question about field "type of number" in SMS PDU In description of SMS PDU (available for me) it is specified, that the code 81h is equal to national number, and 91h - international (begins with "+"), for other codes suggest to look GSM 04.08, chapter 10.5.4.6, I could not find GSM 04.08, but to me have come SMS with type D0h and there instead of the simple numbers (4 bits per symbol) was latin word in the 7-bit coding ! And on the screen in phone the field "from" was not number, and a word. Where it is possible to take the list of codes (except for D0/81/91) ? P.S. I have found the source code of the program for writing SMS PDU, but there is specified: === // Type of Number sub-field DA_TON_UNKNOWN 0x80 DA_TON_INTERNATIONAL 0x90 DA_TON_NATIONAL 0xA0 DA_TON_NETWORK_SPECIFIC 0xB0 DA_TON_SUBSCRIBER 0xC0 DA_TON_ALPHANUMERIC 0xD0 DA_TON_ABBREVIATED 0xE0 DA_TON_RESERVED 0xF0 === But national number has type 81h (instead 0xA0) !? P.P.S. Here an example of the usual message (from S45i, a field of length of a line of the sender in 15DD2B, type of a line of the sender - 15DD2C, sender: "674", time in format "yy mm dd hh mm ss" in 15DD31): === 15DD20: F2 00 9B 04 03 00 00 00 01 9B 04 03 B9 76 F4 00 15DD30: 00 40 90 02 02 00 93 61 A0 CB BA 7C 0E 8A 81 AA === Here an example of the message with type D0h (sender: "BeeLineInfo"): === 15DD20: F2 00 76 24 14 00 00 00 01 76 24 14 D0 C2 72 99 15DD30: 9D 76 97 93 6E F3 1B 00 00 40 90 02 81 93 90 61 === |
@ntcn It's a long time ago that I programmed with PDU, so I found this, maybe it helps you ***** Type-of-number: Bits 6 5 4 0 0 0 Unknown 1) 0 0 1 International number 2) 0 1 0 National number 3) 0 1 1 Network specific number 4) 1 0 0 Subscriber number 5) 1 0 1 Alphanumeric, (coded according to GSM TS 03.38 7-bit default alphabet) 1 1 0 Abbreviated number 1 1 1 Reserved for extension The MS will interpret reserved values as "Unknown" but will store them exactly as received. The SC may reject messages with a type of number containing a reserved value or one which is not supported. 1) "Unknown" is used when the user or network has no a priori information about the numbering plan. In this case, the Address-Value field is organized according to the network dialling plan, e.g. prefix or escape digits might be present. 2) The international format shall be accepted also when the message is destined to a recipient in the same country as the MSC or as the SGSN. 3) Prefix or escape digits shall not be included. 4) "Network specific number" is used to indicate administration/service number specific to the serving network, e.g. used to access an operator. 5) "Subscriber number" is used when a specific short number representation is stored in one or more SCs as part of a higher layer application. (Note that "Subscriber number" shall only be used in connection with the proper PID referring to this application). gsm0340_V740 ***** I have the followed PDF-files gsm0338_V720.pdf gsm0340_V740.pdf gsm0411_v510.pdf gsm0411_v700.pdf GSM_07.05.pdf GSM_07.07.pdf Please let me know, if you need one of them via e-mail. Best wishes maulwurf |
2maulwurf, thanks! I have found the similar information in http://rpu6.nm.ru/doc/appnote_constr...f_sms_pdus.pdf, but it was interesting to me how to get sender string for each type of SMS (for example, for type B9). That is for "alphabetically-digital" fields 7-bit coding, and for the others only "on 2 numbers in byte" is used? |
Hi ntcn, this are the links where I got my GSM-Docu http://webapp.etsi.org/key/queryform.asp it's the homepage of ETSI <http://www.etsi.org/services_products/freestandard/home.htm> May this can help you. Best wishes maulwurf |
Has loaded the description, but it is identical to that you specified above. Though this the standard - it should correspond :) 2 moderators: if it is possible - close or delete a topic, probably more information will not be. |
Sending SMS with SENDER NAME (TP-Message-Reference) Quote:
I wanna send SMS, and define SENDER NAME, but I receive ERROR message from my mobile (not network). I can send normal SMS using PDU format with no problems; only have problems sending SMS with SENDER name (I mean TP-Message-Reference) I want, the receivers of my SMS, see a NAME instead of NUMBER. Is there any sample of TP-Message-Reference<>0 in your PDF files? I think this is about gsm0338_V720.pdf Thanks A.B.Fatehi |
it's really long time ago that I done something with SMS and PDU. I'm not sure if you have to use 7bit character. If you want I can send you all the documents PDF which I have, for this please give me your email address (for the @ use [at]). maulwurf |
I must do the same thing, can you help me? |
