x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
07-03-2002, 02:03 | #1 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Moscow, Russia Age: 47
Member: 6653 Status: Offline Sonork: 100.1597550 Thanks Meter: 26 | SL45 - EEPROM data damaged |
07-03-2002, 02:40 | #2 (permalink) | |
No Life Poster Join Date: May 2000 Location: Russia Moscow Age: 59
Member: 1408 Status: Offline Thanks Meter: 39 | Re: SL45 - EEPROM data damaged Sorry to rest members , just some words in russian Õîðîøèé ó òåáÿ íèê , ñï-ËÎÕ .. WBR Crew Quote:
07-04-2002, 04:54 | #7 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Hungary Age: 47
Member: 3097 Status: Offline Thanks Meter: 30 | Hi! I had the same problem a few days ago and I solved it: Just use All 3/4 Siemens 2.5 cracked by Xak, and loadthe .flx file then mark writw flash, write IMEI, Burst mode, them click on Init mobile. eeprom area will be ok, IMEI will be ok, then phone will turn on just for a second. After this you need to upload a MAP file to the phone and thats it!!! This is working 100% |
07-04-2002, 14:07 | #8 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Burj AL Arab --- DUBAI Age: 42
Member: 6837 Status: Offline Thanks Meter: 5 | Hi sp-lox, i had the same problem with SL45 , I USED THE MAPPER , but it gave error ËEPROM DAMAGED" then i FLASHED the phones with ALL 3/4 by PRO after flash the phone switched on ! i repaird 4 SL45 by this method BEST OF LUCK Best Regards |
07-07-2002, 03:29 | #12 (permalink) |
Junior Member Join Date: Jun 2002 Location: The Netherlands Age: 41
Member: 13113 Status: Offline Thanks Meter: 0 | Could somebody Send me a s45 flex file... [email protected] |
07-07-2002, 05:25 | #13 (permalink) |
Freak Poster Join Date: Dec 2001 Location: JavaLand
Member: 7743 Status: Offline Thanks Meter: 0 | Here All Flx flash : http://www.odblokgsm.sk/download/ |
07-07-2002, 12:21 | #15 (permalink) | |
Insane Poster Join Date: Apr 2002 Location: someplace
Member: 11033 Status: Offline Thanks Meter: 0 | Re: Here Quote:
eeprom data damaged | marici24 | x1x to x45/x50 | 10 | 06-17-2002 21:02 |
SL42e EEPROM data damaged | KATOUE | x1x to x45/x50 | 9 | 06-07-2002 05:53 |
S40 EEPROM data damaged | Jebek | x1x to x45/x50 | 7 | 05-28-2002 06:25 |
what is the solution for EEPROM data damaged | Sher | x1x to x45/x50 | 6 | 03-24-2002 07:48 |
eeprom data damaged? What can i do? | Proggy | x1x to x45/x50 | 6 | 01-16-2002 14:39 |
