Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 05-24-2002, 18:01   #1 (permalink)
Member: 11444
Wink (NEW) Simple Solution Repair X35 Phone Dead (Tested 100% Work) VERSION 2
THIS SIMPLE REPAIR I HOPE MORE EASY TO USE.
For ALL people always asking and searching about this topic, This is a solution i use for repair and your all must know how to use (PLS LEARN by ur SELF).
This solution i get while try to downgrade ver24 to ver21.
(Ver24 cannot change imei if u change with lead your phone get error and u must use workshop 1.22 pro to repair)
1. USE MARTECH 1.7 TO WRITE FULL FLASH (CHOOSE X35 FULL FLASHER (X35 VER 05) TO WRITE (THIS FULL FLASHER YOU CAN DOWNLOAD FROM LANDY PAGE)). UNTIL FINISH --> NEXT
2. FLASH YOUR PHONE WITH WINSWUP and USE X35 VER 0503 --> NEXT
3. USE ZIEMENS SOFTWARE 1.22 BY PRO AND PRESS "CEE_REPAIR" (THIS JUST TRY REPAIR ANY DAMAGE BY FLASHER (REPAIR "SERVICES MODE") REMEMBER YOUR PHONE STILL DEAD) --> NEXT
3. TRY YOUR PHONE WITH MARTECH 1.7 FOR SURE IF YOUR PHONE CAN CONNECT TO "SERVICES MODE" (THE WORDs UP ON PHONE SCREEN) --> NEXT
4. IF OK FOR "SERVICES MODE" USE X35EE_UPLOADER AND USE THIS EEPROM S/M/C 35 TO REPAIR YOUR PHONE EEPROM. (SOMETIME U MUST PRESS THE "ON" POWER REPEAT 3-5 TIMES UNTIL THE "SERVICES MODE" UP ON THE PHONE) --> NEXT
5. USE ZIEMENS 1.22 AGAIN TO REPAIR CLICK "CEE_REPAIR", NOW YOU GET WORKING PHONE AGAIN --> NEXT
4. USE IMEI CHANGER BY LEAD TO CHANGE IMEI BACK. --> NEXT
5. FINALLY U CAN USE X35 ANY FIRMWARE TO UPGRADE BUT YOU JUST CAN UP TO VERSION 21. CAUSE LEAD IMEI WRITER JUST SUPPORT UP TO VERSION 21 (AFTER VER21 YOUR PHONE WILL ERROR, PLEASE REPEAT PROCEDURE TO REPAIR)
THIS SOLUTION TESTED ON S35i AND M35I (WORKS 100%)
ALL SOFTWARE YOU CAN DOWNLOAD FROM LANDY PAGE
For EEprom u can download from here
Old 05-25-2002, 16:15   #2 (permalink)
BufferMess's Avatar
Member: 9856
Thanks Meter: 2
Tested on C35, too. Works 100%
Thanks
Old 05-25-2002, 16:36   #3 (permalink)
Member: 8329
Thanks Meter: 6
... yep!... works 101% !!!!!!!
very good solution RINVEND !
Old 05-25-2002, 17:00   #4 (permalink)
maxxnskk's Avatar
Member: 6791
What new in this solution?
On Landy page you can find it, it is old as landy pages
Old 05-27-2002, 08:56   #5 (permalink)
Member: 11444
On Landy page this solution similar but many people not really understand. so i make this solution i get while try to repair x35 dead phone and i explain this solution very easy step to use
Old 06-11-2002, 05:17   #6 (permalink)
Member: 3969
Thanks Meter: 9
Sorry, but i ot a lil problem: I cannot acces these files, cause i don't have pass. My other problem is, that the martech software stops and restarts fashing at 5%, with an error message: read beyond end of file. What could be the problem? Can U help me? Or email me? [email protected])
THanxx.
Old 06-11-2002, 05:35   #7 (permalink)
GsmCyber's Avatar
Member: 6080
Thanks Meter: 4
Landy page:
USER NAME: mobile
PASSWORD: elibom
Regards
Old 06-11-2002, 10:10   #8 (permalink)
Member: 11444
Talking hmm
THanxx.
ur flash dont finish cause u dont use full flash. In martech directory only have Languange Flash
Pls download full flash on landy page
Old 06-12-2002, 04:23   #9 (permalink)
Member: 3969
Thanks Meter: 9
Solved, tahxx to all!
Old 06-12-2002, 06:20   #10 (permalink)
Member: 11803
Hello rivend,
I can't find "CM0503.BIN" (C/M35) TO REPAIR MY PHONE EEPROM.
Landy Page changed password !
If you have It, I would be very happy, if you would send it to me (size 64KB)
Hope I can bring my M35i back to life. (I can't get this "X35EE_UPLOADER" working under WIN98SE)
I read your "SOLUTION FOR REPAIR DEAD X35 PHONE"
Thanks alot,
Greetz Trailer.
Old 06-12-2002, 09:43   #11 (permalink)
Member: 11444
Re: (NEW) Simple Solution Repair X35 Phone Dead
Originally posted by Trailer
Hello rivend,
Thanks alot,
Greetz Trailer.
password for download still same
login: mobile
pass: elibom
X35EE_UPLOADER is working Good on win 98/me (I use this system)
Problem for X35EE_UPLOADER is your EEprom phone is Damage. So X35EE_UPLOADER cant boot on your phone.
for eeprom ur ask please read my solution for link to download
on landy page is Full flasher not eeprom.
For procedure on my solution is work if u can using it and have all program, softwaren and understand how to use procedure.
Old 06-27-2002, 15:39   #12 (permalink)
Member: 6959
100%...
Man,after step 1,my S35 is DEAD(!) and no posible to flash with WINSWUP or make repair with ZIEMENS...
Old 06-27-2002, 16:55   #13 (permalink)
locer's Avatar
Member: 8435
Thanks Meter: 7
It worked for me of 100 %. Check the battery and try once again!
Old 06-27-2002, 16:59   #14 (permalink)
Member: 6959
Batery was fully charged before "step1" and now no indication...
WBR
Old 06-27-2002, 17:11   #15 (permalink)
locer's Avatar
Member: 8435
Thanks Meter: 7
Charge the battery separately from the phone and try! Or charge in the other phone, ask someone from familiar.
(NEW) Simple Solution Repair X35 Phone Dead (Tested 100% Work) VERSION 2 rinvend x1x to x45/x50 11 07-18-2002 15:38
Simple Solution Repair X35 Phone Dead (Rate if Work) rinvend x1x to x45/x50 7 05-18-2002 09:40
Page generated in 0.27996 seconds with 10 queries
