Reset phonecode? I want to change to a new phone code but I don't know the current phonecode. How can I reset it? Thanks. |
@andi u can write new EPROM (phonecode '0000') to phone, after change IMEI. |
Use new map, it solve all problems with phonecode and lockings ;) |
hi guys, i entered wrong phonecode 3 times on my SL45 fw56, now it's locked. Can someone please help????????? thanks alot guys..... |
@andi & @r4rosal Create *.log, using logger 4.02 and sent them to me. IŽll create *.map for you. Then just write it with logger4.02 again. |
i already used logger 4.02, why is IMEI box field lacks 1 digit? my IMEI no. has 15-digits while in logger 4.02 you can enter only 14-digits? thanks all drug_store, could you please explain how to use logger 4.02 |
Insert only 14 IMEI numbers, the last digit will be calculated later. DonŽt worry. Insert your IMEI, save the *.log, and sent me. Then IŽll send you *.map file. |
