x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
12-14-2002, 23:23 | #31 (permalink) | |
Freak Poster Join Date: Jul 2002 Location: Croatia Age: 49
Member: 14004 Status: Offline Thanks Meter: 6 | This data is very helpfull !!! Quote:
So, i firsrt tried to put 7200 for 0000 and 7201 for 0002, and chargung error was corected, but phone was allways showing full battery (even on Vbat 3.3 V !!!) Then i tried your data, and phone is OK. Charging normal, no shut-off, battery lasts for more than 120 min of talk (battery is one year old!) Thank you very much! | |
12-15-2002, 14:31 | #32 (permalink) |
Junior Member Join Date: Nov 2002
Member: 18294 Status: Offline Thanks Meter: 0 | It is nice to try different data. But does anyone know, what does each filed exactly mean? And what format are the data which should be written into those fields? There are some voltage and temperature data..... I need some help with this, please. I don't have problems with charging, but I have problem with temperatures. My phone does not turn on when it is cold. |
12-21-2002, 08:17 | #33 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: INDONESIA
Member: 17360 Status: Offline Thanks Meter: 1 | Quote:
01-18-2003, 05:33 | #34 (permalink) | |
Freak Poster Join Date: Aug 2001 Location: Metro Manila
Member: 5971 Status: Offline Thanks Meter: 2 | Quote:
Thanks a lot! | |
01-31-2003, 08:58 | #35 (permalink) |
Member: 17360 Status: Offline Thanks Meter: 1 | same as WITEK ... but i tried to change value in 000C ... 0000:4183 0002:4221 0004:63461 0006:1011 0008:79 000A:62490 000C:107 000E:65233 0010:100 0012:0 works well, too. tested on ME45i 040101. |
05-26-2003, 18:34 | #37 (permalink) |
Member: 14004 Status: Offline Thanks Meter: 6 | Yes, sensor tools could probably help. Try it, but first save your data to file.... If something goes wrong, load your backup to phone. Try values posted in this thjread and inform us of results! |
06-25-2003, 11:31 | #38 (permalink) |
Junior Member Join Date: Jun 2003 Location: Portugal
Member: 31918 Status: Offline Thanks Meter: 0 | I've tried the WITEK settings and the phone is working fine? What are the meaning of each setting? Not only 0000, 0002, 0004, 0006. Is those setting thge perfect tunning for the mobile? Thanks. |
07-16-2003, 09:38 | #39 (permalink) | |
Junior Member Join Date: Jan 2003
Member: 19926 Status: Offline Thanks Meter: 0 | Quote:
Somebody any idea to get it loaded better in carkit? | |
09-02-2003, 19:21 | #40 (permalink) |
Junior Member Join Date: Sep 2003
Member: 38224 Status: Offline Thanks Meter: 0 | If anyone got good results for M35i please post... will the values already posted work well for other models like C35/M35? Is there any risk to the phone by using wrong values not suitable for my phone? |
03-03-2005, 12:01 | #41 (permalink) |
Junior Member Join Date: Mar 2005 Age: 43
Member: 122576 Status: Offline Thanks Meter: 0 | Do you guys have a working link for those files? Here is my issue, and maybe you can suggest an alternative solution... but from what I am looking at, I might be able to fix it with this tool you are talking about... I have an S55... When I start to charge the phone, it discharges. I bought a new battery yesterday and I got the same problem. Bought a new charger too, just in case. Now I have no technical understanding of the phone, but could you suggest some way to fix this? Thank you. PS. Now there is no juice in the batteries to switch it on and charge them. Please answer back, thanks |
03-04-2005, 22:05 | #42 (permalink) |
Junior Member Join Date: Mar 2005 Location: Germany Age: 46
Member: 122957 Status: Offline Thanks Meter: 0 | Hi all, I have a similar problem with a MC60. The display always shows me "Battery empty. Please charge.". Does anyone know the right configuration for this mobile? From Siemens Sensor Tool: 0000: 4740 0002: 4182 0004: 64205 0006: 1007 0008: 97 000A: 65181 000C: 97 000E: 65272 0010: 100 0012: 0 |
How to use Sensor Tool to fine tune SL45 battery | sl45vietnam | x1x to x45/x50 | 40 | 11-23-2004 10:27 |
Siemens Sensor Tools Help - Battery empty Problem | stigma | x1x to x45/x50 | 4 | 03-15-2003 12:10 |
Need blk-File for Siemens Sensor Tool for SL45 | vikado77 | x1x to x45/x50 | 4 | 07-09-2002 22:04 |
Siemens Sensor Tool | gamalabel | x1x to x45/x50 | 2 | 06-24-2002 22:36 |
