x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
01-15-2003, 01:40 | #1 (permalink) |
Junior Member Join Date: Jan 2003
Member: 19498 Status: Offline Thanks Meter: 0 | siemens sensor tools 1.3 after a lot of digging in older post i didn't find really satisfying answer about sensor tools...i tried to calibrate my sl45 battery but something gone wrong...now the phone acts really strange...i have tested all *.blk files for sl45 for resolving this problem but no success ... is here somebody who can explain battery calibration step by step ? |
01-15-2003, 21:01 | #2 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | try to read values or ask someone to give you right values, from a good phone, and write it into yours. If you still donīt know how to use it, Iīll explain you how to use it. Go to my site and donwload BLK files archive http://www.drug-store.angelcities.com/Files/Bat/Blk.rar Iīll send you by mail right away a *.blk file from my own SL45i |
01-16-2003, 20:58 | #4 (permalink) |
Member: 19498 Status: Offline Thanks Meter: 0 | thanx for reply drug_store... i've downloaded the blk files from your yahoo group...now i'm testing one by one which is fitting best to my phone...but this is like fishing in the ocean ... the utility (sensor tools 1.3) is very confusing..is there any documentation or manual for using it ?...and why the program's sensor values (vbattmin,vbattmax,vbatmiddle ) are without values ? there is a just green note "ACTIVE"... |
01-17-2003, 19:47 | #5 (permalink) |
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Test only SL45 files. If itīs very confusing, use 1.0 or 1.1 http://www.drug-store.angelcities.com/Files/Bat/ |
07-30-2003, 06:37 | #9 (permalink) |
Insane Poster Join Date: Jul 2003
Member: 33336 Status: Offline Thanks Meter: 0 | I have tested this extensively with virtually no help and I have come to the conclusion that, even if you get someon else's good values from their phone, it does not necessarily mean that it will work good on your phone. As I understand, every phone is very different and that means that the optimal settings on your phone are also very different. I've loaded up a lot of "original" or "optimal" settings and, although the standby times are very long, the battery indicator is pathetic. The only way to solve this problem, I think, is to make your own sensortool values. This is very lengthy and its pretty much trial and error. I have asked several times what each of the values mean and the only information i can find is that "SPGY03V" is the "shutdown value" and the SPGY04V is the "stop charging value" Gr_diver has told people on this forum that, if you increase your SPGY03V, then you will get the phone to shut off at a lower voltage (which means that your battery will last longer). However, if you put this value too high then your battery indicator will no longer work (your phone will think that the battery is full when in actual fact it is not) For the SPGY04V value, I have been told that increasing it will mean that your phone will charge the battery to a higher voltage. However, if you enter a value which is too high, your phone will over-charge the battery thereby reducing it's lifetime. That is all I know and no one on this forum seems to want to help me figure out a solution to this battery problem. So I guess it's me on my own now. |
07-31-2003, 00:13 | #10 (permalink) | |
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Quote:
Yes you have to figure out whats be best values for your phone by yourself, and each phones has different values... Thanks | |
07-31-2003, 13:01 | #11 (permalink) |
Member: 33336 Status: Offline Thanks Meter: 0 | How do I figure this out? 6 months ago I might of JUST bought my SL45, so forgive me for not being here when you guys were talking about it. But I've searched high and low and no one can give me advice on how to configure my phone properly. So now I'm just chucking in random values..... |
08-03-2003, 03:25 | #14 (permalink) |
Freak Poster Join Date: Jul 2001 Location: Thailand
Member: 5472 Status: Offline Thanks Meter: 0 | Do not serious about battery calibrate. I has used Siemens C25 S25 C35 S35 C45 and S45, but none of them has ideal linear scale. For me calibrate to... 1. do not turn off when charging. 2. shut down with properly low voltage. 3. period of used times is OK. 4. scale is seem to be OK. |
HELP: After using Sensor Tool 1.3 my telehpone is off | hookah | Siemens Hardware Repair Area | 1 | 10-13-2004 15:54 |
Help! Siemens sensors tool 1.3! | morzsi | x1x to x45/x50 | 3 | 11-06-2003 21:05 |
Sensor Tools 1.3 calculation | sasko2 | x1x to x45/x50 | 0 | 10-13-2003 09:31 |
canīt conect S35i whit sensor tool 1.3 | GeorgEisler | x1x to x45/x50 | 3 | 05-29-2003 07:47 |
Siemens Sensors Tools 1.3 LATEST VERSION | Drug_Store | x1x to x45/x50 | 0 | 11-22-2002 20:39 |
