB-5 ) 9 05-27-2007 14:42
R210s dead --> burned smd Blu3fish VLSI, Conexant, Skyworks and Old Models 2 06-25-2003 08:11
Page generated in 0.15626 seconds with 9 queries
