Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
![]() | #31 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2001 Location: Thailand
Member: 5472 Status: Offline Thanks Meter: 0 | Quote:
Are you sure that partial flash-files created after CRC full-flash already? Sorry for disturbance. | |
![]() | #32 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2002 Location: Serbia, Belgrade
Member: 15820 Status: Offline Thanks Meter: 0 | Quote:
![]() BTW, I forgot to tell you that this I did, not on ME45, I did that on ME45i or ME45 with soft of S45i, maybe this is the reason it works. But also I did what you say to me, change that values in ini file and than choose, search and configure, and now when I open either flash for ME45 v28 or S35 v24 or ME45i it says that everything is OK and there is no that warning message. I tried on my ME45i now to partial flash phone after did that and everything is working just great. Now I am trying to convince my friend with S35 v24 to give me his phone AGAIN to try to change ringtones again, but he's having second thoughts because I killed his phone last time with this soft and than put backup back ![]() ![]() p.s. I would like to heard if you did something about C45 because a friend of mine has it and I would like to try it also on it? | |
![]() | #33 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2002 Location: INDONESIA
Member: 17360 Status: Offline Thanks Meter: 1 | For S/ME45 v28 and S/ME45i v04 users ... Please edit the RTMOD.INI file. At the [RINGTONE] section change: S45=42,4,13xxxx ME=42,4,13xxxx to ... S45=42,4,136000 ME=42,4,136000 Save the file, open the RTMOD.EXE, and load your BIN flash. Click on the SEARCH button, then click on the CONFIG button. After that, you know what the next ![]() Tested on my ME45 v26 & v28 and ME45i v04 ... ![]() have a nice day, -YudiYaN- |
![]() | #34 (permalink) | ||
Member: 15820 Status: Offline Thanks Meter: 0 | More news, I've just got two phones for checking this soft, and changing ringtones for their owners. This is S25 and A40. I did'nt make anything with S25 because I find out that UniSiemens doesn't support this model so I can't make backup of flash and also can't flash phone with it. If someone knows what flasher support S25 please tell me. A40 is strange phone. Look what happened. First after did backup, I open it with rtModifier and it says Quote:
@ KoTsK Rizapn has already explained that and that already works. Last edited by Dentin; 11-14-2002 at 11:00. | ||
![]() | #35 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2002 Location: -[r0]- Age: 51
Member: 9891 Status: Offline Thanks Meter: 2 | @Dentin: *) A40? I think I was not put A40 inside the original rtmod.ini. If rtmod display something, means it is already support. Did you add something inside your rtmod.ini? If not, do you mind to check, what is the firmware type value (see Firmware Info box), is it A3x ? *) From your free area info, you can use 085400 as your Axx new address. Modify it (just like when you modify this value for ME case) inside the rtmod.ini ... I think, it was written as 085200 ... *) It is good to hear that it is work for Axx phone firmware... *) S25? I do not think so... RPN |
![]() | #36 (permalink) | |
Member: 17360 Status: Offline Thanks Meter: 1 | Sorry, i didn't read at all .... too long ![]() ![]() Quote:
![]() ![]() ![]() Please visit our ForumPonsel. Give us your clues ![]() Thank you ... | |
![]() | #37 (permalink) |
Member: 15820 Status: Offline Thanks Meter: 0 | @Rizapn Look man. I don't have this a40 phone now with me, because it was only a short time at me while I was doing it. Now I don't have it and maybe in next couple of days I will have it again. When I open this flash it declares it like a A3x one, but with one mistake. Then only first possition gives that warning message, in opossite to all others which don't make any problems. Only problem shows when all job is done and that is problem that few of ringtones stay old and others are new ones. That is only problem. I will try to change this values so that soft supports also and a40. But results will be in next few days, maybe longer. Now about S25. Can you do what you did for all this phones and also for S25? I'd priciate that very much because I promisse that I will do that to my sister from uncle and now she asking me non-stop when I will do that. Can you please do that? |
![]() | #38 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2002 Location: Holland Age: 60
Member: 11291 Status: Offline Thanks Meter: 0 | @Rizapn I was trying to flash (Partial)with new .ini settings you gave me yesterday,al seems to be ok,but after 3 minutes phone turns off. When turning on again "wrong software". So i think settings for m(T)50 still not good yet! Please could you try to figure it out,so i will be able to change my ringtones permanently! Wbr Rossifan |
![]() | #39 (permalink) |
Member: 5472 Status: Offline Thanks Meter: 0 | Dentin: For S25 we have free program to read fullflash from, but I don't found program for write fullflash. In the past, I used C25 total flasher write fullflash to S25 but.... only first MB. (S25 fullflash= 2MB C25 = 1MB). At last, if you edit S25 fullflash in first MB area you can write it to phone with C25 total flasher. I don't know @Rizapn program can support it or not and you should try..... Rossifan: Suggest to write fullflash edit by program to your phone. I still have problem with 2 partial flashs created by this prog too. |
![]() | #40 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @Ken: From your previous explanation, you can do partial upload using your own partial files (copy-paste from the modified full-flash file). Did you compare those files with the ones (partial ones) which are created by rtmod? Is there any different? @Rossifan: After some trial using the real C45, and both M50 and C45 full flash file which I have, now I come with some conclusion: *) C45 and M50 has almost same CRC algorithm. Both use different algo with C/M/S35, S/ME/SL45, and A3x. *) My CRC algo is not compatible with their algo, that's why the CRC for new full-flash file looks like wrong. So, for the time being, please do not use rtmod for C45 and M(T)50 unless you know how to bring your dead phone alive ... Riza Purwo Nugroho |
![]() | #41 (permalink) | |
Thanks man for thi sinformation. If Rizapn would make to his soft works and with S25 I will ask you to give this soft to me, hope you'll do it. @Rizapn Hey man. Is there any chance that you make your soft works with s25, and what do you think about this ken told, is it enought to flash, just first mb of two? Hope you'll find that alghoritm you need for c45 because I would like to to that also on c45. Why don't you see about that with DarkBEER, Skylord or some great minds like those ones? All for one and one for all ![]() | |
siemens ax72 full flashing procedure+full flashfile wanted | chrizop | E-Gold Based Phones | 14 | 09-20-2010 11:59 |
Siemens Full Flash Modifier | rizapn | Siemens-Benq RingTones and WallPapers | 37 | 02-27-2003 11:47 |
Siemens A40 full flash | jojopovo | x1x to x45/x50 | 19 | 01-14-2003 03:02 |
i need siemens c25 full flash for use with koci 5.30 | gsm flying free | x1x to x45/x50 | 7 | 12-03-2001 18:04 |
Siemens C30 full flash | milerr | NON Siemens Brand (ODM Phones) | 8 | 09-07-2001 09:55 |
