x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
01-04-2003, 16:31 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: ME
Member: 8400 Status: Offline Thanks Meter: 0 | imei change on s45 ? with best regards , NNN |
01-04-2003, 17:45 | #2 (permalink) |
Member deceased !! Join Date: May 1999 Location: Wien/Austria Age: 65
Member: 5 Status: Offline Thanks Meter: 1,884 | Hi make log with reader 4.03 and type in Imei what you wish. post this log in "logfile-requests" anyone will make you a map. write this map with the same logger in your phone. now its unlocked and imei-changed. |
01-05-2003, 00:44 | #3 (permalink) |
Junior Member Join Date: Nov 2002
Member: 18294 Status: Offline Thanks Meter: 0 | I have changed S45 IMEI by the SM45Tools programm. It is easy. You need a service cable and the phone must be off when connecting to the computer. Then you start the program, select the type of phone (S45), the COM port where your phone is connected, and then you have to type in the new IMEI, press Unlock and then shortly press the "red" button on your phone (so shortly that the phone does not switch on). Done. |
01-06-2003, 19:16 | #5 (permalink) |
Major Poster Join Date: Aug 2001 Location: Europe
Member: 5877 Status: Offline Thanks Meter: 0 | Yes, SME45Tools12.exe, it is downloadable from www.gengheraenga.net SIEMENS section. If it ask for pswd, just use my one, Username: dk-1 , Password: 77289 . Good luck! |
IMEI Change on E800 - Do i also need to change the Bluetooth ID? | gaz_0001 | SYSOL Platform | 3 | 05-11-2005 23:44 |
IMEI changing on the EEPROM | Ice Dragon | Nokia Hardware & Hardware Repair | 5 | 06-12-2001 10:16 |
Imei change on C35 | kick | x1x to x45/x50 | 1 | 04-02-2001 09:08 |
IMEI change on 8210 & 8850 | Craig | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-11-2000 13:25 |
IMEI change on the 16xx | Comic | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-01-1999 17:12 |
