x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
11-11-2002, 22:26 | #16 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Holland Age: 61
Member: 11291 Status: Offline Thanks Meter: 0 | When i create partial flash the programs says 1st partial is start adress 05 second partial starting adress 13 ???????????? What does that mean,when i select SL4x (suppost to do with MT50 !)starting adress for fullflash is 000000 ending 600000. So where do i start with partial flash????? Somebody ???????? Wbr Rossifan |
11-12-2002, 01:30 | #17 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | @Dentin (and all with same problem): Thank's. *) If you look at to the bottom of the screen (green text), you can see WARNING message. New addresses uses non-empty area. Please post the result, and I will give my advise to solve that problem. *) I'm sure it work for its (A3x) full flash file. I did try it with a3x.bin I got from the net. But, I can not guarantee that everything is oke after you upload that file to your phone. I do not have that phone to test and check the impact. @Rossifan (and all with the same problem): If you got that partial flash, then do this (I also write these method in the latest help text) : 1. What is your filename used to save that files ? Let's assume your *NEW* filename was new_ff (or new_ff.bin), then your partial flash are new_ff_05.bin and new_ff_13.bin 2. Run UniSiemens, select your phone model, Open File new_ff_05.bin, modify FLASH FROM value (it was 000000) to 050000, FLASH SIZE value (it was 600000?) to 010000, and do Write Flash ... 3. Open File new_ff_13.bin, modify FLASH FROM value to 130000, keep FLASH SIZE value with 010000, and do Write Flash ... Hope it give more information for you all... RizaPN Last edited by rizapn; 11-12-2002 at 02:00. |
11-12-2002, 02:03 | #18 (permalink) |
Freak Poster Join Date: Jul 2001 Location: Thailand
Member: 5472 Status: Offline Thanks Meter: 0 | Riza : little problems 1. font of bottom screen (green) is difficult to read in Win98se but OK in Winxp this happen with rpnrtc11 too. 2. partial flash for C25v2501 make phone turn off (not correct CRC) Fullflash is OK. great |
11-12-2002, 04:02 | #19 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @ken: 1. OK. I'll change it (for rtmod, because some friends of mine also have the same comment) to the normal font (it is Small font size 7, I will use MS Sans Serif size 8... 2. C25? I think I was not include that firmware inside the INI file. Let's assume that you did modify the INI file and add data for C25 firmware. Then, do you mind to post some data about that firmware, such as : the first address and new address from the table, which partial flash file(s) did you upload ? Thank's, RizaPN |
11-12-2002, 08:54 | #20 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Serbia, Belgrade
Member: 15820 Status: Offline Thanks Meter: 0 | Excuse me but I can't understand what should I do? Only text in the bottom of the screen is this one and it just says that there are that wrong addresses. and than when I try no matter to this to change some ringtone, it says this message I would really like to help as like you and aslo to me and others with same problem, but I really don't know what information do you need. Can you please give me some closer help. I tried ti choose ringtone info from menu but this isn't that. I also tried to save information in list but this also isn't that. I don't know what is that what you need? |
11-12-2002, 09:09 | #21 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @Dentin: As I say, after you Load your file, please press Search button, and you will see some information in the bottom. The problem is that new address area is not free in your fullflash file. What I need is the information about where your free area is... Please post only the free area information, text based, do not use graphics. I think, it consume more bandwidth for all of us... Thank's, Riza PN |
11-12-2002, 12:28 | #22 (permalink) | |||
Member: 15820 Status: Offline Thanks Meter: 0 | I can't believe it I didn't figure that. Now before I give that txt, one question. Is it enought to when some new flash is entered and software, already doesn't support it, to choose search and than press config and this mean that this new addresses is already entered in the *.ini file and that now this flash is also supported? Now here is information you wanted Quote:
11-12-2002, 17:11 | #23 (permalink) |
Member: 15820 Status: Offline Thanks Meter: 0 | While I am writing this I didn't check if there is already some new posts, so I am sorry if someone already explain this. Look what I did. I opened flash file of my ME45i, you know what's the story about it and I was completelly sure that your soft doesn't support this one, which it also says. Than I use search button and than configure. After that I changed few ringtones, not all because this was only a test, and no matter it tells me that warning message. Than I create that two partial flash file and write it in the phone. Put battery out and in and turn on the phone and it works with no problems and ofcourse there is that changed ringtones I made. So, now I am not sure is this happenes just in this case or this warning message doesn't have any meaning if you before use search option so that soft find free area in your flash file? Once again, I want to THANKS A LOT to you, RIZAPN an to tell you that you are PURE GENIUS, and if I can help you in any thing, any where and any how, I will do this, you can count on it. |
