Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 06-24-2002, 13:43   #1 (permalink)
Member: 406
Thanks Meter: 2
sl45 can't change imei
Got an sl42 that i can't change the imei on
first killed it and corrupted imei
fixed using ldb map then loading
another map calclated using map maker
works fine but imei 00000000000000
tried to restore original imei by creating new map
wrong software
other map with imei 0000000000000 created by same map maker
works fine?????
Old 06-26-2002, 00:54   #2 (permalink)
Member: 8581
Read a Log withLogger 4.02write your IMEI in the box New IMEI, save the Log, copy the infos in the Log in the Logfile Request Area here, someone will calculate Map for you, copy this into a new text file, delete all spaces after * and IMEI Block XX and add two lines at the end of the map. Then save it (*.map) and write it with the logger.
Greez Cryo
Old 06-29-2002, 07:17   #3 (permalink)
Member: 406
Thanks Meter: 2
got it working... already have a working map maker just had to upload with logger 4.02
Can't change IMEI in C3300 pleasse fix it. wgmmmx VygisToolbox 4 05-02-2006 11:42
Z500 can't be read out sw verison and can't change imei fuzhiguo8888 NSPRO 5 02-23-2006 21:10
i can't change imei 2100 saeed-gsm Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 11-29-2004 05:50
m55tool - pgsm can't change imei on m55v11 bandrei2501 E-Gold Based Phones 1 06-15-2004 16:39
Simens S25 ver 44 i can't change IMEI All26.exe (flash futjitsu) vladwork1974 x1x to x45/x50 0 11-14-2002 07:52
Page generated in 0.11538 seconds with 9 queries
