x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-14-2002, 01:01 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | dead c45 after flash.... have flashed with 33 version, still the same. With map still no joy ??? pls help |
06-14-2002, 01:17 | #2 (permalink) |
Freak Poster Join Date: Jun 2002 Location: sky
Member: 12495 Status: Offline Thanks Meter: 2 | try this!! downgrade ...all version.... in process downgrade in erase eeprom unplug the data cable.....so winswup again ....... normaly winswup so .... you only need Good MAP from Internet!!!! (no calculate your self....this map generator not good cracked) |
06-14-2002, 01:22 | #3 (permalink) |
Member: 12495 Status: Offline Thanks Meter: 2 | try this!! downgrade ...all version.... in process downgrade in erase eeprom unplug the data cable.....so winswup again ....... normaly winswup so .... your c45 alie but wrong software ....... now you only need Good MAP from Internet!!!! (no calculate your self....this map generator not good cracked) .... with imei writer you got your c45 again! no bzzzzz again......so call me +628122989597 |
06-14-2002, 01:34 | #4 (permalink) |
Insane Poster Join Date: May 2002 Location: BathRoom Age: 53
Member: 12441 Status: Offline Thanks Meter: 1 | downgrade your phone with winswup, when the flash end erase, unpluged your cable from your phone. Then swup again your phone with version you have, you will get wrong software, after that you'll need a map. |
06-14-2002, 23:28 | #6 (permalink) |
Member: 3194 Status: Offline Thanks Meter: 41 | *.lc not work i ll try to unplug my cable when erased finished... to bedjo : hi man... how r u doin ??? have u slved ur 3310 light problem ?? thanks for replying all of u, i ll try that solution rgds |
06-15-2002, 01:22 | #8 (permalink) |
Member: 12495 Status: Offline Thanks Meter: 2 | @ Bedjo u right! i dont know with cellman eeprom damaged or not, if not damage, please to try Bedjo solution...........if Damage send ypur c45 log to Irene or Bedjo or Me! the same as....we all help U! |
06-16-2002, 13:56 | #10 (permalink) |
No Life Poster Join Date: Mar 2002 Location: HEAVEN Age: 51
Member: 10243 Status: Offline Thanks Meter: 18 | try this, read c45 working phone (lower version) with c45 toll ===>*.bin flash *.bin with x35 (new toll for x35-ENEMY)===>stlill dead winswup again with any version.===>wrongsoft write map C45FlashReader.zip x35 flasher Last edited by bedjo; 06-16-2002 at 14:33. |
06-16-2002, 14:24 | #11 (permalink) |
Banned Join Date: May 2002 Location: GERMANY Age: 43
Member: 11549 Status: Offline Thanks Meter: 6 | hi i have full flash C45 v6 .bin u need it use Swup to downgrade or send me Log ICQ : 117887605 [email protected] best regards bop_gsm |
06-16-2002, 19:55 | #15 (permalink) |
Crazy Poster Join Date: Apr 2002 Location: hk Age: 49
Member: 11218 Status: Offline Thanks Meter: 0 | Hi,CELLMAN! About *.lc file. LogUploaders by Pro doesn`t work with different PC cables.I recomend to try outgoing AC. Try this or another PC cabel. My friend had the same problem and this helped him. I could help You with *lc file too. Best regards Gsmgray my icq 58655465 |
Need Help Dead V635 After Flash with V600 Flash (i didn't do it) | g0den99 | Motorola P2k | 3 | 10-08-2005 23:58 |
dead C45 after wrong map, help!!!! | masterID | x1x to x45/x50 | 2 | 03-31-2003 19:08 |
dead t192 after FLASHING with bad flash file | zdob | Motorola Old Legacy (EMMI) | 5 | 07-02-2002 18:30 |
dead t280 after flash with free flash | tkerek | Motorola P2k | 0 | 05-26-2002 16:22 |
Dead 3699 after flashing | unlockerbh | Motorola Old Legacy (EMMI) | 0 | 08-22-2001 17:49 |
