S35: ziemens CEE repair do not work Hi,<br />Since 3 months I try to repair my phone. When I switch on, i lights once and then shut down.<br />I tried to upgrade the flash with v1801 .xbi but it does not change anything.<br />I read that i should perform a CEE repair with Ziemens 1.22 but the program crashes on lunch (windows98 blue screen error).<br />Since then, I tried to upload a s35_18.bin on my phone with the EEuploader (in DOS mode) but the only thing it does is to put my phone in "Service mode" and after the program tells "Phone do not respond". Can anyone helps me please ?<br />How can I upload the .bin to my phone ? Thx ! |
You can upload the bin with another software but you still need to CEE-Repair with Ziemens to bring back your phone alive.. I also use Win98se and Ziemens works fine on my comp. Try to start ziemens manually by starting emulator (emmu.exe) then open the program (serv.exe). <img src="biggrin.gif" border="0"> |
i will try to install a clean windows... maybe it can come from it, no ? i keep you inform.<br />has anybody had the same issue with ziemens v1.22 ? (on some package, i can start the emmulator but the server then crashes, on other packages, both crash at start)... |
sometimes i also get the same problem with you, but always work when i load serv.exe the second time. that is why i told u to start the prog. manually. <img src="biggrin.gif" border="0"> |
I installed win95 (which is more sta^H^H less unstable than 98) but the issue is the same :<br />- I unzip Ziemens v1.22<br />- I lunch emmu and then it crashes, and serv crashed too if I try after<br />- if I lauch via all35 it crashes too what can I do ? |
[quote]Originally posted by LvCKyLuKe:<br /><strong>sometimes i also get the same problem with you, but always work when i load serv.exe the second time. that is why i told u to start the prog. manually. <img src="biggrin.gif" border="0"> </strong><hr></blockquote> I also tried on NT -> i have a Dr. Watson when I start emmu.exe<br />Maybe i did not catch, what do you call "starting manually" ? i understood, strating emmu.exe and then starting serv.exe instead of lunching all35.exe. am I right ? |
try to use another emulator.. mail me, i'll send you the file. <img src="biggrin.gif" border="0"> [ 19 February 2002: Message edited by: LvCKyLuKe ]</p> |
thanks very much, i send you an email. it is cool to find help ! |
Hello.<br />siemens Workshop 1.22 100% worck |
not on all computers obviously... so 100% seems to be strongly optimistic... |
set up windows 98 se again work sure........... <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> |
>>>>@JOHN WESTWOOD!<br />I have the same Problem.What`s this "another emulator"?Does it help?If yes,will You send it to me?<br />best regards,<br />z.natov<br />-----------------<br />[email protected] <img src="eek.gif" border="0"> <img src="frown.gif" border="0"> |
I check the solution provided by LvckyLuke and if it works I forward the program to you. |
Ok,tnx...<br />regards,<br />zakiid |
Please, mail me too this solution and prg.<br />Best regards! |