11-12-2002, 17:12 | #24 (permalink) |
Member: 11291 Status: Offline Thanks Meter: 0 | @rizapn Oke found first adress to upload with unisiemens,shame on me i didn`t find it before! But second problem is,i only can set adress max to 600000,no 13xxxxx or don`t i see it right? Please help me,i`m using option SL4x to flash MT50 ! Wbr Rossifan |
11-12-2002, 22:29 | #25 (permalink) |
Member: 11291 Status: Offline Thanks Meter: 0 | @rizapn Do i have to change all ringtones or am i able to changes only a few? I`m asking this becouse i changed the first 5 tones,upload the changed fullflash to MT50,and after about 2 minutes phone turns off,when i try to turn phone back on,display shows "wrong software" !!!!! Hope you have a answer Wbr Rossifan |
11-12-2002, 23:29 | #26 (permalink) | |
Member: 5472 Status: Offline Thanks Meter: 0 | Quote:
11-13-2002, 01:47 | #27 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @Dentin: *) That message is a warning about using non-fress area in the flash file as a ringtone data. It will overwrite the existing data. If it was a data which is need by phone to be work normally, then we will have problem if we overwrite that area with other data. *) From your free area data, I think we can use adress 136000 as a starting point. Open rtmod.INI, go to [Ringtone] section, modify ME=42,4,... with ME=42,4,136000 (and if you like, also the S45=42,4,... with S45=42,4,136000, then save the file. *) Run rtmod, Open your full-flash file, press Search (yes, again), press Config to save the new values. After this, you should not be found any Warning again ... then, just redo what you were done before. *) For S35v20, modify S3=42,0,... with S3=42,0,320000 and do the same step with ME ones... @Rossifan: *) The partial address is not 13xxxxx (with 5 x), but 13xxxx (with 4 x). *) Sorry for your Wrong Software. It is not cause by modifying only 1 tone, but I think it was caused by selecting the wrong free area (130000). You can modify just one with same risk with modify all tones. *) If you have your original full-flash, then re-upload that file to your phone. Hope it will make your phone normal. *) If you still want to continue to modify your ringtone, please edit rtmod.INI file, goto [Ringtone] section, modify M5=24,4,... value with M5=24,4,068000 and MT5=24,4,... with MT5=24,4,068000 (read again carefully, there are 3 zeroes after 068). Then, save the file... *) Run rtmod, open your full-flash, press Search, and press Config. After that, you can redo what yo were done before (inserting your selected tones). @Ken: *) OK, it was C35v2501. Theoritically (from my software source point of view), if the full-flash is working normally, then the partial flash (from the same operation and same source file) should work normally also, because those partial flash are the part of that full-flash file. Problem will occur, if we only upload 1 partial-flash file, not all partial files generated by that operation. That's why I want to know what was done by you, also to make sure that I did not do something wrong again in with my software. Thank's, Sorry, and Good Luck, Regards, RizaPN Last edited by rizapn; 11-13-2002 at 06:08. |
11-13-2002, 05:55 | #28 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | *** WARNING !!! *** I just borrow C45, and found that my rtmod 1.25 *IS NOT* support this phone firmware. Phone will be dead after a while, then it become Wrong Software. Tested using C45v14 firmware. Sorry for this, ps: - One user report that he was successfully change his ME45 ringtone with no problem. |
11-13-2002, 09:01 | #29 (permalink) |
Member: 15820 Status: Offline Thanks Meter: 0 | I was that user. I did that change and no matter to warning message, I did that and it works OK, but because it was just a test, I bring back backup so I didn't use phone for very long time. Can you solve this problem for c45? |
11-13-2002, 09:56 | #30 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @Dentin: Hehehe... but sorry, what I meant is someone from other forum (Indonesian) had change his ME45 without any problem... Of course, your input is very usefull for me. Thank's... |
siemens ax72 full flashing procedure+full flashfile wanted | chrizop | E-Gold Based Phones | 14 | 09-20-2010 11:59 |
Siemens Full Flash Modifier | rizapn | Siemens-Benq RingTones and WallPapers | 37 | 02-27-2003 11:47 |
Siemens A40 full flash | jojopovo | x1x to x45/x50 | 19 | 01-14-2003 03:02 |
i need siemens c25 full flash for use with koci 5.30 | gsm flying free | x1x to x45/x50 | 7 | 12-03-2001 18:04 |
Siemens C30 full flash | milerr | NON Siemens Brand (ODM Phones) | 8 | 09-07-2001 09:55 |
