x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
07-15-2002, 02:18 | #7 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | i already have change pf, but problem still remain. About sensor tool, is difficult to use... i dont know what number should be used to have correct result.... i ve used flx files, hoping have original eeprom and used map files, no joy... pls help.... |
07-17-2002, 12:07 | #8 (permalink) | |
Junior Member Join Date: Jan 2002 Location: RUSSIA Age: 46
Member: 9048 Status: Offline Thanks Meter: 0 | Quote:
http://www.siemens-club.ru/files/SiemensTools.rar and try to read post here http://forum.siemens-club.ru/viewtopic.php?TopicID=7453 | |
07-18-2002, 01:22 | #9 (permalink) |
Member: 3194 Status: Offline Thanks Meter: 41 | CarkBear thx for reply... but i still cant used this soft.... i have no idea about parameter that used to fill in each Column. About the forum is in russian.... i cant read it. pls help from you... thx |
07-18-2002, 01:24 | #10 (permalink) | |
Member: 3194 Status: Offline Thanks Meter: 41 | Quote:
Should be Darkbear...not Carkbear.... sorry for mistyping.. rgds | |
07-18-2002, 12:33 | #11 (permalink) | |
In new version you must see this fields. SpgY03V - Offset from 3.0V SpgX0 - Nominal Voltage SpgY04V - Offset from 4.0V Example: 0000 SpgY03V -6474 -min - 3+0.6474 = 3.6474 V 0002 SpgX0 -4181 -nom ---------------- 4.1810 V 0004 SpgY04V -2188 -max - 4+0.2188 = 4.2188 V Measure SpgY03V vs near Empty Accum, SpgY04V vs Charged Accum. | |
07-18-2002, 22:04 | #12 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Bulgaria Age: 44
Member: 8627 Status: Offline Thanks Meter: 4 | Ok i'll try to explain you how to calibrate your phone with sensor tool. This is about old siemens tool version. 1. You should use only 0000 and 0004 fields (0002 and 0006 should be used only if you go out of range in 0000 and 0004) The numbers in fields are in hex format - A=10 , B=11 .... F=16 This is the only diference from decimal. 2. Fully discharge your battery then increase vbattmin value with 200 ex: 1F33 + 200 = 2133 , 1000 +200 =1200 discharge again and increase value untill battery really fully discharged( phone will turn off without warning) Now decrease vbattmin little ~100 (If you want to get batt empty warning ) . Now your vbattmin value is ready. 3. Increase (decrease) vbattmax value until vbattmiddle reaches 3.66 -3.67. 4.Recharge (At the end your battery should be little hot because the vbattmin value is oversized.You should decrease vbattmin value if your battery becomes very hot) Your vbattmax value should be 4.2-4.3 If everything is by plan congratulations the last siemens protection has fallen and your battery will have more standby time Special thanks to DarkBear. Last edited by prp; 07-19-2002 at 20:32. |
07-19-2002, 01:14 | #13 (permalink) |
Member: 3194 Status: Offline Thanks Meter: 41 | thx for the reply... its work!! really aprreciated for your help friends... its need time to do that, but result Good and i ve learned somethin... rgds Check out my Groovy Tones at : http:\\nokiaforum.org at Nokia General Discussion.......Cool !!! Thx Dark Bear |
6500c charging ok but always low batt. | gsm junction | Nokia Hardware & Hardware Repair | 0 | 03-26-2010 09:11 |
6500c charging ok but always low batt. | i-Fixed | Nokia Hardware & Hardware Repair | 5 | 02-11-2010 13:46 |
nokia 3230 low battery always. 1.2v on batt connt ...plzz help | raggudada | Nokia Hardware & Hardware Repair | 4 | 01-29-2010 14:14 |
K300 low batt always | elpocitano | Sony Ericsson Hardware Repair | 1 | 02-18-2007 02:45 |
Allway low batt on 2618s | Jeroen | Old Ericsson Phones & Sony Phones | 1 | 05-26-2001 21:21 |
