Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 06-16-2003, 14:27   #1 (permalink)
Member: 27689
Pls help me my siemens c-35 keypad Hang pls help me
Hello any body there pls help me my Siemens c-35 key pad hang pls give me a good solution for get through it. I have seen in three cases of same problem with keypad Hang, I did hot air to Cpu, one day it had worked and same problem in the next day. So pls give me the right solution for it plz.........................
Old 06-17-2003, 10:50   #2 (permalink)
Member: 26889
it hangs? does the button hangs or the button get back to his idle position but the function goes on? you can open the phone and check if there is any rust between the buttons. it could be more things that cause this. please be more detailed in your description. whe can get through this
plz help me, my siemens sx1 locked! asemoni Siemens Hardware Repair Area 1 03-30-2008 16:43
X100 keypad hang pls help??? proxy_gsm UST Pro II 11 12-06-2006 10:07
Hello my siemens C28 automatically switch off pls help me in this regarding kelika7hills x1x to x45/x50 0 08-13-2003 06:02
Need Help for My Siemens S40 DrMobile x1x to x45/x50 5 06-03-2002 18:53
Page generated in 0.16514 seconds with 9 queries
