x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
12-04-2005, 05:11 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Bangkok Thailand Age: 44
Member: 114558 Status: Offline Thanks Meter: 4 | SL45 turn off longtime. Should i turn off it by remove batt or without remove batt? The first SL45 turn on for use. The second SL45 turn off longtime because i unused it.But for the second SL45,that's turn off longtime. Should i turn off it by remove battery or without remove battery? Help me please. Thank you very much. |
12-04-2005, 14:33 | #3 (permalink) |
Member: 114558 Status: Offline Thanks Meter: 4 | Sorry for my language. I mean if unused SL45 and switch off it to longtime. Should i switch off it by not remove battery or remove battery? (SL45 switch off to longtime by remove battery.Have side effect?) Last edited by ^NaT^; 12-04-2005 at 14:48. |
12-04-2005, 14:53 | #5 (permalink) |
Member: 114558 Status: Offline Thanks Meter: 4 | If remove the battery when it is a long time unused.Have any side effect with EEprom or any memory in the phone? Sorry for my stupid question because i don't know. Thank you very much. Last edited by ^NaT^; 12-04-2005 at 15:14. |
12-05-2005, 19:40 | #6 (permalink) | |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | No there aren't sideeffects for your phone (except the internal clock-timer will be deleted). But your battery could be damaged by unloading it to a deep level if it's inserted into switched off phone. Because clock and background alarm will consume battery-power furthermore. Quote:
any solution for remove user code without fbus or usb ? | micmac | Nokia Base Band 5 ( BB-5 ) | 0 | 02-06-2009 10:44 |
6230 fast draining batt or batt low | hpcom | Nokia Hardware & Hardware Repair | 4 | 10-11-2006 05:43 |
turn on sharp 703sh then turn off it self | thungfanglie | Cruiser Suite | 0 | 04-10-2006 16:54 |
need device to read dump without removing eeprom or mcu | ADD-GSM | CAR Electronics | 0 | 02-15-2006 16:57 |
You can read Genie2000 EEPROM without remove it | JPascal | Philips | 0 | 03-30-2001 08:20 |
