x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
02-23-2002, 11:17 | #1 (permalink) |
Crazy Poster Join Date: Feb 2002 Location: Poland
Member: 9490 Status: Offline Thanks Meter: 0 | s35 detected as c35 after Workshop 1.22 |
02-23-2002, 22:42 | #4 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Belarus Age: 50
Member: 4048 Status: Offline Thanks Meter: 0 | You don't need to reflash phone with S35 flash, phone will work Ok, tested many times.<br />And I didn't find any eprom for repair S35 v18 in the net.<br />But you can flash v05 and use eprom from Landy's page but You don't need it!<br />Regards |
02-24-2002, 11:11 | #7 (permalink) |
Member: 9490 Status: Offline Thanks Meter: 0 | O no, what I have done!<br />I tried to downgrade to v05(i wanted to do what Maks wrote)from v18 and now my s35 is dead at all.It even does not work in service mode-what to do? |
02-24-2002, 11:54 | #8 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Fairyland
Member: 3383 Status: Offline Thanks Meter: 3 | Hi Wit, sometime after many attempts the phone stops going into service mode ,<br />so just leave it for a day n try tommorow , maybe it will go into service mode . goodluck have faith n trust pete <img src="biggrin.gif" border="0"> |
02-25-2002, 00:50 | #10 (permalink) |
Insane Poster Join Date: Jan 2002 Location: earth Age: 42
Member: 8906 Status: Offline Thanks Meter: 0 | Wit, you don't need downgrade v05 to use s35 repair bin from landys.. Just upload eeprom from that file and cee-repair. it should work even the phone using v18 and up.. [quote] You don't need to reflash phone with S35 flash, phone will work Ok, tested many times.<br />And I didn't find any eprom for repair S35 v18 in the net.<br />But you can flash v05 and use eprom from Landy's page but You don't need it!<br />Regards <hr></blockquote> Phone identifying are saved at eeprom block 69 and 140, the program will look at these block to recognize c/m/s35..<br />To make the program recognize your phone as s35 again, just use an EEPROM dump from s35 type of phone. If you don't want to disturb the EEPROM you have right now, you can just copy the required fields from another EEPROM. To do this, look in the directory structure located at the end of the EEPROM, and copy EEPROM blocks 69 and 140.<br /> <img src="biggrin.gif" border="0"> |
w830 detect as k700 after write gdfs HELP PLEASE..... | SONU898 | SETool2 | 5 | 02-08-2010 13:26 |
M35 detected as C35 in VisSie, S35Explorer, etc.. | LPP | x1x to x45/x50 | 11 | 02-16-2002 02:56 |
Workshop 1.22 - can it dump all x35?!?! | gin1978 | x1x to x45/x50 | 2 | 02-08-2002 13:48 |
100% solution for dead C/M 35 with "abnormal termination" in Workshop 1.22 | Chuk | x1x to x45/x50 | 7 | 01-17-2002 18:26 |
Found A35 Dead solution after Ziemens 1.22!!! | nightxyz | x1x to x45/x50 | 7 | 08-28-2001 10:32 |
