What do i need to repair my dead C45 BA20 ?? Experts Help please ! >> I have a dead Siemens C45 BA20 , it was originally v17. I flashed it with 3/4 2.05 cracked by xzZ With C45 V9 lg v07.flx file from http://www.odblokgsm.home.sk/downld.htm The phone then would not turn on. I have tried to flash it with the Same .flx files using many versions of 3/4 by xZZ and Xak ! It still does not turn on. I have taken a back up of another C45 BA20 v17 using Unisiemens and then flashed the dead phone with the back up and it still doesnt turn on. The phone still communicates with software so can someone please tell me step by step how to fix it. Thanks very much |
Hi. You should have to use with sl options with flashing software. Becuase it has different boot loader from ordinary c45. So if you flash then it seems flashing but really not flashing. Bye |
U need to flash with all34 v2.0.9 and a flx flash file. After u upload the flash, read a log calc a map and upload it (use bontek dongle maps + log readers + log uploaders) |
1) Flash with flx file in all34 2.0.5 2) Flash with winswup version 31 or hight and now phone in Wrong Soft 3) open map (calculated with soft with dongle) and select sl45 phone, Write calculated map 4) be happy |
Odyssey i have flashed with .flx file and all34 2.05 , The phone doesnt turn on, i have tried to communicate with winswup 31 but it just says could not start phone. You have to run winswup with the phone on dont you ?? Sorry for all the questions !! |
make a map using bontek log readers, make a map with bontek map calc (needs dongle) upload the map using bontek log uploaders. ur phone must be ok after that |
bcool i only have Maxim dongle can you send me this bontek logger and help me with map ? [email protected] |
sure, nps send me a mail with subject MAP ill answer back sending the log readers and log uploaders, then u read the log, and i calv the map for u. nps. |
does the maxim dongle work with the bontek software ? TIA |
Hi Msr. Gsmsalers is it matter if phone was readed with UniSiem selected as C 45.??? For example: I read flash and eeprom selected as C45. Now when I need to restore backup I select Sl45. Will phone after that work OK ??? or I must select Sl45 when reading also ??? Regards Cole |
I dont think usiemens writes the flash as u r saying it will give u error msg. Maxim's doesnt work with bontek stuff. |
Hi. For it you don't use unisiemens for ba20. It can read but can't write even with sl options. Just flash with winswup,then upload eeprom with lc log uploader. |
Hi I have one dead c45 with BA20.:mad: Where to find lc log uploader??? Thanks |
@format1 Log uploaders here Logreaders here Bye.;) BTW: you can download they from official Bontek's site www.bontek.com |
But again Format1 u will need a map calc with bontek dongle, or else those log readers and uploaders wont do a **** |
