x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
07-12-2002, 20:18 | #1 (permalink) |
Major Poster Join Date: Jun 2002 Location: Germany
Member: 13266 Status: Offline Thanks Meter: 0 | Repair Solution for dead S/C/M 35 HOT NEW No matter your C/S/M 35 by the Flashen was how defective with this method functions it again!! 1. You need a Backup of another C/S/M 35 depending upon model. 2. It must have been selected however with the X-35 Flasher. 3. Load Flash file presses and opens your Backup. 4. Then Repair Phone press and the red button from your Phone press. 5. If the Flash is finished Unlock and Imei-change with Siemens –maper by heinrich and Logger 4.02!! No Problem for V.24 All in one!! That`s All!! Under Win 98 works 100% The X-35 Flasher can down-load you here you. Click Here Siemens_mapper click here Logger 4.02 © copyright by multifund Last edited by MULTIFUND; 07-20-2002 at 20:56. |
07-13-2002, 06:12 | #5 (permalink) |
Member: 13266 Status: Offline Thanks Meter: 0 | A Backup can you from me have. Write in the Attachment Backup X-35 Flasher S35!!!! Mail me, and I`send it to you. Last edited by MULTIFUND; 07-15-2002 at 00:18. |
07-14-2002, 04:43 | #6 (permalink) |
Insane Poster Join Date: May 2002 Location: Netherlands Age: 41
Member: 11803 Status: Offline Thanks Meter: 0 | Hello MULTIFUND, Thanks for your repair guidance, nice work. I need a working "backup", for a dead Siemens "M35i" to repair it with X-35 Flasher. (Dutch language) Maybe if you have it, you'll be so kind to send it to me? Would be a good chance, to try your repair guidance. You can mail me here If you need more info, please let me know. Greetz Trailer. |
07-14-2002, 05:25 | #8 (permalink) |
Junior Member Join Date: Jul 2002
Member: 13682 Status: Offline Thanks Meter: 0 | @MULTIFUND ask u some question about x35 flasher Using it with win98SE system, I try "repair phone" with bin file u sent to me. Click "Flash", choose bin and press "repair phone". Waiting 10 minutes, It's no any progress. Using other method, my phone is alive now. Then I want to read EEprom form s35 24v8. After press "Read EE", input a bin name and then power on phone (in service mode I think). The same thing happen. Waht's wrong? BTW Flash ID is E401 Regards, |
07-14-2002, 05:37 | #10 (permalink) |
Member: 13682 Status: Offline Thanks Meter: 0 | oh, install win98 again win98=win98se in my mind thanks for reply where is "red listener key"? I can't find it in software "red listener key" is the open/close button of s35? I press it as demand, but X35 display "sending application..." for 10 minutes. Last edited by QQisQQ; 07-14-2002 at 05:44. |
07-14-2002, 06:04 | #11 (permalink) |
Member: 11803 Status: Offline Thanks Meter: 0 | @ MULTIFUND Hi MULTIFUND, Thanks for the M35 v17 does it have lg1 (Dutch language included)? X-35 Flasher works fine on my WIN98SE, no problem! Backups "read" with Ziemens Workshop, (select all options) also work fine. ("write or repair" this backup with "X-35 Flasher") And this is for QQisQQ: If you have a virus scanner installed, "switch it off" before reading or flashing! Greetz Trailer. Last edited by Trailer; 07-14-2002 at 06:15. |
07-14-2002, 06:22 | #12 (permalink) |
Member: 13266 Status: Offline Thanks Meter: 0 | @ QQisQQ I believe which you the wrong data cable used. Sorry for my english, I meen the red button on your mobile!! 10 Minutes is not normal!! @ Trailer Dutch language included, no notion?? You must excuse, it can be which I always everything correctly understand or correctly do not show. I translate most with a translator!! Last edited by MULTIFUND; 07-14-2002 at 06:28. |
07-14-2002, 09:07 | #13 (permalink) |
Member: 11803 Status: Offline Thanks Meter: 0 | @ MULTIFUND Hello MULTIFUND, Siemens M35i alive and kicking!!! The M35 v17 you send me is perfect. (lg1 Dutch included) Used repair with X-35 Flasher (phone SP blocked now) Changed IMEI to original + unlock with IMEI Changer by Lead. Updated to v18 with Winsup. Changed personal settings in phone(language etc.) Finally made new backup (X-35 Flasher or Ziemens Workshop) Phone working perfect! Many, many thanks MULTIFUND you're GREAT! Greetz Trailer Last edited by Trailer; 07-14-2002 at 09:09. |
07-14-2002, 15:38 | #14 (permalink) |
Member: 13682 Status: Offline Thanks Meter: 0 | @ all The only problem of mine is using a wrong data cable just as MULTIFUND said. although I can repair dead s35 successfully with it, it can't work well with Unisiemens or Ziemens Workshop. I'll find a new cable for testing. Many many thanks for your kind help |
repair solution for dead T20s | ripper_bg | Old Ericsson Phones & Sony Phones | 8 | 06-28-2006 09:10 |
An Easy Repair Guide For Dead C975 After Unlock FOR R245_U_82.21.911 TYPE | chowdary | Motorola P2K (USB-Smart) | 2 | 05-07-2006 15:16 |
REPAIR SOLUTION for DEAD Panasonic phone | m.com | Panasonic | 96 | 09-23-2005 21:09 |
:: Update 28th April 2005 :: X70 repair instruction for DEAD phones : | Infinity-Box | Infinity-Box | 14 | 05-01-2005 00:31 |
Simple repair solution for dead C/M 35-tested 100% working!!!! | Abe | x1x to x45/x50 | 30 | 05-13-2002 08:29 |
